Ecgs bushing install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 3rdGen, Nov 16, 2017.
  1. Nov 16, 2017 at 12:47 PM
    3rdGen
    3rdGen [OP] Well-Known Member
    17Toco TRDSport 4X4
    Hood decal
    Thanks! To clarify, it's not the actual bushing but the seal for the carrier right? Probably dumb question
  2. Nov 16, 2017 at 12:55 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Use them and sell them!
    AZBACKCOUNTRY likes this.
  3. Nov 16, 2017 at 12:55 PM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    The PVC coupler is designed to assist with the seal only. It's the perfect size to drive it in uniformly.
    This is another good post about how everything should look, which I believe the poster corrected his error with the seal.
    https://www.tacomaworld.com/threads...l-leaking-diff-help-now-with-solution.499972/
    There are no dumb questions , there are like 10 people watching this thread that probably have the same question.
    If you go back to do it. Keep the questions coming.
  4. Nov 16, 2017 at 12:55 PM
    anthony250f
    Anthony
    San Diego, CA
    Just for the seal!!
  5. Nov 16, 2017 at 12:56 PM
    AZBACKCOUNTRY
    Doug
    This
    After it's done and the truck isn't vibrating. Report back :bananadance:
  6. Nov 16, 2017 at 1:21 PM
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    I had a Toyota master tech install mine. He jacked up the drivers side and left the passenger side grounded (obviously using jack stands for safety). He told me it keeps the fluid from leaking out and presents the bearing at a better angle to work on.
  7. Nov 16, 2017 at 2:34 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    quick question there is a lip on one side and not on the other (ecgs bushing) which side goes in and which side is out?
  8. Nov 16, 2017 at 2:46 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    The side with the steal lip goes out, your install too will drive, contact that steal lip as you tap it in.
  9. Nov 16, 2017 at 3:55 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    Cool, good info, need. To have mine installed, it's not vibrating, that I've noticed but an ounce of prevention....
  10. Nov 16, 2017 at 4:44 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    yeah i so need to get this done.
  11. Nov 16, 2017 at 5:49 PM
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    The key to using a prybar to get the cv axle out, is to pry with one arm, while sort of pulling on the axle with the other to help straighten it out so your not putting side load pressure on the c-clip and shaft (kind of trying to keep the axle centered while prying). Try that, and it should come right out without much fuss. I nearly gave up as well, until I realized what was happening with just prying; after that, it popped out pretty easily. I've since done a couple more in the same way.
  12. Nov 16, 2017 at 6:33 PM
    blackcloud08
    blackcloud08 Well-Known Member
    WNC
    Heading to ECGS tomorrow to get this done and they’re gonna see what they think is causing the howling differential as they’ve not had their hands on one to diagnose.
    Jaggerbub likes this.
  13. Nov 16, 2017 at 7:08 PM
    99superduty
    99superduty Well-Known Member
    2016 DCSB OR 4x4 OME LIFT W/886 and DAKARS 265/75/16 Duratracs C4 lo pro bumper
    17SandTaco likes this.
  14. Dec 13, 2018 at 11:57 AM
    SweatyBiscuit
    SweatyBiscuit Well-Known Member
    Paul
    Northern AZ
    2016 Taco TRD OR
    Katzkin leather, heated seats, Popnloc, bed lights, remote start, bhlm....
    I installed the bushing a few days ago. I installed a new seal with a seal driver. I didn’t like the way the driver fit the seal but I used it anyway. The next day I noticed the axle seal was leaking. I wiped it down and checked it the following morning. Definitely the cv axle seal. I figured I messed it up while installing it so I installed another seal with lots of grease and used a PVC coupler that fit perfect. I exercised more care the second time when installing a double check the seal was all the way in with equal spacing all around. That was two days ago. Today was the first time I drove freeway speeds and I noticed a leak after the drive.
    Is it normal for the front diff to leak a little after a seal and fluid change? I’m not sure what to do.
  15. Dec 13, 2018 at 12:43 PM
    #35
    kbp810
    Au Gres, MI
    2016 Tacoma TRD OR
    If it was just a very small amount, and you haven't seen any since, it could have just been some small little pools of oil on the shaft/baffles or just outside the seal.
    Otherwise, if it's still leaking, I would contemplate if perhaps you might have put the seal in backwards, or potentially damaged it while re-installing the axle shaft.
  16. Dec 13, 2018 at 1:37 PM
    #36
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    easy way to remove is pack dry ice in there wait an hour comes out with out a puller watched it done amazed me
  17. Dec 13, 2018 at 1:43 PM
    #37
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I just did mine today. I pray to the Tacoma God's that it doesn't leak or vibrate because I really don't want to mess with this again.
    What a disaster.
    lowtidejoe likes this.
  18. Dec 13, 2018 at 2:02 PM
    #38
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    To remove the cv I used a screw driver and a few swing of the sledge hammer and the assembly came out. Removing the bushing wasn't difficult besides aligning the tool where I broke the ring of the bushing but no other issues. Installing the new bushing was very painful. The a coupler of some type to hammer in the bushing would be ideal. Used a combination of impact sockets to hammer in... painful. With the limited space and tight fit took about 30 mins of beating to finally align the new busing flush. To install the CV took quite a bit more force but is easier to just smack the opposite CV shaft. The tolerance is significantly different almost 1/8" of slop in the needle bushing with absolute no slop with the ecg bushing.
    Mr-Paul likes this.
  19. Dec 13, 2018 at 3:48 PM
    #39
    crizq0
    crizq0 Well-Known Member
    Bay Area, CA
    2018 Tacoma TRD OR
    TBD
    I am not looking forward to doing this install.
    30min of hammering does not sound like fun.
  20. Dec 13, 2018 at 4:01 PM
    #40
    kbp810
    Au Gres, MI
    2016 Tacoma TRD OR
    It's usually not that bad. Putting the bushing in the freezer (or in some dry ice) first can help, as it will shrink it ever so slightly. A little grease around the bushing doesn't hurt either.
    okichewy1 likes this.
