EGR Bugshield seems to rub?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by driven_, Aug 21, 2007.
  1. Aug 21, 2007 at 10:18 AM
    driven_
    driven_ [OP] Well, someone has to do it...
    Milwaukee, Wisconsin
    '16 Super White 4x4 DC LB TRD OR
    Nature dust.
    eh. so i recent got the EGR bugshield and installed it on my taco.
    anywho.
    after installing it.
    it appears to seem like its rubbing.
    anyone have an EGR bugshield?
    also does anyone know a way to prevent it from rubbing.
    sorry im still new to the automotive world.
  2. Aug 21, 2007 at 8:10 PM
    flyman767
    flyman767 Well-Known Member
    I have the same exact shield and absolutely no rubbing. Where does is appear to be rubbing? Underneath or on top? Are the screw anchors correctly aligned in the underneath mounting holes? Is the shield maybe warped and rubbing on top?
  3. Aug 21, 2007 at 8:17 PM
    driven_
    Nature dust.
    right at the edge of the hood where the plastic curves right from under the hood to the ouside.
    and i tried to pull it out as far as i could.
  4. Aug 21, 2007 at 8:31 PM
    flyman767
    If all the fasteners are down tight and assuming your hood is not misaligned or damaged; I would call the vendor where you purchased it and advise them of the situation. Have you noticed if the pre-drilled holes underneath the shield are aligned properly? I couldn't really tell from your pic.. but does the rt side where it's rubbing seem to be stretching tighter to the hood than the left side? If so, and the pre-drilled holes are aligned correctly, than it sounds like maybe you have a slightly warped shield.
  5. Aug 21, 2007 at 8:39 PM
    driven_
    Nature dust.
    yeah i'll go ask the guy about it. but thanks for helping
  6. Aug 21, 2007 at 8:46 PM
    flyman767
    No problem...let me know what you find out.
