East Coast Gear Supply Freakin' Rocks!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by winkel, Dec 3, 2016.
  1. Dec 6, 2016 at 6:52 PM
    #41
    Shikokaon
    Shikokaon Slacker Extraordinaire
    Portland, OR
    2017 Tacoma D-Cab Off Road (MT)
    Thank you! Truck only has about 1500miles so am sure i can reuse seal (as its almost brand new), just wasnt sure if its one of those things that gets damaged when removed, and a new one needs to be used.
  2. Dec 9, 2016 at 7:20 AM
    #42
    J_Hacker
    J_Hacker Well-Known Member
    Somewhere in Virginia
    '19 White Tundra Crewmax
    Bilstein 6112, CB +2 Shackles, Soft Topper, Method 316, 295’s
    Well after reading this thread I tackled this task yesterday. Took about 4 hours. Had never done anything like this before so wanted to take my time and had some difficulties. But all in all got it done. Feel accomplished and the best part, Vibration free.
    Dgibson529 and danbow like this.
  3. Dec 15, 2016 at 5:04 PM
    #43
    winkel
    winkel [OP] Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Excellent! It's pretty satisfying isn't it!!!
    I'm glad this thread is getting some mileage. So often we have questions and get a lot of good answers but it's nice to hear so much positive feedback from people that have actually applied the fix and had the 'hoped for' result!
    I was so happy that it fixed my problem that I just had to help ECGS get more product out there.
    J_Hacker[QUOTED] likes this.
  4. Dec 16, 2016 at 3:23 PM
    #44
    btripptrd
    btripptrd Well-Known Member
    Barrett
    Graham, WA
    06 tacoma trd
    2.5in w/ rancho RS9000s, AAL, ECGS bushing
    How long (miles) have owners driven with the front driver side diff vibration/bad needle bearing? Any wear issues, or breakage to worry about?
    HITMAN416 likes this.
  5. Dec 16, 2016 at 4:34 PM
    #45
    Shikokaon
    Portland, OR
    I think its mostly an annoyance from what I've read, but am sure that enough mileage on it would definitely mean there are some shavings in fluid/oil...
    Anyone with experience that could shed some light on this???
  6. Dec 16, 2016 at 8:15 PM
    #46
    winkel
    Corydon, IN
    Yeah, I have no long term personal experience with it but I've read other threads where folks said it was just an annoyance and didn't cause any damage to speak of. Before I installed the bushing, I did slip the bearing and the bushing onto the end of the axle shaft. There was noticeably more play in the bearing. My axle shaft looked fine but again, I didn't have more than a few thousand miles on it since the lift.
  7. Dec 17, 2016 at 4:48 AM
    #47
    J_Hacker
    I had around 24,000 on my original needle bearing. I couldn't tell how the bearing once once i pulled it as i destroyed it in the process.. But I did have noticeable wear marks on the input shaft of the cv. Granted my truck is lifted so it put more stress on the cvs and that could have been part of the issue. Never the less a few hours and the problem is fixed.
  8. Dec 17, 2016 at 5:36 AM
    #48
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    It's been almost 15,000 miles on my ECGS bushing and no issues whatsoever. FWIW, when I tapped the bushing in, I checked how far it had gone by feeling to see if the outside face was flush as well as checking the inboard side to see how close it was to the spider gear. I think I ended up just outboard of flush, but there's plenty of room between it and the spider gear in case I need to remove it, I can get a tool on the back of it. I forget what ECGS says the limit is, but you can have it sticking out pretty far IIRC.
  9. Dec 20, 2016 at 11:02 AM
    #49
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Does anyone have the removal tool that they want to sell? I am getting ready to do it here in the next month or so.
  10. Dec 20, 2016 at 12:02 PM
    #50
    btripptrd
    Barrett
    Graham, WA
    06 tacoma trd
    I'll have one for sale in a couple of weeks, if all goes right I'll have it in before first of the year. I'll post into this thread when it is available.
  11. Dec 20, 2016 at 12:54 PM
    #51
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    @Crom posted in another thread showing his CV shaft after something like 70K miles with the needle bearing - it didn't look too good.
  12. Dec 24, 2016 at 7:51 AM
    #52
    dpi
    dpi Well-Known Member
    Dan
    Tulsa, OK
    AFE Stage 2 SI CAI Banks 3" Mandrel bend Cat Back dpi Rock Sliders
    I wanted to give cudos to the folks at ecgs. I placed my online order for the bushing and puller at 3:54 pm central time on 12.22. I had a tracking number 3 minutes later at 3:57 and today, 12.24 @ 9:30 am the doorbell (in Oklahoma) rings and it's fedex dropping of my bushing and puller. Talk about excellent customer service and they do rock!
  13. Dec 24, 2016 at 9:11 AM
    #53
    JadedTaco
    JadedTaco Well-Known Member
    IA
    15 OR SSM (MT)
    Lift, tires, mats, blah, blah, blah...
    Did mine yesterday. Haven't driven it much, but the vibes seem to be gone.
  14. Dec 31, 2016 at 8:38 AM
    #54
    btripptrd
    Barrett
    Graham, WA
    06 tacoma trd
    ECGS install went very well, no vibes or sounds from the front diff any more. I would strongly recommended replacing the needle bearing if you have a lift and are experiencing rumbled strip noises from the front. Its like a new truck again. Change the front diff fluid at the same time, cv shaft had a little bit of polishing but no marks after 1500mi of driving.
  15. Dec 31, 2016 at 11:03 AM
    #55
    JLaScala
    JLaScala Super White is gonna treat you right.
    Snohomish Washington
    2010 TRD Sport 4x4 long bed crew cab.
    Secondary air filter removal, K&N drop in, Removed front mud flaps, Toyota all weather matts, skid plate, bug guard. Bilstein 5100's all around fronts set at 2.5", OME add a leaf, Goodyear Wrangler Authority 265/70/17, stubby 6.5" antenna, smoked tail lights, blacked out badges.
    This works. Had no droning prob with my 09, then did the same lift with my 10 and boom it was there. After the bushing was installed the problem was resolved. Totally worth it. ECGS fixing Toyota engineering cock ups one at a time.
  16. Jan 1, 2017 at 8:49 AM
    #56
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    diff drop useless please explain
  17. Jan 1, 2017 at 11:04 AM
    #57
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Guess I'm lucky not to have this vibration issue. Or, maybe I have it and don't realize it. I do have some steering shaking but I diagnosed the problem with worn out control arm bushings based on the truck 'floating' and the uneven tire wear. Recently checked the wheel bearings - third assembly on driver-side is good; second one on pass-side has a little play. Truck feels the same to me whether in 2WD or 4WD. Installed 2.5 lift at about 40K and never did the diff drop.
  18. Feb 19, 2017 at 6:11 PM
    #58
    jrlin718
    jrlin718 Well-Known Member
    Jonathon
    Louisville, KY
    2016 TRD Sport Barcelona Red 4X4 Double Cab
    Plastidip front grill and badges Bilstein 5100 shocks set at 0 OME 888 coils Lights Racing UCAs Headstrong AAL TRD Pro Wheels Matte Black BFG KO2 275/70/17 Rocky Mounts DriveShaft SD KB Voodoo Bed Rack ECGS 8 in clam shell bushing Custom Bedside Decals TRD MTB Edition CBI front bumper CBI rear high clearance bumper CaliRaisedLed 20 in single row bumper ARB CKMA12 Air compressor
    So i figured id share my experience. I am not super mechanically inclined but I am very well read on the subject and watched a ton of youtube videos beforehand. I lifted my 2016 sport a few months ago and got the vibe. Toyota did not have an answer so they replaced the whole front diff which solved the problem for about 2k miles. I finally grew the balls to do it myself.
    I used these youtube video as my guide
    CV axle removal video
    https://www.youtube.com/watch?v=ZfpP4sy8qYw&t=226s
    ECGS needle bearing removal and ECGS bushing install video
    https://www.youtube.com/watch?v=WnA_R3gFf2s&t=200s
    I rented most of the necessary tools from autozone loan a tool program (I can not overstate the importance of having the right tools and it doesn't cost anything to rent from autozone (100% refund with return of tools within 90 days))
    heres a list of what i rented
    35 mm socket
    breaker bar
    torque wrench
    tie rod separator
    bearing driver kit
    263 dollars total shipped to my house for free and 100% refundable if you return the tools within 90 days which I did today
    (The spring compressor was for something else and is not needed FYI)
    Some other tools I had that were necessary
    Pry bar
    10 mm allan wrench on a socket driver
    ball pien hammer
    small sledge hammer
    jack stands
    jack
    standard set of sockets up to 22mm
    I bought the $60 needle bearing puller tool and in my opinion it is a must
    I used the ECGS recommended gear oil afterwards which i ordered from Amazon (85W-140)
    https://www.amazon.com/gp/product/B000IG20T0/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    Used this forum for a guide of torque specs for reassembling everything
    https://www.tacomaworld.com/threads/the-torque-spec-guide.318116/
    All in all it took me about 4 hours and keep in mind I've only driven about 20 miles since the install but my taco drives like a dream now. Quieter than the day I bought her. Hope this helps anyone with any doubt about doing it yourself. The two hardest parts were seating the removal tool behind the needle bearing and the other was pounding the new ECGS bushing in.
    Brauhnyman and EatSleepTacos like this.
  19. Apr 17, 2017 at 9:40 PM
    #59
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Subd for later since I'll be doing my ECGS bushing in the next month or two.
  20. Jun 7, 2017 at 1:11 PM
    #60
    Sna
    Alberta
    I'm having a hell of a time getting the ECGS bushing in the last 1/16"-1/8"....any tips?
