eBay fog light kits for '08-'09-'10 Tacomas....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10taco, Sep 6, 2009.
  1. Nov 11, 2010 at 7:28 PM
    #181
    pinktaco808
    pinktaco808 Hot Steppa
    right checker ???
  2. Nov 11, 2010 at 7:56 PM
    #182
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    When you are doing the installation just keep in mind this, the battery will NEVER be connected directly to the ON/Off switch, it would melt it. The On/Off switch can't handle that amount of current flowing through it over a period of time. You could use a fuse to restrict the amount of current, but then you'll be able to turn on and off your foglights with the truck off, which is not a good idea.
    That is why the relay is there, so the on/off switch does not have to deal with that high amount of current from the battery.
    The switch will be receiving current from the fuse TAIL 10A (the one I used) when the switch is ON, it will allow that current to continue to flow to the relay. Once it reaches the relay, it "tells" the relay to send current from the battery to the foglights.
    NOTE: this way of wiring the foglights you will only be able to turn on the fog lights, when your headlights are ON.
    So in short
    positive battery terminal needs to be connected to relay NEVER directly to the on/off switch
    the On/Off switch should be powered from another source, preferably a fuse from the fuse box or a wire which only has power when the truck is turned on
  3. Nov 12, 2010 at 3:57 PM
    #183
    pinktaco808
    yes thanks man and the other directly to the battery right???
  4. Nov 12, 2010 at 3:59 PM
    #184
    pinktaco808
    also make sure too tell everyone to use the small add a fuse
  5. Nov 12, 2010 at 4:30 PM
    #185
    pinktaco808
    also do you connect the power last and the ground first???
  6. Nov 13, 2010 at 2:55 PM
    #186
    pinktaco808
    why does your fuse box look different???
  7. Nov 13, 2010 at 3:20 PM
    #187
    pinktaco808
    my fuse box looks exactly like this one
  8. Nov 13, 2010 at 3:54 PM
    #188
    pinktaco808
  9. Nov 13, 2010 at 7:36 PM
    #189
    epa4wd
    Eduardo
    2019 SR
    Its the fuse box inside the truck, not the one in the engine bay.
    Behind the little compartment door in the left side of the steering wheel.
    I would connect grounds first and power last.
  10. Nov 14, 2010 at 10:20 PM
    #190
    pinktaco808
    yeah just figured that out thanks man
  11. Nov 14, 2010 at 10:28 PM
    #191
    Truckn4life
    Truckn4life Well-Known Member
    Dan
    Iowa City
    09 Black 4x4 Reg Cab SR5
    Epa, i have seen this post evolve over many. You have done a GREAT job in a through and detailed writing. I hope you can piece it together into a single post or more like set of directions!
  12. Nov 15, 2010 at 3:40 AM
    #192
    epa4wd
    Eduardo
    2019 SR
    Thanks, when I get a chance I'll do that
  13. Nov 15, 2010 at 5:39 AM
    #193
    pinktaco808
    yay it done now woop woop post pic later
  14. Nov 15, 2010 at 7:40 AM
    #194
    epa4wd
    Eduardo
    2019 SR
    awesome!
  15. Dec 17, 2010 at 4:12 AM
    #195
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    thank god for this thread! helped me out so much lol...well anyway...put some piss yellow bulbs in it...the stock bulbs that came with the kit were horrible lol
  16. Dec 17, 2010 at 5:53 AM
    #196
    pinktaco808
    good pic showing your paint gloss
  17. Jan 5, 2011 at 8:24 PM
    #197
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    I am going to purchase this kit. Just a few questions, how do I connect the ebay wiring harness to the stock oem switch? Thanks.
    edit: EPA, first off, thank you. Second, all the wiring in your pics looks oem, is that how the wiring came, or did you wrap it all up like that? Also, the pic with the fog light by the battery, what is that connected to? Thanks.
  18. Jan 6, 2011 at 4:49 AM
    #198
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    There is a connector that plugs into oem switch and 4 pigtails that you get from the dealer. The 4 pigtails push into the connector then you connect wiring to them. There are part numbers for these somewhere in here, maybe in the first part of this thread. I need another set of these to connect my Hellas to the 2nd oem switch I have.
    Here are the part numbers..............
    Part Number for plug if you already have the switch: 90980-11090,
    Part Number for wires with pins that go in the plug: 82998-12340 4 required
    See post #5 in 1st page of this thread for wiring diagrams.
  19. Jan 7, 2011 at 8:52 PM
    #199
    drewskie
    Drew
    Burbank, CA.
    Thanks man. What about this kit, it looks as though it has an oem style switch that will fit in the factory slot. Also, it seems pretty much plu and play. i really dont want to splice any wires.
  20. Jan 11, 2011 at 5:37 PM
    #200
    Mt Taco
    Mt Taco Member
    Derek
    North Florida
    2010 Toyota 5 lug
    so far just 30 inch a/ts on 17s. 10 inch sub behind passenger seat.
    Does anyone know where I could order just the wiring harness? Ive emailed several ebay sellers but none have gotten back to me about just the harness, all want to sell with lights and switch. Problem is I already have both and would like to save a little money.
