E-Locker question and support
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icepuck72, Nov 14, 2019.
  1. Nov 14, 2019 at 12:39 PM
    Icepuck72
    Icepuck72 [OP] Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    So my E-locker will not work properly. I even bought a new OEM actuator and it's still not right...so I'm thinking it's some electronic gremlin somewhere. I don't have the time to chase it down....
    Anyone use this kind of product to get your rear locked? No more weird electrical issues....just a manual way to engage it. I like it. Want your thoughts.....
    https://www.lceperformance.com/8-E-...FUG5cJbpkG_fNm_ekqnCKSB6vytMWywxoCTREQAvD_BwE
    EDDO likes this.
  2. Nov 14, 2019 at 12:44 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    oh...and you can engage it in 2hi as well.
  3. Nov 14, 2019 at 1:01 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    whelp yeah, you have full manual control over it...
    Problem i see with this is electronic functionality of stuff like abs / traction control disable while locked wont work.
    Icepuck72[QUOTED][OP] likes this.
  4. Nov 14, 2019 at 1:10 PM
    eon_blue
    Azusa, CA
    In this case wouldn't it be cheaper (maybe) and less time consuming to just have a shop figure out the issue with your e-locker?
    Unless you're looking for a reason to go cable actuated, which is entirely understandable as it is pretty cool AF imo.
  5. Nov 14, 2019 at 1:14 PM
    markus30
    markus30 Well-Known Member
    mark
    Florida
    2009 tacoma dcsb trd
    king 2.5 coils with resi in the front, dirt king lca, TC uca, archive towers, 14" rear kings, shackle flip, dakars HD. pelfreybilt front bumper, sliders and skids, brute force rear bumper, method nv 17" wheels, 35" ko2s, 4.56 gears locked, EBC brakes,TC spindle gussets, dual batterys, arb fridge, bunch of other crap..... more to come
    I believe the sensor in the rear end is seperate from the actuator. Meaning if you convert to cable it should still recognize when the locker is engaged and work with the abs and all that
  6. Nov 14, 2019 at 2:43 PM
    Muddinfun
    Muddinfun Well-Known Member
    GEEZ! Can they make the handle any bigger? That's nuts. All they need is something like this.
  7. Nov 14, 2019 at 7:33 PM
    Eselhengst
    Eselhengst Well-Known Member
    South of Abbotsford
    2011 Access cab TRD Offroad
    Sway-A-Way 2.0 coilovers and rear shocks Wheelers 8 leaf springs and superbumps ARB front bumper Trail Gear sliders RCI aluminum skids URD Spec-U exhaust etc.
    Do they make similar giant levers for the transfer case and front differential disconnect? Oh, and one for the E-brake too, because it’s awkward to pull a Rockford with the foot pedal style. I’m kind of joking, but also mostly serious, it is nice to have positive mechanical control of those systems, but the electric versions have worked well for me so far
  8. Nov 14, 2019 at 8:06 PM
    Muddinfun
    Here you go.
    US Marine and llamasmurf like this.
  9. Nov 17, 2019 at 8:19 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    Does anyone have a wiring diagram for the rear diff lock/ 4wd system? I've searched and searched..even found some threads on TTORA...but the links posted are all dead.
  10. Nov 17, 2019 at 8:20 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    If I can get a wiring diagram, I can start there..the actuator is brand new. There's gotta be something crimped off or shorting out from the ECU to the actuator.
  11. Nov 17, 2019 at 8:31 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Lenco !!!!! :drool:
    Muddinfun[QUOTED] likes this.
  12. Nov 17, 2019 at 9:22 PM
    Muddinfun
  13. Nov 18, 2019 at 4:33 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
