Eibach PRO TRUCK Coilover 2.0 Stage 2
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patdeezy, Jun 24, 2020.
  1. Mar 14, 2021 at 8:31 PM
    #321
    MtbRob80
    MtbRob80 Member
    Any One Running 285 70 17s on this set up? How do you like it ? Pics ?
  2. Mar 14, 2021 at 8:47 PM
    #322
    patdeezy
    patdeezy [OP] Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    I will be running that size tires. I'm just waiting for the wheels get in
    Gettin Lost and Hooper89 like this.
  3. Mar 18, 2021 at 3:43 PM
    #323
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    Tomorrow morning going to get the eibach stage 2 coilover lift kit, ECGS bushing, 2" rear blocks, CMC, and MAYBE a viper cut.... Still debating on the viper cut. It's a bit aggressive, but looks cool in my opinion.
    EXCITED.
  4. Mar 18, 2021 at 3:50 PM
    #324
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Why not do an AAL instead of a hockey puck in the back?
    71tattooguy and Gettin Lost like this.
  5. Mar 18, 2021 at 4:04 PM
    #325
    Gettin Lost
    Florida
    2021 TRDOR
    Because everyone knows that hockey is a manly sport... Duh :D
    Got the blocks free technically and it's what I have right now... I plan on replacing the full leaf packs later. An AAL still uses Toyotas leafs... And they're not great... I'd rather replace the full packs at once.
    This is my 5th Tacoma, I've had others with rear blocks, offroading them and all, with no issues. But it's not a long term thing on this build.
  6. Mar 18, 2021 at 4:15 PM
    #326
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Nice man
    Gettin Lost likes this.
  7. Mar 18, 2021 at 4:49 PM
    #327
    scottstrong89
    scottstrong89 AhsokaTaco
    Carlsbad | CA
    2021 Tacoma SR5 2.7L DCSB Black (Sold 6-2-21)
    Bilstien 5100s- front 2.5inches Bilstien 5011s - rear extended HeadStrong OffRoad progressive AAL Manga flow muffler Aftermarket Powder-Coated Black Tip BFG KO2s- 265/70/17 Method Wheels Double Standard 17” Prinsu Cab Rack w/ Plano Rife Cases Yakima Awning Tacoma_Twins Paracord Handles TRD Pro Grille w/ Raptor Lights Laminx Fog Light Vinyl Yellow Me-So Customs Flip Fob Me-So Customs Gas Hole AJT Designs Emblem Overlay Black Me-So Customs Method Wheel Caps Screen ProTech 3 Piece Protector Kit Bumper Shells Bumper Caps Black tttacodan Bed Stiffeners TRD Pro Skid Plate TVD Vynil Decals Chrome Delete Hondo Garage Mounts w/ Ram Mounts RCI Adjustable 12” Bed Rack RotoPax Lox Mounts RotoPax WaterPax & Storage Pack Yakima Skyrise RTT WaterPort Shower Baja Born OffRoad Rock Sliders XBull Recovery Boards Al Off-road Trailgate Panel ataco4x4 Grille Emblem Desert Armor Ultra4 Ditch Light Pods Cali Raised LED 40” Light Bar Cali Raised OEM Style Switches
    Post pics!
    Gettin Lost[QUOTED] likes this.
  8. Mar 18, 2021 at 5:08 PM
    #328
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Mine is on the truck. Seems ok but I’m gonna dial it down some more as its still a little high up front and I don't want to deal with the needle bearing atm. It does come with a wrench and a swaybar relocation bracket.
    The front is almost 1” higher than the rear so yeah that shit will be dialed down lol
  9. Mar 18, 2021 at 5:32 PM
    #329
    Gettin Lost
    Florida
    2021 TRDOR
    Definitely!
    scottstrong89[QUOTED] likes this.
  10. Mar 18, 2021 at 6:39 PM
    #330
    Hooper89
    I’m trying to adjust them down and these fuckers are seriously stuck. Anyone have suggestions for thread lube? Try a breaker bar maybe? I was hoping to adjust them w/o jacking it up in the fucking rain.
  11. Mar 19, 2021 at 6:24 AM
    #331
    AMarkham40
    AMarkham40 Well-Known Member
    Roanoke, Virginia
    2014 MGM DCSB TRD O/R
    I jack the corner I'm adjusting off the ground & use WD-40 as a thread lube. I also added a small pipe to the end of the adjuster for a little more leverage.
    Hooper89[QUOTED] likes this.
  12. Mar 19, 2021 at 7:12 AM
    #332
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Need to get the weight off the corner. You aren't going to be able to adjust pre-load with a heavy truck weighing down the coilover.
    Merling, AMarkham40 and scottstrong89 like this.
  13. Mar 19, 2021 at 11:01 AM
    #333
    Hooper89
    ok that worked for the passenger side but I had to go almost all the way down only 2-3 threads showing to get it level (no rear lift atm). Drivers side was horrendous needed cheater bar then the wrench broke theres about 3/4” threads still showing. Needs to go down about 1/4-1/2” still.Also the wrench broke near a brake line so I’m worried it might have hut it when the thing snapped off. Have to call eibach for a new wrench.
    cannot believe how much load these springs have over stock. Out of the box it was 2” over stock.
  14. Mar 19, 2021 at 11:23 AM
    #334
    AMarkham40
    Roanoke, Virginia
    I installed the Eibach coil-overs & rear shocks on my 2014 a couple days ago. I'm with you as I don't have a rear lift. I just wanted to level the truck with the option of being able to lift it later If I choose to go that route. With the passenger side coil-over all the way down I am level with the rear. I'm still playing with the drivers side to eliminate the "Taco lean". Right now I have about a half an inch of threads showing. When I first went to adjust the coil-overs with the weight off the front end I was surprised how much force it took. I then liberally applied WD-40 to the threads & top/bottom of the adjusting nut. Things went much smoother after that. Do you have the newest spanner wrench they offer?
    Also, when adjusting the coil-overs make sure to drive the truck a short distance working the wheel & brakes to get the front end to settle before taking a measurement.
  15. Mar 19, 2021 at 11:35 AM
    #335
    Hooper89
    Thats the wrench I broke. It is close still about 1/4” too much on drivers side. I may take it back to have the alignment tweaked a bit too once this is finished.
    My big takeaway is that if you want to run 33s without spending a lot these certainly have enough lift
    also still has bro lean
  16. Mar 19, 2021 at 12:17 PM
    #336
    patdeezy
    souLcaL
    I tried adjusting my coils with said wrench before too and I couldn’t get mine to budget at all. Sprayed some lube and used the pipe from another jack to use as leverage. I ended up just giving up. I’m 0.5” lower in the front from my rear, told myself it isn’t THAT much of diff to justify the extra work needed to adjust them at that moment lol
  17. Mar 19, 2021 at 12:19 PM
    #337
    patdeezy
    souLcaL
  18. Mar 19, 2021 at 2:54 PM
    #338
    Hooper89
    My front right also sounds like shit on big bumps so checking the torque on all of those bolts is my next project.
  19. Mar 19, 2021 at 7:48 PM
    #339
    Gettin Lost
    Florida
    2021 TRDOR
    Lift, CMC, ECGS bushing, and alignment completed today. Wheels and tires are next.
    Coilovers were raised 5 turns. Will let them settle and adjust again if needed, but with 5 turns up front and a 2" rear block, I'm pretty level I think.
    [​IMG] [​IMG]
    RCrumb, QwickC, JDPNW and 1 other person like this.
  20. Mar 19, 2021 at 8:16 PM
    #340
    patdeezy
    souLcaL
    Looks great bro!
