Effect Low Psi On Mileage
Discussion in 'Wheels & Tires' started by Rich Swanner, Oct 20, 2007.
  1. Oct 20, 2007 at 11:19 PM
    Rich Swanner
    Rich Swanner [OP] Well-Known Member
    N.California
    2007 Black PreRunner DC V6 SR5 LB
    Leer 100R Shell NXT Tech Wax
    It got colder here and my tires dropeded 4 or 5PSI. My milage went from 20 to 18-18.5. Does that seem like a cause possibilty? I am running 31 PSI now on my Double Cab. The pressure was at 25-26PSI. I did not change driving habits.-Rich [​IMG]
  2. Oct 20, 2007 at 11:51 PM
    PatheticJoe
    PatheticJoe Well-Known Member
    Sacramento, CA
    07 Prerunner SR5 TRD Sport - Access Cab
  3. Oct 21, 2007 at 10:18 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    Tire pressure can definitely effect your mpg, I suggest running just a few psi under your tires max psi. I have BFGoodrich Allterrains and the max psi is 50. I usually run about 45, I've got about 3k on them and they are wearing even, however they have hardly worn at all though these things wear like iron.
  4. Oct 22, 2007 at 7:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I agree.... I experienced a similar increase with tire pressure/mpg.
    It hasn't been as noticable on other vehicles I drive - but on the tacoma it was. I was running at the recommended 29psi ever since I bought the truck back in March and I was consistantly getting 17.5-18.5mpg. Just about a month ago - I raised it up to 32psi and the first tank I got about 19.5mpg.
  5. Oct 22, 2007 at 10:50 AM
    Critter
    Critter Well-Known Member
    Alot!
