Eating through carrier bearings
Discussion in 'Technical Chat' started by 03sasTACO, Nov 3, 2009.
  1. Nov 3, 2009 at 10:54 AM
    03sasTACO
    03sasTACO [OP] Member
    Ricky
    brevard
    SAS taco on 38's
    dunno what to do have had the truck lifted and on 38's for a little over a year but about a month ago i had to put a set of 35's on and since i have been through two carrier / center support bearings. its just chewing up the rubber. any suggestions?
  2. Nov 4, 2009 at 11:44 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Tom woods, search it. Good stuff.
  3. Nov 4, 2009 at 11:48 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'm running a High Angle Driveline setup using a Ford Super Duty carrier bearing and double-cardigan CV joint. Pretty much bulletproof.
  4. Nov 4, 2009 at 2:12 PM
    03sasTACO
    Ricky
    brevard
    SAS taco on 38's
    mjp do u have a pic of the set up?
    thanks afwrestler
  5. Nov 4, 2009 at 3:54 PM
    Afwrestler1986
    Johnstown, NY
    I see your location says Brevard, what state?
  6. Nov 4, 2009 at 6:53 PM
    03sasTACO
    Ricky
    brevard
    SAS taco on 38's
    florida, east coast
  7. Nov 4, 2009 at 7:03 PM
    mjp2
    NJ
    It requires a custom mount since the larger carrier bearing has different bolt spacing. Mine is lower than stock to clear the torque arm mount at full compression but is still high enough to make sure the driveshaft clears the driveshaft skidplate at full droop.
  8. Nov 4, 2009 at 7:08 PM
    03sasTACO
    Ricky
    brevard
    SAS taco on 38's
    dunno i cant figure it out. the only thing that i have changed is gone from 38's to 35's the driveshaft sholdnt have moved right? i took it to one of the shops and they said it could be the slip was sticking so i greased it up real good and still nothing. mad some new drop spacers to try and reduce the angle and still nothing. i will get some pics of it tomorrow and see if anyone can see anything wrong. thanks
  9. Mar 18, 2010 at 7:23 PM
    NEBULENCE
    NEBULENCE Member
    Donald
    New Orleans
    02 PreRunner SR5
    AEM Brute Force Intake and Rough Country 2.5 suspension lift and Westin Safari Bar with Hella Lights.
    I am having the same problem with my 02 Taco. The first bearing went bad at 82000 miles . The dealer would only change the whole drive shaft assembly so I did that 20000 miles or so later and it went bad again, all I did was put different rims on it and kept the stock tires and now i have a 2.5 lift on it to fix clearance issues while turning. I don't know what to do with this carrier bearing issue. THE NOISE IT CREATES IS DRIVING ME CRAZY...
  10. Mar 22, 2010 at 6:44 PM
    intense
    intense Well-Known Member
    Georgia
    TRD OFF ROAD '07
    ASE Dry, Carbon filter removed, Grillcraft, 5100's. Low Pro Ameriweld box black powder. Tint / Vent Visors. Textured Black skid plate. Husky Liners. Design Seat Covers
    installed 5100's set front on 1.75 at 52K, truck has 60K and had to replace both front bearing hubs left was brownish and right was starting brown, you could hear the left one and a tech said 2nd gen were notorious for wheel bearings, who knows ?
  11. Mar 23, 2010 at 5:00 PM
    NEBULENCE
    NEBULENCE Member
    Donald
    New Orleans
    02 PreRunner SR5
    hey i read your post .... you are going through bearings on the front spindles right , i had that problem with my 94 toyota p/u , front wheels were too wide and was causing the outer bearings on the front wheels to grind up
