Dummy Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kystnTRD, Oct 1, 2007.
  1. Oct 1, 2007 at 5:50 PM
    kystnTRD
    kystnTRD [OP] Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    looks like a tire tread with a exclamation point in the middle of it? still waiting on the dealership to send me the owners manual. If anyone can help me out it would be awesome
  2. Oct 1, 2007 at 6:07 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Tire pressure monitering system. Check the air pressure in all 5 of your tires (yes I said 5 the spare is monitered too)
  3. Oct 1, 2007 at 6:19 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    If all the tires are all aired properly, you will need to set the tire pressure with the button underneath the steering wheel.
  4. Oct 1, 2007 at 6:30 PM
    kystnTRD
    NW Pennsylvania
    2016 TRD Sport 6MT
    that was my first thought, i checked 4 of them and they were all good to go , spare tire huh? thats the craziest thing i have heard in a while but thanks, i was wondering what the reset button was for so two birds with one stone. thanks again
  5. Oct 1, 2007 at 8:35 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    I think if one or more of the tires are more than 12 psi off, the light comes on.
  6. Oct 2, 2007 at 11:47 AM
    06TRDbama
    06TRDbama Well-Known Member
    Maryville, TN
    06 Prerunner TRD Sport
    im having this issue also...my question is: do you have to take the damn spare tire off to check it? i layed underneath the truck and i didnt see a valve stem sticking out anywhere. all four of my regular tires were about 38-39 psi
  7. Oct 2, 2007 at 12:42 PM
    maverick491
    South Jersey
    Yes. From the factory the valve stem faces up. I'm not sure if you could remove the tire completely and reverse it. I don't see why you couldn't, but I don't know for a fact.
