E85?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HMA, Jun 14, 2010.
  1. Jun 14, 2010 at 7:00 AM
    HMA
    HMA [OP] Well-Known Member
    Hal
    Bainbridge, Ga
    '10 Taco Surveying Machine '22 Lunar Rock
    Can the new (2010) Toyota's use E85 (85% ethanol / 15% gasoline)? I'm guessing not since the gas cap doesn't say it's ok. The place I buy my fuel just started carrying it and the price has been around $1.80. I want to give it a try if the Tacoma can drink it. My buddies that have used it say the only noticable difference is a slight decrease in milage. I know that if your vehicle is not approved for it using it will badly damage your fuel system and possibly your motor.
  2. Jun 14, 2010 at 7:49 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    2010 tundras and sequoias have the option, not tacomas
  3. Jun 14, 2010 at 7:53 AM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    noooooooooooo
  4. Jun 14, 2010 at 8:07 AM
    HMA
    Hal
    Bainbridge, Ga
    Thanks.
  5. Jun 14, 2010 at 9:58 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
  6. Jun 14, 2010 at 10:46 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I got almost 50 whp from converting a 2.0 LSJ motor (cobalt) into E85 and the fuel economy went down about 20% as well. For us, it was as simple as changing the injectors and the adjusting the scaler for the injector flow rate.
  7. Jun 14, 2010 at 11:09 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
    there are cheaper options for the taco. The nice thing about the APR kit is you can still run normal gas if you want to with no ill effects.
  8. Jun 14, 2010 at 11:11 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I read that, that is a nice option.
  9. Jun 14, 2010 at 12:09 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    why would you want to?! you will get 20-25% less MPGs as E85 has 25% less energy content than E10 (regular pump gas)
  10. Jun 14, 2010 at 12:24 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    Running E85 stock? NOOOO...
    With some fuel system modifications? Yes.
    Practical? Probably not. Depends on your preference.
    Go check out Dually's Drop Taco. He's running E85...but just about nothing under his hood is stock.
  11. Jun 14, 2010 at 12:32 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    All depends on how much e85 costs if its cheap enough then it will save you money otherwise its just a higher octane fuel option.
  12. Jun 14, 2010 at 12:39 PM
    HIKR
    HIKR Well-Known Member
    Tacoma, WA
    '09 4x4 dbl cab in pyrite mica
    6% Tint all around, Toyota all-weather floor mats, Toyota bed extender and skid plate, Python 991 remote-start alarm, oem cruise control and class III hitch were all installed within a couple months. I then installed Icon c/o's and Icon's 3-leaf aal with 17x9" GA9's and 285/70/17 Goodyear Duratrac's. The DRL mod was done, as was a custom rack setup similar to the org. cross bars. Blacked out headlights bought online, and a BOSS 1500 under-seat sub installed along with a Pioneer double-din DVD player
    don't forget that the other benefit is being more green ^
  13. Jun 14, 2010 at 1:09 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    yes and no but thats more of a political thing and i'm not going there.
  14. Jun 14, 2010 at 2:24 PM
    HMA
    Hal
    Bainbridge, Ga
    I was looking at this from a cost/benefit angle. I use this truck for a Land Survey Crew. It logs +- 550 mi./week. Modifications to use it aren't worth it. Does anyone know if E85 compatibility is in the works for Toyota? The fact that it is std on most American brands and not on most Jap. brands makes me wonder about the long term effects on the plastic/rubber stuff. Could just be politics. FYI there are several new plants in Ga. that are making it out of pine tree limbs/tops that used to be waste. John Deere even makes a machine specifically for gathering the stuff.
  15. Jun 14, 2010 at 6:09 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    The fuel system can handle E85, well all but the injectors....the ECU is the next thing, the programming needs to reflect the change in flow and injectors. I am sure in time, they will introduce a model thats compliant. You can refer to post #5.....you'll have to do your own cost analysis to see if adding the mods are worth it.
  16. Jun 29, 2012 at 12:10 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    name an american vehicle that lasts as long as your truck will???
    still waiting..
    that is a prime exampe of why you shouldnt use it. if it were truly as good as it is marketed, why arent the japanese cars built to use it?
  17. Jun 29, 2012 at 1:37 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Not a political thing, it's factual.
    E85 is not green and will not net better gas mileage. Unless your vehicle is equipped to handle it (it's highly marketed so it would say so in the owner's manual), you shouldn't try it. Seals and lines will be destroyed over time, and the equipment controls cannot compensate for it.
  18. Dec 28, 2013 at 11:35 AM
    grippy
    grippy Active Member
    Tempe, AZ
    05 Tacoma 4WD
    What about stainless steel valves? Does the tacoma have them from the factory or not? If not I wouldn't mess with it unless someone makes aftermarket stainless valves. E85 is a great option especially when gas prices rise and it runs cleaner and better for your engine with correct mods of course. Downfall would be that you do get less miles per tank but when the overall price is cheaper and you get more power then it's a no brainer that it's better. Also they make an aftermarket gas tank for the tacomas that holds a higher capacity of fuel which would be ideal for e85 conversions. If anyone knows about the factory valves I'd be very interested to hear the answer.
  19. Jun 8, 2014 at 12:41 PM
    frog13
    frog13 Well-Known Member
    Yes ,it is politics . It's about controlling you and what you will do ,per "them" . Running alcohol based fuels is not the answer and it is a detriment to all combustion engines . China's not "green" , nor Russia and alot of other countries .It's only a policy for non-Socialist / Communist countries . The Earth is going to go through it's normal "Climate changes" ( notice how "they" changed the terminology...they started this fiasco as "Global warming" then , they changed it to the present BS ) regardless what "man" does or doesn't do....don't be fooled by Gov . ( just like, "they" have WMD...weapon's of mass destruction....then come to find out Iraq didn't ) . Cheers.:D
  20. Jun 8, 2014 at 1:02 PM
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    The cornhole lobby is why e85 is even offered anywhere in this country.
    They are trying to use the money you are paying for new vehicles and fuel in those vehicles to put money in their pockets....and that's just the tip of the eco-iceburg.
    TacomaMike37 likes this.
