Dumb Question- Model Identification
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Greatwhitewing, Oct 31, 2013.
  1. Oct 31, 2013 at 3:44 PM
    Greatwhitewing
    Greatwhitewing [OP] Well-Known Member
    Mass
    2022 SR5 V6
    That title gets my attention all the time...lol
    I am a caretaker for a Toyota Tacoma (I do not not own it nor did I buy it) but I am really confused about model names.
    The VIN seems to indicate Pre-Runner (according a web page I looked at) and it says "TRD" on the bed sides and it's 4WD with 6 lugs per wheel. I am told Pre-Runners are NOT 4 wheel drive. It's also a 6 cylinder.
    It's a 2005 so what I found says it's a second generation.
    Please help me understand the models and what I am taking care of.
    Thanks
  2. Oct 31, 2013 at 3:50 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    that makes absolute no sense if the VIN indicates prerunner then it should only be 2WD unless the owner of it did a 4x4 conversion 05-14's are 2nd gens and generally the V6 tacos come with the 6 lug pattern
  3. Oct 31, 2013 at 3:54 PM
    Greatwhitewing
    Mass
    2022 SR5 V6
    No conversion. Don't know if the VIN site was accurate either. There is definitely a drive shaft on the front. Has ABS too.
  4. Oct 31, 2013 at 8:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    All 4x4 and Prerunner Tacoma Trucks have the 6 lug pattern.
    If it has a front drive shaft it is a 4x4 and is Not a Prerunner.
    A Prerunner 2x4 has the same configuration as a 4x4 with the exception of the front drive components.
  5. Oct 31, 2013 at 9:09 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The VIN site could be wrong.
    PreRunner models have a "PreRunner" badge above the "SR5" badge on the right side of the tailgate:
  6. Nov 1, 2013 at 3:56 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Not easier than 4x4 mudflaps ? No Prerunner owner would be that dishonest, would they? lol..
  7. Nov 1, 2013 at 4:20 AM
    Greatwhitewing
    Mass
    2022 SR5 V6
    Replying to multiple posts
    No shift knob besides stick for manual transmission. There is a rotary switch I hadn't noticed before for the transfer case (H2, H4, PUSH and L4 are the positions). I have only driven the truck about 20 miles in three different trips.
    Front wheels definitely have a drive shaft with a male spline connecting the wheel flange on the front bearing.
    Again badging says "TRD Off Road" on the side. Says "V6 SR5" on the back.
    So that means it's a Toyota Tacoma SR5 4WD? Not an X-runner, Pre-runner or base model?
  8. Nov 1, 2013 at 5:25 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    It could have been hit in the back, or the tailgate stolen, and the shop that did the replace/repair didn't know what badges to use so they used them all. If it was wrecked, they most likely had to replace the bed side decals.
    Since the bumper is chrome, I am guessing SR5 or TRD Off Road, but something is fishy here if the VIN says PreRunner. Since the OP is asking, I am guessing that they smelled something fishy as well.
  9. Nov 1, 2013 at 5:38 AM
    Greatwhitewing
    Mass
    2022 SR5 V6
    Not lowered either. Is a 4WD model called "Base"? Very likely the the Vin check site was wrong or I miss-read it.
    It was purchased from a Toyota dealer as a used vehicle. Hard to imagine it was a wreck but a tailgate getting replaced is likely IMHO. The dealer does have a good reputation.
  10. Nov 1, 2013 at 6:22 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I'm confused by you saying you're a caregiver for a Tacoma. What does that mean?
    It is not a Prerunner, so erase that from your mind. It's a Tacoma SR5 with the Off-road package. Which includes updated seats depending on year I think A-Trac rear E-locker. Also depending on year reverse camera inside auto dimming mirror, and overhead temp gauge. I think that's about it.
    Also curious, why are you asking?
  11. Nov 1, 2013 at 7:23 AM
    Greatwhitewing
    Mass
    2022 SR5 V6
    Truck belongs to a family member who is not available for a while. That's all I can say, it's a private matter. I am doing some needed work on it in the mean time.
    Thanks for the answer. When I look for parts on-line at sites like Amazon and select Tacoma there are only 3 sub categories, Pre-Runner, X-runner and Base. A little different at rockauto, just select Toyota and get engine size and 2/4WD options and see parts listed all kinds of different ways. Very confusing. Never seen any selection for SR5.
    I couldn't tell what wheel bearings to buy so I went local with the old one in hand to make sure. Wheel bearings in and now I can see it needs tie rod ends.
  12. Nov 1, 2013 at 7:31 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Uh oh. Doing time! J/K!
    Anyway ,yeah websites are strange with that. Anyone I have been on has been like that. I don't know why the don't break it down a little more.
    As far as the wheel bearings, think they are all the same, no? Maybe the 5 lug and 6 lug might be different, but I'm not sure. I have no idea though.
  13. Nov 1, 2013 at 7:35 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I meant for 2nd gen. Sorry. Are they all the same?
  14. Nov 1, 2013 at 7:43 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Ok.
  15. Nov 1, 2013 at 7:48 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
  16. Nov 1, 2013 at 7:50 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    TRD Off-Road wouldn't have the SR5 badge. Me thinks the best course of action would be to contact a dealer and have them run the VIN. The owner of this vehicle obviously did a lot of modifications.
  17. Nov 1, 2013 at 7:52 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    My off-road had the SR5 badge also.
  18. Nov 1, 2013 at 7:58 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Yes my 09 4x4 OR had an SR5 badge on it as well.
  19. Nov 1, 2013 at 8:01 AM
    Greatwhitewing
    Mass
    2022 SR5 V6
  20. Nov 1, 2013 at 8:05 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    :thumbsup:
