ECGS bushing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Travis1209, Aug 11, 2017.
  1. Aug 11, 2017 at 5:54 PM
    Travis1209
    Travis1209 [OP] Well-Known Member
    Travis
    2011 TRD Offroad Double Cab SB
    I recently lifted my 2011 TRD OR SC SB. Developed a slight shudder at take-off. Also slight vibration while driving at 20 MPH. Put the truck in 4HI and the shudder/vibration goes away.
    Ordered the East Coast Gear Supply bushing, removal tool, and a CV seal.
    Looking for any tips, tricks, do's and dont's while performing the needle bearing removal, and bushing install.
    Thankyou!
  2. Aug 11, 2017 at 5:55 PM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Make sure to put some plastic or something behind the needle bearing when fishing the removal tool back there. Ask me how I know lol
    Unchained 5150 and Squidward like this.
  3. Aug 11, 2017 at 5:56 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Put the bushing in the freezer prior to install
    Reaper 4x4 and Fitz235 like this.
  4. Aug 11, 2017 at 5:57 PM
    Travis1209
    Travis
    How do you know?
    Im guessing to prevent dropping tools/parts into the diff? Haha
  5. Aug 11, 2017 at 5:57 PM
    Travis1209
    Travis
    Thankyou! Would of never thought of that one.
  6. Aug 11, 2017 at 6:01 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I am sure he will post the link so stand by.
  7. Aug 11, 2017 at 6:02 PM
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Haha yes. I dropped the nut from the removal tool into the diff and got super lucky by fishing it out of the drain hole. If it drops in there and you can't get it out it means you gotta drop the whole thing and open it up
  8. Aug 11, 2017 at 6:03 PM
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
  9. Aug 11, 2017 at 6:18 PM
    Travis1209
    Travis
    Yea definitely want to avoid that one! Thankyou
    rollin904[QUOTED] likes this.
  10. Aug 11, 2017 at 6:30 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Several good write ups here about it. Read through some of those first. It's not too bad of a job.
  11. Aug 11, 2017 at 7:15 PM
    Travis1209
    Travis
    Yes i have searched and read through some write ups first. Couldnt find much. Reason being for creating this thread.
  12. Aug 11, 2017 at 7:21 PM
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    https://www.tacomaworld.com/threads/actual-write-up-of-ecgs-bushing-install.470116/
    and
    https://www.tacomaworld.com/threads...-and-adventures.362772/page-171#post-14019469
    Both helped me out a bit. I wish I had just taken the time to pull the whole spindle out of the way to make it easier. The axle was a pain in the ass to remove and reinstall thanks to the c-clip on it, so maybe others can suggest some tips for that. I used a pry bar to pop it out but it wasn't easy. Reinstalling was even more of a pain in the ass and I needed a helper. Good luck, I hated doing this bushing install but im glad it's over. 42k on my truck and no scoring on the axle after being lifted since purchase.
  13. Aug 11, 2017 at 7:23 PM
    Travis1209
    Travis
    Sweet, thanks Rollin
  14. Aug 11, 2017 at 9:30 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Atomic likes this.
  15. Aug 11, 2017 at 9:32 PM
    Travis1209
    Travis
  16. Aug 11, 2017 at 9:37 PM
    Braves95
    Braves95 Go Clemson Tigers
    David
    Central PA
    17 MGM TRD Off Road DCSB P&T 6MT
    Fab Fours Bumper Block Heater Dual Exhaust Flow Master Smittybilt 12k Winch Synthetic Rope Bed Mat Roof Rack Puddle Lights 17" Rockstar Wheels NittoTerra Grapplers Power TailGate Lock Tonneau Cover w/lights Mobtown sliders MT Remote Start Tinted Windows Front And Rear Camera BRC Competition Diff Breather Bed Step Weather tech Floor Mats TRD Pro Tail lights TRD MT Shift Knob ARB dual compressor URD short shifter Kings 2.5 OEM W/remote resi. Click adjuster.
    Now why would you do that?
  17. Aug 11, 2017 at 9:39 PM
    Travis1209
    Travis
    Ill take a guess, its going to shrink if its cold, so as long as its still cold when you try to install, it should fit a little easier
  18. Aug 11, 2017 at 9:39 PM
    Braves95
    David
    Central PA
    Awesome to know. Thanks.
  19. Aug 12, 2017 at 7:27 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Nailed it
  20. Aug 19, 2017 at 10:23 AM
    Travis1209
    Travis
    Finished the bushing install, everything went pretty smooth. Hardest part was popping the cv axle free. No scoring on the axle, put everything back together with a new seal as well.
    Needle bearing needles do fall out EASILY, those things almost got into the diff, but we had a rag to stop them from doing so, counted them, re counted them. Had all 34 outside of the diff. Pheeew.
    Still have a slight shudder. It is significantly less, id say about 60% less, but it is still noticeably there. At takeoff, a slight shudder. Thinking that my worn out cv axles may have a part in the vibration. The drivers side did have quite a bit of "play" in it while it was pulled. Could grab the shaft and the main housing and feel a lot of play. Thinking of ordering new shafts to see if that will help more with the vibration.
