DVD/CD/Bluetooth for 97 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by b54406barrel, Dec 18, 2013.
  1. Dec 18, 2013 at 9:09 AM
    b54406barrel
    b54406barrel [OP] Member
    Rex
    Pendleton, OR
    1997 tacoma xc 4x4
    paint/wheels
    Does anyone know of a make/model DVD/CD, bluetooth (preferably with a back up camera option) for a 97 tacoma? Pulled the panel off over the din cd player & the space below it, and it's a weird size. Not single, double, or even 1-1/2. I didn't really want to install a unit with a pull out screen on a single din if I could have the full screen.
    Thank you very much for any assistance!
  2. Dec 18, 2013 at 9:20 AM
    mr optimist
    mr optimist Mr Lazy
    Sam
    Alamosa, CO
    1998 4runner SR5 5 speed
    Supercharged, 5 speed, AOR Sliders, Tundra Front Springs, OME 906 Rear springs, Bilstein Tundra 5100s, Factory Diff lock, Wrangler Authority 275/75/16
    I have a 1996, when I replaced the head unit it was definitely double din. It already had an after market unit so something may have been changed. I installed this...
    http://www.amazon.com/gp/product/B006WVX9R2/ref=oh_details_o01_s01_i00?ie=UTF8&psc=1
    While it does not have video the sound quality is good, and the Bluetooth works very well. I would recommend Clarion as a good head unit, I know they make touch screen units as well.
  3. Dec 18, 2013 at 9:23 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Pioneer avh3500bhs is what I have and it's wonderful. But.... I found I rarely use the dvd player part.
  4. Dec 18, 2013 at 9:23 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Double din unit
  5. Dec 18, 2013 at 9:24 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Double din is an easy fit without modification
  6. Dec 18, 2013 at 9:48 AM
    b54406barrel
    Rex
    Pendleton, OR
    1997 tacoma xc 4x4
    paint/wheels
    Ok, that's good to hear! Opens up a whole bunch of options, maybe even gps though we're mostly after the bluetooth. Also my wife is addicted to back up cameras. I measured using an older delco-bose 'double din' from one of our corvettes and it wouldn't fit. Maybe it was too make/model specific?
    Thank you, really appreciate the advice!:cheers:
  7. Dec 18, 2013 at 10:24 AM
    offrdmania
    Templeton, Ca
    Aftermarket double din only. Factory double dins are vehicle specific and usually dont fall into the universal double din dimensions
  8. Dec 18, 2013 at 10:31 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    It should be a standard double DIN. Hit up crutchfield.com for fitment check and shopping, then check Amazon for pricing. It's often cheaper. :)
  9. Dec 18, 2013 at 10:36 AM
    offrdmania
    Templeton, Ca
    It is cheaper through Amazon but Crutchfield gives you install kits, correct wiring harnesses and 24/7 tech support, included in the purchase price. Worth the extra few dollars to me. You are on your own when purchasing through Amazon
  10. Dec 18, 2013 at 10:45 AM
    JLee50
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Yep, certainly depends on what exactly you need. Sometimes for a ~$60 savings, I'd rather spend the $15 on a harness.
  11. Dec 18, 2013 at 11:31 AM
    b54406barrel
    Rex
    Pendleton, OR
    1997 tacoma xc 4x4
    paint/wheels
    My stock harness is long gone as someone had put in a pioneer and spliced everything so the adapters aren't too pertinent. I will make sure to check consumer reports on any unit I consider. Thank you all, again.
  12. Dec 18, 2013 at 11:35 AM
    JLee50
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    If you get another Pioneer deck, your existing harness may plug right in.
