E85?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HMA, Jun 14, 2010.
  1. Jun 8, 2014 at 2:36 PM
    smd3
    smd3 Well-Known Member
    That's forced induction. These motors would lose power, even with the necessary programming.
    I'm pretty sure the energy density on e85 is lower, but the octane is higher. That's why you need the larger injectors, and why the turbo/sc cars can make so much power with it.
  2. Jun 8, 2014 at 2:37 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    You are correct
  3. Jun 12, 2014 at 1:57 PM
    Yota64
    Yota64 Professional Threadjacker
    I thought higher octane=less ethanol? Is it backwards? I have always heard the higher grades like 93 called "high octane"
  4. Jun 12, 2014 at 2:41 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Typically all gas station have upto 10% e in all grades here anyway, some stations ive seen have a lower % as u go up in grade, but e85 is about 105 octain due to the alcohol content. Alcohol is used as an octain booster more or les in gas but is not the only additive used to increase octain
  5. Jun 12, 2014 at 2:52 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    If you would have seen the inside of the carb on my hotrod with only 10% ethanol in the fuel, you wouldn't want to be anywhere near that stuff!
    Ethanol is cheaper, produces less mileage, and will cause a lot of problems in your fuel system. Corn is meant to be grilled and eaten, not run as fuel in your truck......Just say no to corn fuel!
  6. Jun 12, 2014 at 3:19 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Exactly.
  7. Jun 12, 2014 at 8:05 PM
    Yota64
    Oh okay, thanks.
    So someone earlier posted E85 was more powerful with turbo and supercharged engines? Well you can put a blower on a Taco so is is harmful then? With necessary modification
  8. Jun 12, 2014 at 8:15 PM
    yota243
    E.J.
    north Alabama
    I dont know all the science behind it but alcohol is a detergent and overtime will deteriorate rubber, but with the proper injectors and fuel pump and lines, benifits can be had. Alcohol is denser than gasoline and also requires more fuel grams per grams of air for detonation, almost twice as much actually. Which means it should run cooler when u pump more fuel in, which helps since turbos and sc produce heat. And premium fuel is needed in most F/I motors and alcohol is higher octain and $1 cheaper a gal than premium around here.
  9. Jun 12, 2014 at 8:25 PM
    Yota64
    Okay, so it really depends on your setup I guess. As for me and most other Tacoma owners I feel the best option is 93. :thumbsup:
  10. Jun 12, 2014 at 8:31 PM
    yota243
    E.J.
    north Alabama
    Yeah i run 87 in mine actually with no complants but have plans to turbo soon and since i have to upgrade the fuel system anyway im getting ethonal rated parts. In the long run ill save a dollar a gal with higher octain and only lose 25% fuel economy which still nets me a slightly better fuel cost.
  11. Jun 12, 2014 at 8:35 PM
    Yota64
    So you're going the E85 route? And sweet yeah that dollar is just over 25% of the cost of fuel. Be sure to make a thread!
  12. Jun 12, 2014 at 11:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Some do not understand what the Octane Rating number actually is:
    Definition: Octane number is a value used to indicate the resistance of a motor fuel to knock. Octane numbers are based on a scale on which isooctane is 100 (minimal knock) and heptane is 0 (bad knock).
    The Octane Rating has nothing to do with the energy stored in the fuel. It just defines how much you can pressurize the fuel before it ignites from the pressure.
    carolinataco12 likes this.
  13. Jun 24, 2014 at 5:25 PM
    Orion Antares
    Orion Antares Well-Known Member
    Wisconsin
    TRD Off-Road White 4x4
    Corn does make for a poor biofuel. Growing and processing switchgrass for ethanol would be far more efficient.
  14. Jun 24, 2014 at 7:02 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    It is my understanding that even switchgrass ethanol requires two gallons of diesel to be burnt (tractors, harvesters, transport, etc) for every gallon of ethanol produced. That's not as bad as corn, but why not cut out the middle and just run diesel to begin with? I know, I know, it's not as "green" or something.
  15. Jun 24, 2014 at 8:46 PM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Ethanol only allows the engine to make more power because more timing can be added. The other drawbacks from it are not worth it.
  16. Jun 24, 2014 at 8:55 PM
    #36
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Do not even think about it.
    Even if your vehicle CAN use E85, do not even think about it.
    $1.80/gallon gets eaten up very quickly because ethanol has 20% less energy content than gasoline. Worse power, worse fuel economy... and maintenance.
    Toyota requires 2500 mile oil changes on vehicles that run E85.
    Ethanol is nothing more than a political shell game. When the government subsidies dry up, it won't be $1.80/gallon. It costs more energy to produce than you get out of it.
  17. Jun 24, 2014 at 8:59 PM
    #37
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ahem....
  18. Jun 25, 2014 at 6:47 AM
    #38
    Orion Antares
    Wisconsin
    I believe the estimate was 13:1 for output verse input once the grass is established. Since it's perennial, it only needs to be tended rather than replanted every harvest like with corn. That estimate could drop depending on seasonal rains though.
    If you are using an engine optimized for ethanol the only drawback, aside from energy density, is the same as with diesel in the winter. FFVs are only designed to accommodate E85, not to optimize its use.
    When the government subsidies dry up we'll finally stop seeing so much HFCS in our food as well. I wouldn't recommend holding your breath waiting for corn subsidies to dry up...
  19. Apr 26, 2015 at 11:20 AM
    #39
    stephen l r
    stephen l r New Member
    2000 tacoma
    rodriro likes this.
  20. Apr 26, 2015 at 11:32 AM
    #40
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Another item - Toyota (on Tundra) specifies a 2500 mile oil change interval if e85 is used.
