ECU App
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacom02, May 31, 2019.
  1. May 31, 2019 at 5:04 AM
    tacom02
    tacom02 [OP] guy with a truck
    Vance
    Colorado
    08 TRD Off-Road 4x4 4.0L manual
    3" Super lift 285/75R17 Toyo Open Country 17x9 Rims some lights in the bumper
    I've done a good bit of research on this subject but am just wondering if there is a chip or something I can plug into my ECU to just read the vitals and the rpms and such of my engine without buying a 500 dollar performance chip that doesn't work on our older trucks. (From what I have read, they don't do anything noticeable to the performance) I just want a monitoring system I can use an app with to keep things cheaper
  2. May 31, 2019 at 5:09 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    96 X-Cab 3.4l
    Money Pit
  3. May 31, 2019 at 5:19 AM
    tacom02
    Vance
    Colorado
  4. May 31, 2019 at 5:28 AM
    tacom02
    Vance
    Colorado
    FLBAdrian likes this.
  5. May 31, 2019 at 5:32 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    If you just want to display on your phone, get one of these. I have had one for 2 yrs and have tried it on Fords, Toyota, Dodge, and Chrysler.
    Download "Toque Lite" free software to make it work. You can upgrade to a fuller version of the software for like $25.00. I got the upgraded software after using the Lite version. Both are good.
    https://www.amazon.com/gp/product/B005NLQAHS/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
  6. May 31, 2019 at 5:36 AM
    tacom02
    Vance
    Colorado
    Glad to hear someone likes the product, I'll buy it this weekend and give it a test run with the lite software to start!
  7. May 31, 2019 at 5:44 AM
    FLBAdrian
    Adrian
    Hanford Ca,
    96 X-Cab 3.4l
    Money Pit
    That would work to for you, cheaper and you could use you’re phone like you wanted to. Both are good products. I have the scan gauge my self in my truck. And I have another one for when people need to read a code
    https://www.scantool.net/obdlink-mxwf/
    tacom02 [OP] and Wsidr1 like this.
  8. May 31, 2019 at 5:48 AM
    Wsidr1
    Indiana
    Scanguage is definitely a good product too. Everybody who has one seems to like them. Just depends on your budget and plan for it.
  9. May 31, 2019 at 5:50 AM
    tacom02
    Vance
    Colorado
    Well depending on how much i like torque lite, ill look into scangauge and the future, for now I just want to experiement with reading what my truck is doing. we all know 1st gens dont have many gauges in the dash
    cruiserguy and FLBAdrian like this.
  10. May 31, 2019 at 5:53 AM
    Wsidr1
    Indiana
    What I like about the Toque software is how I can configure the gauges that are displayed. You can pick data & gauge type and group whatever gauges you want on each screen. Then a swipe left to move to the next screen full of gauges. Very simple to set up too.
  11. May 31, 2019 at 5:55 AM
    tacom02
    Vance
    Colorado
    Perfect, that actually answers a question I was just going to try and found out! Does that apply with the lite software as well as the premium?
  12. May 31, 2019 at 5:56 AM
    Wsidr1
    Indiana
    I honestly can't remember what was on the Lite version vs full, but the upgrade is very cheap as I said, maybe $25...?
    FYI, my comments are based on Android version. Not sure about Apple.
  13. May 31, 2019 at 6:00 AM
    tacom02
    Vance
    Colorado
    Yeah I use android so this is perfect
  14. May 31, 2019 at 6:02 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    That's exactly what I use and it allows the vitals to be monitored. You'll be good with that OBD2 plug in for what you're looking to do right now
    tacom02 [OP] likes this.
  15. May 31, 2019 at 6:05 AM
    Wsidr1
    Indiana
    I just opened the Lite version on my phone. You can modify it some. It has the following gauges pre-loaded:
    Accel
    Timing Advance
    RPM
    Throttle
    Coolant
    Intake
    MAF
    Load
    MPG
    O2Sensor 1
    Speed
    Short Term Fuel Trim1
    Of course, depends on your model year truck (what sensors are onboard) as to how much of that works.
    cruiserguy likes this.
  16. May 31, 2019 at 8:30 AM
    tacom02
    Vance
    Colorado
    OK, very good to know thank you, i just purchased the part through Amazon and should get here tomorrow for me to test it out and see what happens! thanks for all the info
    Wsidr1 likes this.
  17. May 31, 2019 at 8:55 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I use torque and my only real complaint is the refresh rate is a bit slow. I do have quite a tablet screen full of guage though.
