"ECT is great!" meh.. Auto lsd and trac off is where its at.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheWildMan, Jul 16, 2024.
  1. Jul 17, 2024 at 12:17 PM
    MindlessCorpse
    MindlessCorpse Well-Known Member
    2020 Tacoma TRD sport
    Seems you might have been correct.
    Traction control normally indicates the brake system is used to slow the spinning wheel.
    Limited Slip differential is a mechanical function in the differential.
    Has Toyota has misled us on this?
  2. Jul 17, 2024 at 8:31 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    so do what you said in reverse, steady speed with ECT on and turn it off, result, it feels like the truck is slightly breaking
    Vmax540[QUOTED] likes this.
  3. Jul 17, 2024 at 9:10 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    No, they make it pretty clear what the system is.
  4. Jul 17, 2024 at 9:25 PM
    Grand Inquisitor
    Grand Inquisitor Well-Known Member
    Northern Calif
    2023 Tacoma TRD Off road
    It doesn't boost power at all, it delivers the power you have differently, you still have the same amount of power, nothing is added at all.
  5. Jul 17, 2024 at 9:35 PM
    Grand Inquisitor
    Northern Calif
    I love my TRD OR, tried all the goodies this last winter in the Sierra snow and mud :burnrubber: I didn't care for the fancy electronic stuff, just 4WD and go! LSD? Nah, slipping is a lot of the fun!
    on another note...
    I took a lot of LSD back in the 80's :alien: don't like beer and the pot was crap in the midwest back then :D
    MindlessCorpse likes this.
  6. Jul 18, 2024 at 6:49 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    My bad... you are correct, I was going by seat of pants feel, yesterday tried holding a steady gas pedal position while turning the ECT on and it does pick up speed (which still confuses me). My thought process told me all auto transmissions today are electronically controlled and turning it to the ON position would raise the rpm and make the shift point higher.
  7. Jul 18, 2024 at 8:53 AM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    They ARE electronically controlled, but it's still just a bunch of gears inside it. The computer just gets to pick the gears instead of it being done solely based on pump pressure or RPM. For anything to do what you were thinking, you would have to be able to vary the actual gear ratio outside of the spinning gears inside the transmission. I think that this is, at least in part, why most new automatics have so many gears. You have more opportunities to stay in the rev range that you (or the computer) want for the road speed that you are at.
  8. Jul 18, 2024 at 9:36 AM
    MindlessCorpse
    What is Limited slip differential?
    A limited-slip differential (LSD) is a type of differential gear train that allows its two output shafts to rotate at different speeds but limits the maximum difference between the two shafts. Limited-slip differentials are often known by the generic trademark Positraction, a brand name owned by General Motors and originally used for its Chevrolet branded vehicles.
    https://en.wikipedia.org/wiki/Limited-slip_differential
    What is Automotive Traction Control?
    A traction control system (TCS), is typically (but not necessarily) a secondary function of the electronic stability control (ESC) on production motor vehicles, designed to prevent loss of traction (i.e., wheelspin) of the driven road wheels. TCS is activated when throttle input and engine power and torque transfer are mismatched to the road surface conditions.
    https://en.wikipedia.org/wiki/Traction_control_system
    Now, that does make it pretty clear...
    so, back to my original query, has Toyota mis-led by calling this an Automatic Limited Slip Differential?
    if I were to surmise, a differential either IS limited Slip, or it is Not. If it is not (as listed) then it is a misleading sales ploy.
    Luchadoor likes this.
  9. Jul 18, 2024 at 9:59 AM
    Vmax540
    Chuck
    Clarion PA.
    See mine is one of the elusive CVT driven Tacoma's... :) So, bear with me... when turning on ECT does, the computer have the transmission drop into the next lower gear ?
  10. Jul 18, 2024 at 10:11 AM
    ShimStack
    Ben
    NC
    No. Because autoLSD is a branded term created by Toyota to indicate the limited slip behavior is a simulated limited slip diff using individual wheel braking across an open differential. They make it clear that's what the term means, they aren't hiding it.
    kahanabob likes this.
  11. Jul 18, 2024 at 11:24 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If you open the owner's manual and turn to the page that describes "AUTO LSD" (page 301 in my 2020 manual), you will see no mention of a limited slip differential or even a differential. I do however agree the name is a bit misleading/confusing, but I don't think it was intentional .
  12. Jul 18, 2024 at 11:29 AM
    Vinci
    Sarasota, FL
    '17 MGM Limited 4x4
    Not unless you are pressing the button at the same time as mashing the gas pedal and then forgetting about the second part.
