ECT Normal or Power and MPG (3.4L only)?
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Mar 1, 2010.
Power or Normal and MPG (3.4L only)
Poll closed Mar 31, 2010.
  1. Normal (15-17 MPG)
    11 vote(s)
    47.8%
  2. Normal (18-20 MPG)
    5 vote(s)
    21.7%
  3. Normal (20+ MPG)
    3 vote(s)
    13.0%
  4. Power (15-17 MPG)
    1 vote(s)
    4.3%
  5. Power (18-20 MPG)
    3 vote(s)
    13.0%
  6. Power (20+ MPG)
    0 vote(s)
    0.0%
  1. Mar 25, 2010 at 9:32 AM
    brg88tx
    brg88tx Well-Known Member
    anybody else tested this? thinking about giving it a try it it really helps mpg.
  2. Mar 25, 2010 at 5:10 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yep, It really does help! Just drive normally with it on and you will see a differece. Im still on my first tank with ECT On and I can or ready tell Im getting better mileage. :)
  3. Mar 25, 2010 at 6:10 PM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    wow, this is pretty cool. i'm gonna start using the ect mode!
  4. Mar 27, 2010 at 7:53 AM
    MTgirl
    Weesa
    Bob's secret mod lair
    Just got back from the gas station, 2nd fill up since using ECT regularly. Only 19.9 mpg this time. That is about average for me, mixed city and highway driving, and about 100 of those miles were put on while driving directly into a 16-18 mph wind.
  5. Apr 2, 2010 at 1:23 PM
    Dogma
    Dogma Member
    Dogma
    Utah
    2004 Taco Double Cab
    none yet
    Have'nt noticed what my milage does ECT/no ECT, however I did get frustrated with shift points on a recent trip.
    Climbing a long hill on the Interstate at 60ish MPH, punch it to stay at 65 (shifts into 3rd), reach 67, fluff the throttle to stay at 67 (and maintain 3rd gear) then it shifts BACK INTO O/D, hill pulls speed down to 62, then repeat this process about four times. Very frustrating, tryed ECT, it helped but still shifting UP-down-UP-down-UP-down. Anyone find this to be a problem?
  6. Apr 2, 2010 at 1:37 PM
    MTgirl
    Weesa
    were you towing/hauling anything? that is what ECT is made for. it basically changes the limits of rpms that triggers OD to kick in.
    i've found that i can pull hills and pass vehicles on the interstate while keeping at a lower rpm with ECT on and OD rarely kicks in. this is all driving with nothing in tow or in the bed.
  7. Apr 2, 2010 at 3:07 PM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I found my truck did poorly climbing hill in 4th, slowing way down even when I punch it. Even slight hills. It has issues staying in 4th as you said. I check my spark plugs and they looked like the originals (w/ 90k + millage). I changed these and it runs great now. No jumping out of gears or slowing in 4th.
  8. Apr 2, 2010 at 4:15 PM
    Dogma
    Dogma Member
    Dogma
    Utah
    none yet
    Was'nt towing, or hauling more than a nights luggage. I keep up on my maintenance. I'm starting to wonder is something is out of calibration, my first thought was maybe the shift points could be changed in the computer.?.?.
    I'm goin to compare my mileage with the ECT just to seeif my results are the same as everyone else. It really doesnt make sense but, looks like it may be true.
  9. Apr 2, 2010 at 4:40 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    not going to lie im one of those guys that likes to hit the gas hard at stop lights and while on normal I averaged about 15.5 mpg, turned on the ect and got 14 =/
  10. Apr 5, 2010 at 4:52 PM
    SunDevilTacoma
    SunDevilTacoma Well-Known Member
    Doug
    Gilbert, AZ
    04 Wht Double Cab PreRunner
    Turn signal relocation, built in fog light conversion, 4" deck plate
    I have to admit i do get better mileage with it on. My last tank I got 321.5 miles on it when I filled up, and almost crossed the 20 mpg milestone.
  11. Apr 7, 2010 at 8:25 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    i drive ect power on all the time. last fill up (tonight) and i got 19 mpg :D
  12. Apr 7, 2010 at 10:12 PM
    Youngunner
    Youngunner Well-Known Member
    Yellowstone National Park
    2003 Tacoma
    The standard expedition setup...
    I really feel like a dumbass now for not knowing what the ect did!
  13. May 8, 2010 at 4:02 PM
    my6
    my6 Well-Known Member
    houston,texas
    04 prerunner 2wd non trd
    ok, i have played with both settings and have,nt really noticed much difference in mpg. i drive my 04 everyday at work with a good mix of highway and stop and go. i do prefer the ect/pwr setting due to the responsiveness though when getting on the freeway. my6
  14. May 8, 2010 at 10:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    ETC mode all the way baby! Even if it doesn't improve mpg, the shift points are just right for me. :D
  15. Jan 5, 2011 at 6:19 PM
    #35
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    Mine does the same thing, I just figured that it is just the way the it is and stopped worrying about it and got used to it. Although I would love to see it perform better.
