eBay fog light kits for '08-'09-'10 Tacomas....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10taco, Sep 6, 2009.
  1. Nov 11, 2010 at 4:59 PM
    #161
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    No bracket is needed, the fogs should snap in to the bumper after you remove the blanks from the bumper.
    I'm guessing one ground is for the relay the second is for the fog lights bulb
    Maybe laying out the wires on the ground and posting a pic could help a bit to figure everything out
  2. Nov 11, 2010 at 5:26 PM
    #162
    pinktaco808
    pinktaco808 Hot Steppa
    well other people done this sooo help
  3. Nov 11, 2010 at 5:32 PM
    #163
    epa4wd
    Eduardo
    2019 SR
    If I had to guess I would say white is 12V Battery, and red ignition +12V, but I would need better pics of the relay and connectors tough.
  4. Nov 11, 2010 at 5:35 PM
    #164
    pinktaco808
    no no there 2 black and 2 red????just trying to figure out where the red wire without the fuse connects too
  5. Nov 11, 2010 at 5:40 PM
    #165
    epa4wd
    Eduardo
    2019 SR
    If those are the only wires then...
    if the fuse on the red wire is small that one is for +12V accessory
    and the other red 12V battery (by small I mean around 10A)
    If there are more loose wires, then I would need to see it
  6. Nov 11, 2010 at 5:54 PM
    #166
    pinktaco808
    just the 2 black wires. so you gotta tap into the ignition system??? got a diagram???? do i have to hook that up??i just want to be able to turn it on with a switch
  7. Nov 11, 2010 at 5:55 PM
    #167
    epa4wd
    Eduardo
    2019 SR
    No by ignition I mean, any fuse that has current only when your truck is ON, for example the fuse for dash lightning, power windows, etc etc
  8. Nov 11, 2010 at 6:02 PM
    #168
    pinktaco808
    do i have to hook that up??? if soo any suggestion with picsss
  9. Nov 11, 2010 at 6:06 PM
    #169
    epa4wd
    Eduardo
    2019 SR
    What I did is I bought an "add a fuse" which is available at any autopart, it basically splits a fuse slot in two. I used it in the Illumination Fuse Slot, in the diagram its marked as TAIL 10A
    This is a pic of the add a fuse installed as mentioned above
  10. Nov 11, 2010 at 6:18 PM
    #170
    epa4wd
    Eduardo
    2019 SR
    Some questions:
    The RED wire WITHOUT a fuse, does it go straight to the relay?
    The RED wire WITH a fuse where does it lead to, to a plug? relay?
    From your picture above I'm assuming the following:
    The red wire I see coming from the fuse looks small, which leads me to think it will not be carrying high current, therefore that wire should be tapped to a fuse which only has power when the truck is ON, (I'm guessing that wire is probably feeding current to the ON/Off switch, which when it is ON, continues to flow that current to the relay)
    The red wire I see coming from the relay is thicker, if there are not any other loose wires then this one is probably the one that should be connected straight to the battery (reason why is thicker). I recommend that you add a fuse to this wire (25A-30A)
  11. Nov 11, 2010 at 6:34 PM
    #171
    pinktaco808
    no this one goes straight to the switch
    Relay box
  12. Nov 11, 2010 at 6:38 PM
    #172
    epa4wd
    Eduardo
    2019 SR
    Then the red without a fuse should go to the fuse box and tapped into a fuse that only has power when the truck is ON
    the Red with fuse should go to the battery, Im guessing the fuse is around 20A
    I find it kind of weird cause the wire with the fuse looks thin compared to the others.
    From your answer looks like your wiring is similar to this diagram, where
    Battery terminal from the right goes to the battery
    Battery terminal from the left goes, to a fuse that only has power with the truck on
  13. Nov 11, 2010 at 7:10 PM
    #173
    pinktaco808
    dammm exact;y man thanks, that the one. just making sure. where did you get that diagram from???
  14. Nov 11, 2010 at 7:11 PM
    #174
    pinktaco808
    so i need that add a fuse thing right???? does radio shcka carry what the name of that part
  15. Nov 11, 2010 at 7:11 PM
    #175
    epa4wd
    Eduardo
    2019 SR
  16. Nov 11, 2010 at 7:17 PM
    #176
    pinktaco808
    what the name of the add a fuse or can i just extend the wire so it can hook up to the main battery terminal
  17. Nov 11, 2010 at 7:21 PM
    #177
    epa4wd
    Eduardo
    2019 SR
    Its called exactly like that an "add a fuse"
    Well, its pretty much up to you, you have a couple of choices
    you could tap that wire without the "add a fuse" to any wire that has power when the truck is On, for example the positive wire that lights up other switches from the dash etc etc.
    or you could buy the "add a fuse" and use it in the fuse that is marked as TAIL 10A (thats the one I used)
  18. Nov 11, 2010 at 7:23 PM
    #178
    epa4wd
    Eduardo
    2019 SR
    No that red wire (the one that does not have a fuse), should NOT be hooked directly to the battery.
    The only one that will be connected directly to the Battery is the red wire that already has an fuse in it.
  19. Nov 11, 2010 at 7:24 PM
    #179
    pinktaco808
    who sells it
  20. Nov 11, 2010 at 7:27 PM
    #180
    epa4wd
    Eduardo
    2019 SR
    Any pepboys, autozone or similar autopart store has it.
    You'll also need a 10A fuse
