Duratracs on 2nd Gen ?
Discussion in 'Wheels & Tires' started by 757southpaw, Jan 29, 2010.
  1. Jan 29, 2010 at 4:22 PM
    757southpaw
    757southpaw [OP] Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    I have on 07 DC LB Sport 4x4 and I'm looking to but the Goodyear Duratracs 265/70/17 on the stock alloy wheels with no lift (yet). I'm wondering if these tires will rub anything on the truck w/out modifications. Has anyone with a similar truck put these tires on and have had issues? Also, Do you TW's think this size tire will look okay once the 2.5" leveling kit in the front and 2" aal in the back are intalled? Thanks in advance!
  2. Jan 29, 2010 at 6:11 PM
    Mountainman
    Mountainman Well-Known Member
    SoCal
    08 6 Lug
    Icons, Okoles, TRD, URD, Deavers, Magnaflow and some other stuff.
  3. Feb 20, 2010 at 10:38 AM
    huff.jeremy
    huff.jeremy Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    I just installed my 265/75/16 Duratracs last night. They are the same diameter as your 265/75/17's (31.6 inches). They are on a 2010 4x4, non-sport.
    They fit, BUT I was forced to remove my front mudflaps; even though there was clearance, it was not enough for my taste since I couldn't even get my pinky finger in there with the tires turned at certain angles.
  4. Feb 20, 2010 at 11:04 AM
    shockittillyareconizeit
    shockittillyareconizeit Well-Known Member
    Dustin
    California
    '07 Coma PreRunner
    Front - Icon 2.5 Coilovers, Maxtrac 4" lift spindles, TC UCA's Rear - Billy's 5100/1.5 AAL, 3" lift blocks MB Predator wheels - 16x8 plasti-dipped matte black Toyo Open Country A/T 305/70/16 Satoshi grille Blacked out badges DTRL Wet Okole seat covers
    Yeah, they'll fit, but you still might have to do a little bit of modding. IMO you might as well just do a 3" with 285's. It might look a little weird if you have it lifted a bit with stock tire size. But that's just my opinion, i'm a nobody. Hope everything works out for you.
  5. Feb 20, 2010 at 11:17 AM
    matt86
    matt86 Well-Known Member
    NC
    2008 Tacoma SR5 4x4
    I was looking to go the same setup (I have the 5100's set at 2.5 in in the front) and was told that I'd have to get spacers to clear the UCA's and that I'd have to do a little trimming on the fender/liner.
  6. Feb 20, 2010 at 8:03 PM
    757southpaw
    Jay
    757
    Cool. I've scored my lift and will be installing it before the tires. Thanks for your feedback.
  7. Feb 20, 2010 at 8:07 PM
    757southpaw
    Jay
    757
    I hear you bro and I appreciate your opinion. Believe me the 285's are on my mind!
  8. Feb 20, 2010 at 8:11 PM
    757southpaw
    Jay
    757
    I hope that's not the case! I've read on this forum that 265/70/17's are the largest tire that I could get without adding spacers and new UCA's. The Duratracs are beefy for an AT tire though...I guess I'll find out when the time comes.
