Eibach PRO TRUCK Coilover 2.0 Stage 2
Discussion in '3rd Gen. Tacomas (2016-2023)' started by patdeezy, Jun 24, 2020.
  1. Oct 4, 2022 at 9:59 PM
    #941
    turner850
    turner850 Active Member
    Just want to point out from my experience, Yes, they've done this since the first day I installed them and I thought it was pretty weird.. had a triple check my install and everything is torqued and correct.
    However, I have absolutely no other issues.. on gravel, roads and pavement they drive just like stock.. I climbed novice off-road trails all over Oregon and they have been great.
    It's just the dreaded speed bumps at Wal-Mart/target and just about every national park we visit. My wife hates it every time.
  2. Oct 4, 2022 at 10:19 PM
    #942
    turner850
    Tomorrow I am going to put the gopro above the wheel well to get a side shot of the shock and go 6mph over a speed bump and see if we can figure out whether its topping out or bottoming out.
  3. Oct 5, 2022 at 12:04 AM
    #943
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Did you email Eibach yet?
  4. Oct 5, 2022 at 2:20 AM
    #944
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    I have these on a 2022 4Runner, and experiencing the same issue with them topping out on rebound.
  5. Oct 5, 2022 at 10:02 AM
    #945
    alegerlotz
    alegerlotz Well-Known Member
    Los Angeles
    2017 Tacoma Limited 4x4
    Mine were about 1.5" of lift right out of the box. I did a bit of adjustment to compensate for "taco lean" but I didn't count turns to do that.
  6. Oct 5, 2022 at 11:01 AM
    #946
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
  7. Oct 5, 2022 at 11:28 AM
    #947
    turner850
    I received an email from Dave at eibach, they are awaiting a set of coilovers sent back from a customer with this issue to investigate.
    So hopefully we can get an answer to why they do this.
  8. Oct 5, 2022 at 2:48 PM
    #948
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Seems to be this an issue with incorrect oil weight or being under filled. The third option would be valving, but if that were the case I'd think it would be more wide spread. Option 4 would be shipping with the wrong springs...being oversprung.
  9. Oct 5, 2022 at 3:23 PM
    #949
    Sand_In_My_Taco
    NOR*CAL
    Yup my set will be on the way to Eibach shortly.
    Hopefully they can figure it out so everyone can have a superior product.
  10. Oct 5, 2022 at 5:22 PM
    #950
    Chief_CNMI
    Chief_CNMI Well-Known Member
    Bryan
    Saipan, Northern Mariana Islands
    2020 4x4 V6 SR5 White
    All lighting are led, wheels, tires, 5100 lift, pro grill, bed light, seat covers, door sill protectors.
    That's amazing about eibach!
    Speedfreak likes this.
  11. Oct 5, 2022 at 5:31 PM
    #951
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
    sooo i dont got a 3rd gen but find this interesting since i have the eibach 2.0 kit on my ranger and so far i havent seen or heard anyone with this issue yet on the ford side? is it on peoples newer kits or the older kits?
    just curious is all!
  12. Oct 5, 2022 at 7:00 PM
    #952
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Keep us updated :thumbsup:
  13. Oct 5, 2022 at 8:38 PM
    #953
    junkyarddogg
    junkyarddogg Well-Known Member
    New Jersey
    2021 TRD Off Road
    Does this issue also affect the stage 1’s?
  14. Oct 6, 2022 at 7:10 AM
    #954
    Chief_CNMI
    Bryan
    How do we contact? Like through email wise? Or go onto techsupport@eibach.com and call?
  15. Oct 6, 2022 at 7:29 AM
    #955
    Sand_In_My_Taco
    NOR*CAL
    It's in what you quoted lol.
    "For those who are experiencing this please feel free to reach out to Dave at techsupport@eibach.com and I will let him know about the concern. "
  16. Oct 6, 2022 at 7:31 AM
    #956
    Sand_In_My_Taco
    NOR*CAL
    I'll be shipping them out on Monday so hopefully they can take them apart and see what the issue is.
  17. Oct 10, 2022 at 1:58 AM
    #957
    Chief_CNMI
    Bryan
    People with the issue, does your coilovers also Squeak going over bumps, off roading etc? I've grease my JBA Uca multiple times. Squeak does not go away..
  18. Oct 10, 2022 at 6:08 AM
    #958
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    No, these were dead quiet for me.
    I did have a weird squeak for a little while, check your skid plates to make sure they are super tight.
  19. Oct 10, 2022 at 6:11 AM
    #959
    turner850
    No squeak
  20. Oct 10, 2022 at 6:49 AM
    #960
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I get a squeak from the sway bar, but only when both sides compress or extended together. This causes the sway bar to twist in the bushings causing the squeak. It was bad when I first installed and is barely noticeable now.
    I believe the issue is the relocation bracket. The factory bolt head sits proud above the surface when mounted to the frame and this causes more compression on the bushing when it is mounted.
    bulalo likes this.
