eBay fog light kits for '08-'09-'10 Tacomas....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10taco, Sep 6, 2009.
  1. Sep 11, 2009 at 12:39 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    No wiring instructions are included in the kit. I wish I had taken pics of the wiring so I could make a diagram. If someone takes a pic of the wiring in thats included in the kit I can make a diagram of where I connected everything
  2. Sep 11, 2009 at 12:53 PM
    epa4wd
    Eduardo
    2019 SR
    The wiring comes divided in two parts
    The first part is the wiring that plugs to the foglights
    It has in one end two plugs for each foglight / bulb.
    On the other end you have a red (+) that has a white connector and a black (-) wire.
    You can see where I connected these on photo #7 of my first post:
    Black (-) wire connected to existing ground screw on driver's side fender
    Red (+) with white connector,wire was connected to the second part of the included wiring.
    The picture is right behind the drivers side headlight between the fender and the battery, red arrows point to the wires mentioned above.
    The Second part of the wiring
    The second part of the wiring has the following:
    Red (+) with white connector coming from the relay - plugs to the white connector of the first part of the wiring.
    WHITE (+) WITH INLINE FUSE, coming from the relay - connect this to the battery's positive terminal, ( Pic1 , Pic2 )
    Now the RELAY has four wires, (2 already mentioned above) my relay is behind the driver's side kick panel:
    (I placed the relay inside the cabin so I would have the lowest amount of wires possible going trough the firewall, (12V from battery to relay, 12V that returns from the relay to the foglights ) )
    [RELAY] wires:
    Black (-) connected to screw behind driver's side kick panel, (its the screw that holds in place a metal frame in which the kick panel snaps in to.)
    WHITE (+) with fuse, this is the one you connected to the battery
    Red (+) this is the one with the white plug that connected to the first part of the wiring
    YELLOW goes to the On/Off switch
    [/RELAY]
    Last wire to connect is a thin red wire with white/gray connector, this one goes to the fusebox, I connected it to the dash illumination fuse.
    IF YOU WANT TO USE OEM SWITCH:
    Included switch connector has:
    RED connect to 1 (oem switch diagram on first page)
    YELLOW connect to 4 (oem switch diagram on first page)
    RED connect to 3 (oem switch diagram on first page)
    BLACK connect to 2 (oem switch diagram on first page)
  3. Sep 11, 2009 at 1:26 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Thanks for the help. Rep on the way.:thumbsup:
  4. Sep 11, 2009 at 5:57 PM
    10taco
    10taco [OP] Well-Known Member
    Massachusetts
    '23 4X4 DCSB V6 AT SR5/SX MGM
    EPA, my lights are on the way (same vendor you used). If any type of diagrams arrive with the kit (ad said no instructions included) I will get it posted. It will be my $0.02 addition to this excellent post! ;)
  5. Sep 11, 2009 at 8:23 PM
    epa4wd
    Eduardo
    2019 SR
    Thanks!, if possible take a pic of the wiring, each plug, because I dont remember exactly the colors for each wire, so I can update the info I posted.
  6. Sep 11, 2009 at 10:01 PM
    BPachom
    BPachom Well-Known Member
    Long Island
    09 Tacoma SR5, 4cyl 4X4, Black
    Access roll-up tonneau cover, Factory radio W/Sirius, Tailgate clamp, HID head lights, Stainless nerf bars.
    Unfortunately, my Tacoma did not come with the factory fog lights as well and I will be purchasing and installing aftermarket ones soon. Had a question on how to remove the grill/cover from the bumper where the fog lights mount?
    Kndgrtn likes this.
  7. Sep 12, 2009 at 8:08 AM
    epa4wd
    Eduardo
    2019 SR
    Simply push them from the back, do it carefully so you don't scratch the bumper
  8. Sep 12, 2009 at 12:29 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I've installed the same kit on my '09 base....so I can help some if needed. ;)
  9. Sep 12, 2009 at 1:45 PM
    BPachom
    Long Island
    I am surprised that there would not be anything (clips, screws, ect) to secure the grills/plug to the bumper that to remove them, just simply push on them.
    What is your input?
  10. Sep 12, 2009 at 1:48 PM
    epa4wd
    Eduardo
    2019 SR
    They snap in to the bumper, there are two round tabs on each side the fog light that keep them from going towards the front once they are in place. Then there is a tab behind the foglight with an adjustable knob for alignment, this also snaps in to place in the bumper. They will not fall. One of my foglights has a little play, very very very little not enough to bother me. If you have problem snapping them in place, play with the adjustable knob behind the foglight.
    Same thing with the covers they are just snapped in place, I think they have three tabs.
  11. Sep 12, 2009 at 2:40 PM
    BPachom
    Long Island
    That makes sense. Very helpful, thank you!
  12. Sep 12, 2009 at 6:12 PM
    Plain Jane Taco
    USA
    They fit into the bumper exactly like the OE lamps do. If installed correctly they will not fall out.
    No different than the actual stock lamps that I checked out on my local dealer's lot before deciding to go with these. ;)
  13. Sep 13, 2009 at 9:28 AM
    BPachom
    Long Island
    Thank you. Will have to buy a set soon and will do the install.
  14. Sep 13, 2009 at 10:56 AM
    NuovoTech
    NuovoTech Well-Known Member
    Upper Left Corner
    09 Tacoma 4x2
    Since a lot of us do not live in foggy regions, what do most here use fog lites for...maybe as Daylite Running Lites? I live in Seattle, we do not get much fog here. :D
  15. Sep 13, 2009 at 11:06 AM
    #35
    epa4wd
    Eduardo
    2019 SR
    I rarely use them, I install them mostly for looks, but when I do use them its for dark back roads with no lightning.
  16. Sep 14, 2009 at 9:11 AM
    #36
    NAAC3TACO
    2014 SR5 DCLB 4x4
    +1. I can't stand the look of those black plastic covers. I also like fog lights on dark roads when it snows. The headlights just light up the snow, but fogs will light up the road.
  17. Sep 14, 2009 at 11:22 AM
    #37
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    What type of bulb came in the e-bay kit?
  18. Sep 15, 2009 at 2:10 PM
    #38
    Plain Jane Taco
    USA
    h10
  19. Sep 19, 2009 at 5:16 PM
    #39
    10taco
    Massachusetts
    I have also ordered the FJ Cruiser 'modded' Toyota OEM switch kit (switch, OEM connector plug & 4 pigtail leads to connect it to the harness) from TRDparts4u.com . Gonna get it installed early this week, will (hopefully) get some pics to post here.
    The eBay kit looks very good indeed. I examined the light housings and they look as good as OEM parts IMO. The harness looks almost OEM, it's that good. NO instructions included but with the input from the experts on this forum it looks like a piece of cake, can prob get it done in 90 mins or less. Got some nice wire harness anchors (thanks EPA4wd) to secure the harness from advance auto parts. Gonna make this installation look FACTORY! :D
    #39
  20. Sep 21, 2009 at 5:40 PM
    #40
    10taco
    Massachusetts
    These are the pics of the wiring harness included with my kit. In one pic is the entire harness; 2nd pic is a close-up of the switch/power/fuse end of the harness ('2nd half' of the harness); third pic is the included relay. I have already installed the lamps & the 'first' (lamp connectors) part of the harness; now I just need to install the 'second' part of the harness (switch/power/fuse). My questions: White wire (with maroon connector, connected to fuse) goes to 12V power, green connector (4 wires) goes to switch (it fits into the included switch), where does the red wire with white connector go to? :(
