Dynolicious dyno times!!
Discussion in 'Performance and Tuning' started by tacoskim, Aug 8, 2008.
  1. Aug 8, 2008 at 8:27 PM
    tacoskim
    tacoskim [OP] Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    well guys i downloaded the program for the itouch and i entered the vehicle info calibrated it and got some times.. the first time i was messing around and it wasnt calibrated and the spedometer was off like 10 mph, then when i calibrated the speedometer was dead on, so i did a off the line time, i led off at 70 mph to be safe.... so heres my first times
    0-60 7.98 sec
    1/8 mile 10.49 sec @66.5 mph
    i didnt get the 1/4 yet cuz this was done on the street, this weekend i will find an inclosed location and get the peak hp and 1/4 time.
    so what u guys think of this time?? seems pretty accurate
  2. Aug 8, 2008 at 8:30 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    mid to low 16 sec run on a track
  3. Aug 8, 2008 at 8:33 PM
    tacoskim
    Los Angeles, CA
    Stock
    stock tires.... again this wasnt WOT, i had to led off and on the calibration said top speed was 68 so i think i can definitiley be in the 15s on the 1/4 mile
  4. Aug 8, 2008 at 8:44 PM
    jaxchrisfla
    flooriduh
    lots
    i would hope with those mods, you would be well into the 15s.
  5. Aug 8, 2008 at 8:46 PM
    tacoskim
    Los Angeles, CA
    Stock
    i just did a quick run through, i put down that the truck weighed 4000 lbs... my next run the times will be alot better since ill have WOT. this time around i wanted to put a good acceleration to see the bar graph go up gradually and to make sure this tool is accurate.
  6. Aug 8, 2008 at 9:18 PM
    BLOCKADE
    BLOCKADE Well-Known Member
    TRD Off Road
    Weather Tech Floor Liners, Front Bed D-Rings...
    did it give you a Horse Power estimate?
  7. Aug 8, 2008 at 9:23 PM
    tacoskim
    Los Angeles, CA
    Stock
    yea my top speed was 68 and peak hp was 156
    it was still calculating while i was decelerating so i dunno if that has something to do with it im still not familiar with this software, i downloaded and i got excited and went straight for it. later on im gonna mess around with it more and will get much more accurate numbers while i do different test
  8. Aug 8, 2008 at 9:36 PM
    BLOCKADE
    TRD Off Road
    The V6 is suppose to have 236hp, if you didn't give it all you had it may not have given an accurate reading. Dynolicious' website doesn't have much information yet on how to properly calibrate and use the software.
  9. Aug 8, 2008 at 9:44 PM
    tacoskim
    Los Angeles, CA
    Stock
    yea those first times are off, i gotta give it a solid hard 1/4 mile for it to be accurate. i only got the truck up to 68 mph. its crazy how the speedometer was dead on to my truck
  10. Aug 8, 2008 at 9:44 PM
    jaxchrisfla
    flooriduh
    lots
    236 at the flywheel. with relates to about to about 190-210 depending on trans(auto, auto+transfercase, manual, manual+trandfercase)
  11. Aug 8, 2008 at 9:45 PM
    tacoskim
    Los Angeles, CA
    Stock
    oh yea i forgot to state, the hp is to the wheel
  12. Aug 8, 2008 at 10:43 PM
    tacoskim
    Los Angeles, CA
    Stock
