Dual USB charging outlet install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmaack, Jul 10, 2015.
Thread Status:
Not open for further replies.
  1. Jul 29, 2015 at 6:28 PM
    #41
    nodal
    nodal Member
    2012 2wd 2.7 Access
    Thanks for the diagram. I just received the usb outlet in the mail. Would adding 3 .1 amps to that circuit be a problem?
    jmaack[OP] likes this.
  2. Jul 29, 2015 at 8:39 PM
    #42
    Dj Suisav
    Dj Suisav Well-Known Member
    Saul
    San Antonio, TX
    2011 MGM DCSB Trd Sport
    RIP 2009 Super White DCSB Trd Sport
    DrFunker likes this.
  3. Jul 30, 2015 at 3:09 PM
    #43
    jmaack
    jmaack [OP] Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    I have checked and rechecked just now. This fuse does NOT power the wire I am tapped in to..Maybe a difference in years or idk. Mine is a 14. But when removed the fuse the outlet still works. Either way I added a 3 amp fuse to the outlet and going to call it good. If you can help me out in another way please do.. I pulled all fuses previously and couldnt get it to quit charging. Id like to know for sure what I am tapped in.
  4. Jul 30, 2015 at 3:10 PM
    #44
    jmaack
    Justin
    Helena Alabama
    When you install post in here how you did your wiring. Id like to know if there is a better way.
  5. Jul 30, 2015 at 9:08 PM
    #45
    jmaack
    Justin
    Helena Alabama
    Hmmmm.
  6. Jul 31, 2015 at 11:21 PM
    #46
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    just bought the dual usb outlet thanks for the link.... is there a constant hot or "always on" circuit beside direct hot from the battery? i would like to charge my phone or something without having to turn the key on... my old truck had the cigarette lighters that were always on and could plug a phone in while i work or something
  7. Jul 31, 2015 at 11:27 PM
    #47
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  8. Aug 7, 2015 at 6:06 PM
    #48
    Yota64
    Yota64 Professional Threadjacker
    Subd!!
  9. Aug 14, 2015 at 1:56 PM
    #49
    nodal
    nodal Member
    2012 2wd 2.7 Access
    Mine is a little different. I'll be installing mine with additional 12V and USB outlets in the bed as well. I'll be running constant power, fused from the battery, thru a relay. Switch in the dash to control everything. I'll also be rewiring the light in my camper shell to work in this circuit. And thanks OP for the write up. I learn a little more in every thread I read about this kind of thing. I'll try to post something on it if my work load ever allows me to get it installed.
  10. Aug 14, 2015 at 2:05 PM
    #50
    DrFunker
    DrFunker Well-Known Member
    Dj Suisav[QUOTED] likes this.
  11. Aug 24, 2015 at 7:59 PM
    #51
    TxStVanWilder
    Tx
    2013 TRD Sport
    FINALLY got mine in today after being on back order from BangGood.. Might actually have this in by the weekend finally. I need to install a gigarette light in the glove box for a hidden plug, has anyone ever done that? Itll be running a dash cam and i ate seeing wires everywhere. i already dont like seeing my ipod cable running from the aux to the glove box.
  12. Aug 25, 2015 at 7:36 AM
    #52
    Dj Suisav
    Saul
    San Antonio, TX
    Never have but shouldn't be hard! You should hard wire straight to the aux and run it behind the dash into the glove so you can stop seeing it! as far as the 12v cig power socket. just make sure its in the farthest back left or back right corner so it wont hit anything when you open the glove.! I'd run a dedicated circuit with an inline fuse to the battery!
  13. Sep 5, 2015 at 3:49 PM
    #53
    Navy Jumper
    Navy Jumper Airborne Paratrooper
    With this being a constant 12vdc on with the ignition off, but still powering the blue LED, will this eventually kill the battery?
  14. Sep 5, 2015 at 4:58 PM
    #54
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Not sure but think in theory one can kill a battery but in practice its unlikely unless the vehicle sat for a very long time. A 2mm LED draws something like 3mA? That's not very much at all. Somebody smarter than me would need to check actual draw and do the math.
  15. Sep 9, 2015 at 4:39 PM
    #55
    jeeprjames
    jeeprjames Well-Known Member
    James
    Summerville, SC
    2006 DCLB 4X4 TRD Radiant Red
    ICON Stage 2, Retrax Pro, frame replaced by Toyota!
    Can anyone tell me what #11 on the same connector below the highlighted #4 goes to? The wire is black with a red stripe. Thanks in advance!
  16. Sep 10, 2015 at 3:58 AM
    #56
    jeeprjames
    James
    Summerville, SC
    Thanks Caribe, I was hoping you would chime in!
  17. Sep 27, 2015 at 1:54 PM
    #57
    Lautzofdirt
    Lautzofdirt New Member
    Greg
    '06 Tacoma 4x4 TRD Offroad DCSB
    Wheels and tires so far
    I used your idea for the rear placement on the armrest console. I routed directly to the battery and used a 5A inline fuse. My next project will be to fabricate some sort of pocket for my phone to rest in against the center console ( front seat part ) next to my right leg while driving. I liked the concept of keeping loose wires out of the way and hidden as much as possible.
  18. Sep 27, 2015 at 2:39 PM
    #58
    Navy Jumper
    Do you have the link to where you got that specific outlet?
    nodal likes this.
  19. Sep 28, 2015 at 7:42 AM
    #59
    Dj Suisav
    Saul
    San Antonio, TX
    Looks great!! :thumbsup:
  20. Sep 28, 2015 at 7:49 AM
    #60
    Dj Suisav
    Saul
    San Antonio, TX
    here you go:
    http://www.ebay.com/itm/Dual-USB-Ca...t-Free-Ship-/161796833581?hash=item25abd7c12d
    Although when i bought it , it was only $2.75 but I guess pricing has gone up. depending on how fast you want to get it youll pay less if its from china vs from someone here in the states but its not much of a difference. same product!
    #60
    Navy Jumper[QUOTED] likes this.
Thread Status:
