Easy question about hid kits.
Discussion in 'Lighting' started by emglishe30, May 7, 2010.
  1. May 7, 2010 at 8:14 PM
    emglishe30
    emglishe30 [OP] Well-Known Member
    NJ
    01 2WD Taco 2.4
    Debadged to TACO, Kenwood reciever, pioneer 6 X 8's, sunpro 3" tach, assorted led lights, sirrius, gps...
    So i have an 01 taco interested in a plug and play kit. I used to have one on my si and it was the best investment I ever made. Can I just buy a kit to fit? Will I have to modify anything? What type of kit do I need?
  2. May 7, 2010 at 11:29 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    Just go to DDMTuning.com and order your kit!
  3. May 7, 2010 at 11:48 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    yep, plug and play. No splicing or anthing required. Just hook into the battery, tap into the original headlight plug, and install the HID bulbs and ballasts. :)
  4. May 8, 2010 at 8:17 AM
    emglishe30
    NJ
    01 2WD Taco 2.4
    Sweet thats what I thought. What bulb type do I get?
  5. May 8, 2010 at 8:26 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
  6. May 8, 2010 at 4:43 PM
    emglishe30
    NJ
    01 2WD Taco 2.4
    not that i don't trust you but could I get someone else to confirm the bulb type for my 01 taco...
  7. May 8, 2010 at 8:06 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    ^actually, thats exactly what you are saying...why dont you go to sylvania.com and get your bulb type, or google, or bing, or any other readily available source to tell you what is in your trucks manual....
    quit being lazy...and why even post a question if you dont believe the correct answer you are given?!
    oh, and its a 9003, not an H4...or is it....:D
  8. May 8, 2010 at 8:46 PM
    emglishe30
    NJ
    01 2WD Taco 2.4
    Well the reason I ask for a confirmation is because I had already checked the Sylvania website and got this for the bulb type 9003/HB2. I took that info and went on to DDMTuning.com and could not find that specific bulb type. So I pretty much want to make sure I buy the right bulb so I don't have to go through any more hassles than I need to...
  9. May 8, 2010 at 8:48 PM
    blake1012
    blake1012 Go Braves!
    Chazz Michael Michaels
    Duluth, GA
    2003 ext cab. tacoma.
    8000k HID's, Weathertech Digital Fit floor liners, Rhino Lined bed, 16x8 TRD Ivan Stewart wheels, bull bar, step rails, Redline Tuning hood struts, low profile tool box
  10. May 8, 2010 at 9:21 PM
    got_titan
    got_titan Well-Known Member
    sevierville, tn
    2010 trd sport dc 4x4
    H4 is correct as bellis said
  11. May 8, 2010 at 9:25 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    HB2=9003=H4.... they are different names for the same bulb.
  12. May 8, 2010 at 10:19 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    wrong, its a 9003
  13. May 8, 2010 at 10:25 PM
    got_titan
    sevierville, tn
    ok, i just traded in my 01 dc for a 10 dc and used the same h4 hid lights that were in my 01 in my new 2010....
  14. May 8, 2010 at 10:27 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    this may be true, but OP will need confirmation from another before he believes this...:D
  15. May 8, 2010 at 11:06 PM
    DevL
    DevL Well-Known Member
    Will you have to do anything else? Depends on if you want your headlight to be legal, hard to ID as illegal, hard to prove as illegal, or illegal and dont care. Generally speaking most HIDs on a Tacoma, including all plug and plays, are illegal and easily identified as such.
  16. May 8, 2010 at 11:11 PM
    tacovic
    tacovic Well-Known Member
    MN/WI
    00 4x4 TRD
    stock for now
    you should do it the right way. there are no good plug and play kits. there is going to be glare and your going to piss off alot of people. you can do a retrofit for about the same price and it will be MUCH better than any PnP kits.
  17. May 9, 2010 at 8:36 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    driver mod
    apparently low post counts makes your info worthless, good job not believing the right answer.
  18. May 9, 2010 at 8:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    A 9003 is an H4.
  19. May 9, 2010 at 11:35 PM
    Viet2100
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    No, you cannot do a retrofit for the same price. $55 vs. $300+.
  20. May 10, 2010 at 7:46 AM
    tacovic
    MN/WI
    00 4x4 TRD
    stock for now
    PnP are only 55 bucks?
