ECU Tune and Failed Emissions Testing Experience
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PacoTheTaco303, Nov 27, 2023.
  1. Dec 2, 2023 at 8:36 PM
    #141
    rolot2
    rolot2 Well-Known Member
    Rolando
    Denver, CO
    2015 TRD OR DCSB
    Front: Extended Travel 2.5” King coilovers with/adjusters (Set at 3” lift) Rear: 2.0” King shocks with adjusters Icon RXT (Option 2) Pack Toyota TRD Cat-back exhaust AnytimeBackup Camera Anytime Front/Rear Camera RCI Sliders KB Voodoo Bed Rack Center Console Ram Mount
    Anyone have a recommendation for a specific OBD II reader to read the CVN/checksum ?
  2. Dec 2, 2023 at 8:48 PM
    #142
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Any obd2 reader will do. Depends on your disposal income.
    I just learned about this one. This one has a bi-directional interface, allows to test systems, reset, etc.
    https://www.amazon.com/dp/B0C3QQYQ1B?asc_item-id=amzn1.ideas.NHZL00NIDEPF
    I've been using OBD Fusion for about 7 years. This one will cost you about $30 if you buy Toyota specific PIDs. Otherwise the cost of a blue tooth obd2 adapter (~$15)
  3. Dec 2, 2023 at 9:56 PM
    #143
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    My brother in law learned this with his father's car (Chrysler 300) which hadn't been driven really in about 8 months. I suspect it might have needed a jump start at some point but not sure. Needed to be cycled for readiness as it failed the OBDII connection.
  4. Dec 3, 2023 at 9:00 AM
    #144
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    So historically CA has been the biggest nightmare on getting smogged. Surely someone in CA has either sold their truck private party in the last year (which requires the seller to get a smog test), works at a smog place or dealer and has had a tacoma smogged.
    Or anyone with a 16' in CA should be coming due in the next year.
    Any other real life experiences out there on smog results?
    Dealing with the smog referee can be a pain in the butt. Changing an ECU is a pain for most. Flashing your own ECU is a sketchy endeavor for most also.
  5. Dec 3, 2023 at 10:19 AM
    #145
    TacoZmtn
    TacoZmtn Well-Known Member
    2022 TRD Off Road LB
    OTT-6112’s~5160’s rxt's~ShmellFab Sliders
    Or even CO, theres gotta be more trucks goin through
  6. Dec 3, 2023 at 10:21 AM
    #146
    mauctopa
    mauctopa Well-Known Member
    :goingcrazy:I'm gonna add one stock ecu to my Christmas wish list
    vivid02 likes this.
  7. Dec 3, 2023 at 5:44 PM
    #147
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Thanks for the alert, update and supporting information. I am sure many will benefit from your experience, efforts and willingness to share.
    EDIT: post revised to reflect current 12-4-23 action by VFT.
    I am here in Colorado too with a family member who will soon face the same situation - a Tuned truck (2016 AT 04B04) due for emissions testing and needing to flash back to a OEM Stock tune that will show the proper CVN on the ECU. I am curious that a solution for this (the OEM Stock CVN for 04B04) has been found and successfully tested. I contacted VFT for the aforementioned Tune on 12-2-23 and they responded on 12-4-23 to me - others facing this issue should reach out to them also. I am hopeful they will release it to all Licensed Software Users. If in Colorado and all else fails reach out to (@MGMSangTaco) for his assistance.
    I too think our State has missed the boat in this circumstance. Unfortunately, we are just pawns in the game of life. Thank you again for your sharing of this unfortunate experience.
  8. Dec 3, 2023 at 5:51 PM
    #148
    TacoTunesday
    TacoTunesday Well-Known Member
    Tony
    If you download the most recent version of VFTuner, it should contain the correct 04B04 file. As Justin has said, check the date to make sure you're loading the correct stock tune file.
  9. Dec 3, 2023 at 5:53 PM
    #149
    GoldenBrew
    Golden, Colorado
    just downloaded (updated) it today - no change - still dated before 9/23. if you find it send it. thanks.
    VFT version 1.7.5.... the legacy version not the new wifi version. maybe that is the issue here?
  10. Dec 3, 2023 at 5:59 PM
    #150
    GoldenBrew
    Golden, Colorado
    just did that today from the VFT site - the "stock 04B04 file" was dated pre 9/23 not post 9/23. Will check again. Thanks.
  11. Dec 3, 2023 at 6:56 PM
    #151
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    yeah, we are still waitin for the update file
  12. Dec 3, 2023 at 7:52 PM
    #152
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
  13. Dec 3, 2023 at 9:23 PM
    #153
    CLVFL1255
    CLVFL1255 Active Member
    I vote sticky this thread
  14. Dec 4, 2023 at 7:23 AM
    #154
    GoldenBrew
    Golden, Colorado
    It would be nice for a confirmation on the file referenced in the post = that is does reflect the OEM CVN and does not brick.
  15. Dec 4, 2023 at 7:52 AM
    #155
    BernsTaco
    BernsTaco Well-Known Member
    21 Cement Tacoma TRD OR 6MT
  16. Dec 4, 2023 at 8:36 AM
    #156
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I can confirm the above.
  17. Dec 4, 2023 at 8:39 AM
    #157
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    So I am honestly confused at this point. Does this all mean that if you have a tune from any tune product and your state requires an emissions test to get a tag, you will need to have an unadulterated ECU on hand to swap out before you get the truck tested?
  18. Dec 4, 2023 at 8:47 AM
    #158
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    No, people are overreacting. You CAN swap the ECU, but that’s an expensive backup plan.
    You can either flash back to stock yourself (with correct laptop/dongle/software) or if you’re not comfortable doing that, a tuner can put you back.
    Everyone wanting a spare ECU is on the paranoid side or wants a “guaranteed” way to go back to stock.
  19. Dec 4, 2023 at 8:49 AM
    #159
    PacoTheTaco303
    PacoTheTaco303 [OP] Well-Known Member
    Colorado
    2016 White Tacoma TRD Off Road
    Kind of. The option to flash back to stock on your current ECU is an option. You don't need a spare. There are some caveats though.
    -The first is that this only applies if your state is looking at your ECU/CVN when they do their emissions test. Many states are not looking for this. Colorado wasn't looking until July of 2021. Do some research on your state's emissions test and you will know.
    -Second, is if the tune you have is CARB certified. If that is the case then your tuner should have provided you with a CARB EO#. You give that to the emissions tester and you can pass an emissions test with an altered ECU/CVN. Unfortunately at this moment, I do not believe any tune for the Tacoma is CARB certified. Yet!
  20. Dec 4, 2023 at 9:14 AM
    #160
    IronMaidenJapan
    IronMaidenJapan So old I fart dust
    Lizardville
    23 TRDOR
    Ok I’m late to the party, I’m in Arizona.(OTT tune and I like it)
    No idea when my truck will require emissions, however regardless of years going by I assume someone here in the land of lizards will still be available to revert?(If needed)Does it have to be the exact laptop/person to match the stock file to specific vin or is it a generic file name that’s easy to revert back to?
    I paid off the truck already so I guess if Arizona adopts the PITA program I’ll trade it in before I let the state scan it lol!!!!!
