eBay fog light kits for '08-'09-'10 Tacomas....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10taco, Sep 6, 2009.
  1. Nov 7, 2009 at 12:33 PM
    #81
    TritonDrew
    TritonDrew Member
    How did you guys feed the cable through the firewall? Coat hanger? Drill a hole? Do you have any pictures? Thanks.
  2. Nov 7, 2009 at 1:37 PM
    #82
    10taco
    10taco [OP] Well-Known Member
    Massachusetts
    '23 4X4 DCSB V6 AT SR5/SX MGM
    ...Look for the large bundle of wires that feed through the firewall (driver's side of firewall); there is a rubber grommet that seals this access point; on this grommet near the lower passenger's side is a nipple, about one-quarter-inch in diameter. I simply cut the end off (it is sealed on the engine side) and fed my wires through there. I later sealed it back up with a zip tie, around the wires I fed through.:D
  3. Nov 7, 2009 at 1:49 PM
    #83
    TritonDrew
    TritonDrew Member
    Thanks! Got it!
  4. Nov 7, 2009 at 2:17 PM
    #84
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    No pics. I use a coat hanger then made it larger with a punch.
  5. Nov 11, 2009 at 8:37 AM
    #85
    cormchar
    cormchar Member
    #85
  6. Nov 11, 2009 at 8:51 AM
    #86
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    #86
  7. Nov 11, 2009 at 8:59 AM
    #87
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    [/url]
    Yes & yes........but use the oem switch.[/quote]
    Yea, the switch that comes with the kit is junk. Good advice.
    #87
  8. Nov 11, 2009 at 3:26 PM
    #88
    BPachom
    BPachom Well-Known Member
    Long Island
    09 Tacoma SR5, 4cyl 4X4, Black
    Access roll-up tonneau cover, Factory radio W/Sirius, Tailgate clamp, HID head lights, Stainless nerf bars.
    The one on Ebay is very similar to what I installed in my truck, and like the other members stated, buy an OEM fog light switch. Which can also be found on Ebay for about $20. The factory switch installation location is the top set of three blanks on the dash (left of the steering wheel), the actual position for the switch is the first blank on the left.
    Hope this helps.
    #88
  9. Nov 11, 2009 at 4:08 PM
    #89
    cormchar
    cormchar Member
    perfect, thanks guys.
  10. Nov 19, 2009 at 7:32 PM
    #90
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    to epa4w: thank you very much for the explanations.
    Today and yesterday I installed the fog light kit, the same that most of ppl here used. It was not that easy to do, but finally I have all the wiring installed. Now I have to wait for my toyota switch to arrive (surely tomorrow). I'm pretty sure that all will work well, I don't think I would have done it if it was not for this post as a guide.
    I used the add-a-circuit also in the fuse box so I would not tap into the existing wires. For the ppl who want to install the switch in the upper 3 slots, you don't have to remove the dash, just lot of patience (that worked for me).
  11. Nov 19, 2009 at 8:38 PM
    #91
    BPachom
    Long Island
    Congrats! :cheers:
    We also find this site VERY helpful with this topic and everything else too!
    I used the corner edge of a small (1 inch) puddy knife to remove the blank from the dash and the OEM fog light switch fit perfect (insert from the front) without removing the dash like you said.
  12. Nov 20, 2009 at 2:23 AM
    #92
    Tacoma_SR5
    Tacoma_SR5 Well-Known Member
    Canada
    07 Tacoma SR5 Double Cab
    #92
  13. Nov 20, 2009 at 6:20 PM
    #93
    rockinray
    rockinray Well-Known Member
    Ray
    Halifax
    '09 Speedway Blue Taco
    Hood protector,window vents, Xtang trifold tonneau cover, Pioneer AVIC F700BT deck with Sirius and rear view camera, Pioneer 6.5" speakers in rear doors with custom made grills, Inverter inside console with outlets on rear of console, LED lights in cupholder and under climate controls, OEM style driving lights, Westin Stainless Steel Tube steps.
    WOW. I called the dealer today to see if they had one in stock and I am not sure what kind of drugs he was on he gave me a price of $201 for the switch and mentioned something about the sterring column. Any ideas what he was talking about or what he was on?
    #93
  14. Nov 24, 2009 at 1:31 PM
    #94
    cormchar
    cormchar Member
    #94
  15. Nov 24, 2009 at 1:38 PM
    #95
    NAAC3TACO
    2014 SR5 DCLB 4x4
    That kit comes with 9005 bulbs. The Tacomas use 9145 bulbs. You could swap connectors at the bulb and they should work fine. Maybe you could avoid the connector swap if 9145s will fit in the same place as 9005s. The bulbs are similar , but that doesn't mean they are interchangeable.
    This kit mentioned earlier in this thread is the one I used and it came with 9145s.
    http://www.makotoautotrends.com/pro...11181&osCsid=df2573912055adab150bdfbc029d47ec
    #95
  16. Nov 24, 2009 at 3:34 PM
    #96
    supralight
    Dan
    Earth
    proof that I did it. Thanks to everyone who helped here. My installation has given very professional results and I am happy!
  17. Nov 24, 2009 at 4:09 PM
    #97
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Nice job!
  18. Nov 24, 2009 at 5:48 PM
    #98
    newfie8
    newfie8 Well-Known Member
    newfoundland
    09 tacoma
    Tinted windows all around. Fog lights. Intermittent wiper switch. Skid plate. Extra D rings. Grillcraft. Color matched grill. Hella 500ff HID behind grillcraft. Rcbs204 Lighting. 5100's up front. 265/75/16 Duratracs.Firestone riderites. Bora Wheel spacers. Tinted tails. De badged. Blacked out rims.
    LMAO! Something about that stuck me really funny..
  19. Nov 24, 2009 at 6:36 PM
    #99
    06lttaco
    06lttaco Well-Known Member
    California
    06 trd sport
    donahoes, allied spindle, camburg arm, bhlm, debadged, 09 smoked tails, eclipse double-din, thorley long tubes, wet okeles, weathertech mats, gaylord tonneau, satoshi grill
    can you buy these kits without all the wiring, bulbs etc.? i just want the black housing to install in the factory location, and since i run hids in the fogs, i don't need the other stuff that comes with it
  20. Nov 29, 2009 at 4:16 PM
    #100
    BPachom
    Long Island
    06lttaco,
    I have not seen just the lights for sale, only as a kit.
