Eibach Lift Pictures
Discussion in 'Suspension' started by raswank, Oct 13, 2010.
  1. May 16, 2012 at 2:38 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Thanks Fabulous...Anyone else have experience with this option?
  2. May 16, 2012 at 2:54 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I have this setup. I am still on stock UCA's. My alignment is considered within spec, but I would love to decrease my positive camber closer to 0 in order to avoid uneven tire wear. I may throw some Light Racing UCA's on this summer.
    The setup drives excellent. No wanding sensation while driving.
  3. May 19, 2012 at 4:53 AM
    CanisLupus
    Stokesdale | NC
    For the guys with this setup, are you close to level or does it revert to factory-type rake? And if there is rake, is it ok to set the Bilstein's to 1.75'' with the Eibach's to level or is that loading the shock too high?
    Finally, is it necessary to get a 1/4'' spacer to eliminate Taco lean?
    Thanks a bunch for any help fellas,
  4. May 20, 2012 at 10:15 AM
    CanisLupus
    Stokesdale | NC
    Can anyone chime in on this?
  5. May 20, 2012 at 10:20 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    .85 is the max setting you can run the billies at with Eibach coils
    Yes on the spacer as the coils are the same length as each other and not side specific
  6. May 20, 2012 at 5:14 PM
    CanisLupus
    Stokesdale | NC
    So you're saying that there is a rake when you use this setup?
    Thanks, Matt
  7. May 20, 2012 at 5:19 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    There may be rake depending on how much you lift the rear
  8. May 20, 2012 at 5:30 PM
    OZ-T
    Peter North
    British Columbia
    Eibach / 5100's @ .85 will get you approx 2 1/2" up front , lift the rear according to how much rake you want
  9. May 20, 2012 at 5:36 PM
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
  10. May 20, 2012 at 5:43 PM
    Noslow100
    Josh
    VA
    08 SR5 4x4
    I have a little rake on my setup. About and inch but you cant really tell by looking at it. My suggestion is go for the full 3 inch lift cause you will want to max out the height. Im glad I did. Also get some light racing UCA's. Dont risk the alignment not coming in like it should and you wearing down tires way faster than it should. I ordered my LR UCA's from Fat Bob's garage and they were direct shipped from SPC. They are the newer ones with the spec ride bushings in them. win win. Install took my friend and I about 6 hours total.
  11. May 21, 2012 at 5:19 AM
    CanisLupus
    Stokesdale | NC
    Well, I already have Bilstein 5100's all around with the TSB AAL. With that in mind, if I drop my Bilstein's to 0.85'', put Eibach springs (with 1/4'' driver's spacer) and LR UCA's in front, with a Toytec 1.5'' AAL in the rear, is that at least close to level?
    Thanks a lot for the help guys, I appreciate it.
  12. May 21, 2012 at 9:38 AM
    OZ-T
    Peter North
    British Columbia
    Yes , close to level , you will get 2 1/2" lift front and 1 1/2" lift rear with that set up
  13. May 21, 2012 at 7:26 PM
    Hairy Taco
    North of Hell
    08 TRD
    I look level with this setup. My rake is in fact very close to 1 inch.
  14. May 21, 2012 at 7:28 PM
    Hairy Taco
    North of Hell
    08 TRD
    It looks very good IMO. A very small rake prevents the squat(nose up) look.
  15. May 24, 2012 at 10:42 AM
    #35
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Please explain how the ride is superior. Is it firmer, smoother, rougher??
  16. May 24, 2012 at 10:59 AM
    #36
    evh5150
    evh5150 Well-Known Member
    Eddie
    Auburn,Ma
    2010 D/C S/B V6 6 Speed
    Bilstein/5100 combo from Toytec. LR UCA's.1.5 AAL's Full audio upgrade.Pioneer 8400, JL Audio subs. All Boston Acoustic pro speakers, and a Kenwood XRS 5 amp. Grillcraft, Smittybuilt stainless steps. Debadged. Soon 17x8 ATX Ledge wheels w/285/70/17 BF Goodrich
    Here is mine with the Eibach/5100 combo assembled at Toytec for a full 3 inches up front. And I have the TSB in the back with a 1.5 AAL from Toyec
  17. May 24, 2012 at 12:57 PM
    #37
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    How much did they charge you for all that??
  18. May 24, 2012 at 1:17 PM
    #38
    Hairy Taco
    North of Hell
    08 TRD
    it is stiffer for sure. The front end doesn't compress as much with braking. I prefer it
