dumb question!
Discussion in '1st Gen. Tacomas (1995-2004)' started by felotacoma, Jun 14, 2010.
  1. Jun 14, 2010 at 6:38 PM
    felotacoma
    felotacoma [OP] Active Member
    felipe
    miami
    99 PreRunner SR5
    hello guys I know this might be a dumb question to most of you out there, but i wanted to know what is the difference between the sr5 prerunner and a trd pagckage tacoma. i own a 99 2wd sr5 prerunner and I'm just curious to know what the differences are. thanks for your time.
  2. Jun 14, 2010 at 6:39 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Pre runner is a 2WD with a beefed up suspension from the base model.
    The SR5 model is mostly a trim package
    TRD packages have lots of different features. They have been outlined in several posts around here.
  3. Jun 14, 2010 at 6:55 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Your PreRunner is a 2WD Tacoma based on the 6-lug (4X4) suspension setup rather than the 5-lug 2WD configuration.
    Both the SR5 and the TRD Off Road Packages were factory option packages. Either or both might be found on any given 6-lug Tacoma.
  4. Jun 14, 2010 at 9:09 PM
    felotacoma
    felipe
    miami
    99 PreRunner SR5
    ok thanks, but is the difference between them very noticible? like rear disc brakes?? or what does the trd has that the pre runner does not have?? is the engine the same. or is just cosmetical differences, thanks for the input.
  5. Jun 14, 2010 at 9:11 PM
    kbx10
    kbx10 Well-Known Member
    Kyle
    Chicago
    The beginning of something big...
    Tint, Autopage Security
    Different shocks on the TRD.
  6. Jun 14, 2010 at 10:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    My Tacoma is a TRD and it has the SR5 trim page. Also, there are Tacoma Prerunners with the TRD package.
    Sometimes you can determine the difference by the badging. But more and more owners are de-badging or adding TRD stickers to non-TRD trucks. The one thing that sets a TRD model apart from non-TRDs is the electronically actuated rear differential locker, though not an obvious visual difference unless you see it performing out on the trails.
  7. Jun 15, 2010 at 4:39 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Well said. I had a 96 4cyl taco with TRD sticker (obviously not a real TRD though), and now I have an 01 V6 TRD that had the decals removed!
    I'm all backwards.
