Effing front end/shake!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bsfilter, Mar 26, 2014.
  1. Mar 26, 2014 at 8:34 PM
    Bsfilter
    Bsfilter [OP] Well-Known Member
    Bob
    San Pedro, CA
    08 4.0 AC 2WD SR5 TRD OR/RT
    Picked up a nail in my front driver side tire and the tire guy fix it for me and while he was at it to rotate the tires and now I have a RIDICULOUS front end wobble! I was going to replace the shocks and tires anyway as it is time but I worry that this shaking crap may never leave again as I've read many horror stories on here about the dreaded front end wobble. Has anyone ever solved this problem properly and permanently? I have zero intention of throwing money down a rabbit hole here. Thanks for your time.....Bob
  2. Mar 26, 2014 at 8:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    balance the tires.
  3. Mar 26, 2014 at 8:57 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Yep. He probably forgot to balance that tire or a weight might have fallen off during the rotation. It happens.
  4. Mar 26, 2014 at 10:14 PM
    Bsfilter
    Bob
    San Pedro, CA
    I'm talking about the notorious Tacoma front wobble here. There used to be a sticky about this problem that was a thousand pages long but it's gone now. I've had a slight shake on this truck (08 access cab) since I bought it a few years ago but it went ballistic after the rotation. Truck has 80,000 miles now and it's time for shocks and tires anyway but I wanted to know if the actual shaking issue had ever been resolved. I remember it takes a hub centric balancer to balance the tires properly or it will wobble with brand new tires also. Some guys have had the wobble right off the showroom floor and THOSE are the guys I want to hear from to hear if and how they resolved that issue....
  5. Mar 27, 2014 at 5:05 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    x3. If all being equal and just rotating the tires made it worse, you may have an out of round wheel to begin with coupled now with worn tires. Try having it road force balance.
  6. Mar 27, 2014 at 5:43 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Some people have fixed the vibrations and some have not. Your situation with the immediate vibration after visiting the shop is probably like everyone else here is saying. Tire balance.
  7. Mar 27, 2014 at 7:05 AM
    LEX
    Houston, Texas
    100 Series LC
    Ok, start reading then..
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/99531-steering-wheel-shake.html
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/99531-steering-wheel-shake-2.html#post1910842
  8. Mar 27, 2014 at 11:32 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    Haweka adapter and road force balancing will solve your frustration.
  9. Mar 27, 2014 at 11:52 AM
    J4RR
    J4RR Well-Known Member
    The OC
    07 DC LB TRD SPORT 4X4
    It's probably a bad balance when they did the rotation. Other possibilities are warped brake rotors (the wobble would happen when braking) or bent wheels.
    I went through the front end wobble but was solved when I discovered that the brake rotors were warped and I had a couple bent wheels, I replaced with vented rotors and new wheels.
  10. Mar 27, 2014 at 2:40 PM
    Bsfilter
    Bob
    San Pedro, CA
    Thanks for the input gentlemen! I'll update in two weeks as I'm going to replace the shocks and struts with Bilstein 5100's and put on some new tires as well. Hopefully all goes well and there is no shimmy or shake when all is said and done.
    Btw...What is this Haweka adapter that was mentioned earlier?
    Thanks again.....Bob
