Eibach coilovers with 5100s
Discussion in 'Suspension' started by 09Doright8126, Oct 27, 2009.
  1. Oct 27, 2009 at 10:59 AM
    09Doright8126
    09Doright8126 [OP] Well-Known Member
    Andrew
    Greenwood, SC
    '09 DC TRD Offroad Pyrite Prerunner
    Aires chrome bullbar, Wet Okole seat covers, 6" KC offroad Slimlites w/ covers, upper Grillecraft black w/ TRD emblem, Redline hood struts, URD TCAI w/ black wrap, URD MAF Sensor, NST pulleys, NST intake manifold spacer, Bilstein 5100s, Eibach coils painted red, painted red brake calipers, SST brake lines, debadged tailgate, window tint, bed mat, extra D-rings, Rear TSB, Tranny TSB, swaybar removed, DTLT headers, URD Y-pipe, Vibrant Resonator, MagnaFlow
    I've got (4) Bilstein 5100s and a set of Eibach coilovers coming my way... I can't wait to get them installed!
    My question is with leaving the 5100s at stock height I should get 1.6" lift from the setup w/ the coils so if I wanted to level out the rear all I would need to get would be a 1.5" rear AAL?
    Thanks in advance.
  2. Oct 27, 2009 at 11:06 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    You would still have some rake because the rear is a bit higher to begin with.
  3. Oct 27, 2009 at 11:23 AM
    geolink
    geolink Well-Known Member
    SILVER STATE
    09 DCLB MagGray TRD SPORT
    Weathertech mats and hood protector, RuffTuff seat covers, padded console, Redline Hood Struts, Snugtop canopy w/Thule Rack, TSB rear springs plus AAL, 5100's all around OME 885 front coils, LR UCA, Avid Step Bars, LT265/70R17 BFG AT on stock Sport Rims
    Correct. Suggest measure now on level surface.
    Also consider loads or no loads
  4. Oct 27, 2009 at 12:03 PM
    09Doright8126
    Andrew
    Greenwood, SC
    Will do... the rear decision will have to be made based upon exactly how much rake exists and taking in consideration my avg. normal load weights.
    Thanks guys.
  5. Oct 27, 2009 at 6:43 PM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    I am having the same installed with a 1.5" AAL. I have a topper, tow a boat, and sandbags in the bed for the winter. Without the AAL I would be pretty much level as it sits with just the topper. I still want 1.5" rake so the AAL it is.
