EFI & Oil Injection Cleaning Every 25K?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slimsdepot, Sep 24, 2008.
  1. Sep 24, 2008 at 9:10 AM
    slimsdepot
    slimsdepot [OP] slimsdepot.com
    SoCal
    08 PreRunner
    I got a notice in the mail with my statement that they recomend an electronic fuel and oil injection cleaning once every 25k or 2 years that costs $119.95.
    Now is this something that I will need? I have been doing the 5k services myself with Mobile 1 truck and suv 5w30 religiously. Any input would help...
  2. Sep 24, 2008 at 9:42 AM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    I ran nothing but Chevron (occasionally Shell) for 20 years in my old truck and never had to service the injectors. Just avoid junk gas and you’ll be good. Not sure what oil injection is though.
  3. Sep 24, 2008 at 9:45 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i say run good gas, and every once in a while, run a bottle of techron in the tank, and run some seafoam thru the brake booster line....you'll be good to go.
  4. Sep 24, 2008 at 12:41 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Also redline it once in awhile... how's it gunna gunk up at WOT? :p
  5. Sep 24, 2008 at 12:50 PM
    slimsdepot
    SoCal
    08 PreRunner
    is this seriously a good way to keep them from getting dirty?
  6. Sep 24, 2008 at 12:52 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    no not really, but it doesn't hurt either :D
  7. Sep 24, 2008 at 1:05 PM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    Nice!
    I put a bottle of STP fuel injector cleaner in the tank with every oil change (1st full tank after change). I did this on my previous truck which had nine years on it and no problems at all.
  8. Sep 24, 2008 at 2:04 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    to be honest I never use additives, usually cause more harm than good. I just try my best to run good gas (shell, Quik Trip, Cheveron), usually that's more than sufficent to last a long time. Pulling out the injectors for a good clean is always better... though 25k is way way way to soon imo. I'd venture more alone the lines of every 60k at min, more like 100k. But, that's just me.
    If you use crap like Arco... yea 25k is probably pushing the upper limit. Or if you buy gas at your local grocery store to "save a few bucks."
  9. Sep 24, 2008 at 4:07 PM
    slimsdepot
    SoCal
    08 PreRunner
    Now when you guys say run the best do you also mean 91 octane??? I run 87.
  10. Sep 24, 2008 at 4:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Great advise!
    Actually, it IS a good idea to run it up now and then. Get the injectors flowing near 100% and it will prevent them from gumming up down the line.
    87 is fine. Stay away from Arco, and no name fuels. Arco has a bad habbit of useing the bare minimum filtering requierments at their stations. QT is one of the best as they have 4 filtering stages at most of their stations.
  11. Sep 24, 2008 at 4:53 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    QT 87 octane is what I run. Usually the cheapest in town, That is when we can get gas.:eek:
  12. Sep 24, 2008 at 4:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ANother FYI about QT gasoline, is that use double the addatives as anyone else does. :)
  13. Sep 24, 2008 at 5:28 PM
    slimsdepot
    SoCal
    08 PreRunner
    What is QT? Is that a gas station in your town? My choices are Mobil, AMPM, Arco, Shell, Costco Wholesale(cheapest), and some others I cant think of right now. But I haven't heard of QT.
  14. Sep 24, 2008 at 5:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    QT= Quick Trip
    Am/PM = bad gas
    Arco = bad gass
    Costco is good. Mobil, Shell....
  15. Sep 24, 2008 at 7:12 PM
    SoCalTacoma
    SoCalTacoma Well-Known Member
    Its just a scam to make extra money for the dealership. Im a mechanic and we sell those all the time. Easy money for me though :D . The only thing i would recommend is a powersteering flush and brakeflush every 2 yrs.
  16. Sep 24, 2008 at 7:15 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    i ran some of that racing level NOS fuel treatment at NAPA. It works pretty good. definitley blew a little smoke heading out from 1dt to second. Just cleaned it out pretty desently
  17. Sep 24, 2008 at 7:45 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    QT is only in certain parts of the country, it's really starting to take off more in Arizona now than before... I think it's pretty much from Kansas City and west in certain areas. At any rate, one of the top tier stations, usually one of the cheapest (aside from arco which is one of the worst gas stations), and they have badass drinks! (of the non adult style).
