Dumb Down Audio for me
Discussion in 'Audio & Video' started by C17Guy, Mar 7, 2010.
  1. Mar 7, 2010 at 6:18 PM
    C17Guy
    C17Guy [OP] Well-Known Member
    Dennis
    Charleston, SC/ Charlotte, NC
    09 SR5 Access Cab 5 Lugger
    Readylift Kit, 245/75/16, HID's, Debadged, Kenwood DNX9960 Double Din Navigation, Image Dynamics Door Components, Pioneer Amp, Dynomax Super Turbo Muffler, Grillcraft Uppers and Lowers
    Hey all,
    I'm fixing to do an audio set up, all I have is the head unit right now (AVIC).
    If I plan on doing components in the front, and a single sub in the rear, is my best option getting two amps? I'd like to get decent sounding stuff, but not ear blowing! It's all going in a access cab, so space is an issue, and I'm trying to stay as factory looking as possible, nothing really showing.
    And whats the deal with the channels in the amp? How many do I need for the components, and how many for the sub?
    This probably sounds stupid, but I figured you guys were the best ones to answer a question like this to help out an audio newb. Thanks! :D
  2. Mar 7, 2010 at 6:26 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    You can run the front components off your head unit if you wanted to and be just fine. As for the sub in the rear, you'll need a amp. A lot of people hide it under the seat.
    Channels in an amp are how many speakers you can connect to it. When picking one for the sub, don't go over 2 channels. That way you can wire it down to 1 channel to work for your sub. A class D amp is specifically made for subs which typically provide a lot of power.
    Figure out how much power you want from a sub and then find the amp.
  3. Mar 8, 2010 at 6:01 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    What is your plans for the rear speakers? Are you more for front sound staging? If so, you can get a 4 channel amp and bridge two for the sub and wire the other two to the front components.
  4. Mar 8, 2010 at 6:04 AM
    DieselTech
    DieselTech Well-Known Member
    Jeremy
    Nova Scotia
    2005 Taco
    3" Lift, Eagle Alloys, 285/75 Mickey Thompson BAJA's, Flowmaster 40 series, 8000k HID's, Low-pro tool box, 7" touchscreen with JBL speakers and sub,
    I would stick to just one amp for your sub, and run the speakers off your headunit (your head unit shuold amplify 50x4), single sub i would just run a 2-channel amp.
    I have a 4-channel amp rigged up to my single 10" sub, but a two channel keeps things cleaner, easier to tune.
  5. Mar 8, 2010 at 1:28 PM
    dreamnz
    dreamnz Well-Known Member
    SoCal
    PreRunner
    Suspension: Camburg Spindles, Bilstein 5100s, Deaver Leafs, BFGs Audio: IDQ 10 in "Marv" box - Hybrid Audio L6 mid bass/ L4 mids / L1 ProSE tweets - RF Power / Arc Amps...BitOne.1 to control it all.
    It's really going to depend on the components you pick and their power requirements. 50x4 from the HU is not RMS. So you likely really have 18-22 watts RMS for the speakers. This will be pretty week for components.
    I'd look for small footprint 4 channel amp. Run channels 1-2 to your front components. Bridge channels 3-4 to run a sub (likely 4 ohm). Run the rear speakers (if used) off the HU.
    That would be an efficient way to go.
    my $.02
  6. Mar 8, 2010 at 1:30 PM
    dreamnz
    SoCal
    PreRunner
    :p Oops. Just saw that someone already suggested that. So, I guess I second it.
