El Cheapo Heated Mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tsilliker, Oct 7, 2008.
  1. Dec 12, 2009 at 6:28 PM
    #221
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I got mine from a local windsheild shop for $40 a piece. They ordered them and had them in the next day. I think it was Bangwegner Glass (or something like that in South Carolina).
  2. Dec 12, 2009 at 8:24 PM
    #222
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Your profile says nothing. Where do you live ?
  3. Dec 13, 2009 at 8:58 AM
    #223
    sonjay
    sonjay Well-Known Member
    I'm not trying to sound like an ass or anything. I'm just trying to save others some money. You DO NOT need mastic to glue these on, any exterior grade silicone will work fine, our mirrors are mirrored both sides so mastic is not needed. The factory is glued with a pad adhesive nothing special and easy to scrape off, Second the larger element isn't necessarily any better, it is most likely less wattage because it is a bigger element, if it were high wattage it would melt the plastic around the outside of the mirror. My grip heaters will keep the mirrors dry in the rain. Also you still have to do the same exact process to install the mirror with all the same dis-assembly to get the plastic piece, still have to route the wires though the mirror assembly. I can see having a spare set of mirrors as good though, it sucks when they break!
    Heres the same kit I have on my truck! http://cgi.ebay.com/ebaymotors/ATV-..._Accessories?hash=item20ad9a7bc6#ht_691wt_941
  4. Dec 13, 2009 at 11:01 AM
    #224
    george3
    New Jersey
    WOW. I must have missed that link if it was posed B 4. That looks great. Everything included for $18. I paid that much for the switch alone and the Highlander switch was $60 to $120 from what I read. I would have definitely given this a lot of consideration. $ saved and everything included. Can't beat that with a stick.:D Do you need a relay with that or will the switch handle the amps ?:confused:
  5. Dec 13, 2009 at 11:31 AM
    #225
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    That's the same kit I used for $6 or so less. I didn't use the switch. It toggles between low and high, and I have mine wired for high with a different switch. Your lighted switch would be better since it's easy to know when you have it on, and remember to turn it off.
  6. Dec 13, 2009 at 11:41 AM
    #226
    george3
    New Jersey
    Man Tiger I admit to being blind. I didn't see all that stuff included in the OP. Oh well water under the bridge. I do like the switch it's a beauty and I don't have to wire a relay.;)
  7. Dec 14, 2009 at 9:26 AM
    #227
    sonjay
    I also used the Toyota switch in the OP. It has a light to tell you its on. Same as tiger, I wired mine to be on high. The switch I have handles the current without a relay. On a side note I see a lot of guys putting timed switches in. I thought about a timed switch, a couple of our new International trucks have timers on their mirrors at work, however I've noticed when driving long distances it seems that the damn timer has the mirror heat shut off and is fogged up every time you go to look in them! I've left my heaters on for hours with no ill effects!
  8. Dec 14, 2009 at 9:56 AM
    #228
    CraigTRD
    CraigTRD It's been a while
    Craig
    London, Ontario, Canada
    2023 Tacoma TRD Pro 6M
    Will have: 6" FabTech Lift, Custom rear leaf packs. Hockey Stick Canadian Flag Mod.
    I just found something here at work. It's like 10+ years old, and we were cleaning off some shelves....
    12V timer.
    I have the heated grips in at the motorcycle store, and I picked up the Toyota switch last year when I first read about this thread.
    I was just talking to a buddy, and he says that his Subaru doesn't have a timer. His heated mirrors are on as long as the vehicle is on. So I may wire this timer up, or I may end up just tying into the accessory position on the key.
  9. Dec 14, 2009 at 11:16 PM
    #229
    bk1
    bk1 Well-Known Member
    Lower Mainland, BC
    08 Tacoma TRD Sport
    ProComp Stage 2 6" lift, AAL, Heated Mirrors, DVD/NAV, Amp & Subs, Fog Light Mod, Rear Diff breather. WeatherTech Mats, Soft Tonneau Cover, 33" TrXus M/T, M8000 Winch & Bumper, CB, Rock/suspension Lighting and a whole lot more Soon to come rear Locker and more....
    Got my first dump of snow today/tonight.... mirrors worked GREAT.... and no timer :)
    One of my favorite mods
  10. Dec 16, 2009 at 7:56 PM
    #230
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Got my switch today. Now just waiting for my .110" terminals to show up. Couldn't find them at my local Car Quest and Radio Shack.
    Apparently, this is what an $80 switch looks like.
    [​IMG] [​IMG] [​IMG]
  11. Dec 16, 2009 at 8:07 PM
    #231
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    ^ mine is on its way. cost me $56 from trdparts4u.com. cheapest place i found it. the connector and "tacoma" colored bulb are on back order though. the 5 wires are being shipped with the switch. i can't wait to get everything.
  12. Dec 16, 2009 at 8:16 PM
    #232
    WATacoRider
    TRD Sport 4x4
    FFFUUUU could have saved $20 there. I thought it was $79 online too when I checked?
  13. Dec 16, 2009 at 8:22 PM
    #233
    griffin407c
    Upstate NY
    ^ CORRECTION. $56.01. haha. sorry man
  14. Dec 17, 2009 at 2:02 AM
    #234
    george3
    New Jersey
    Carquest part number TA484L, List $4.381, Net $3.245 Plus Tax, Total $3.48 in NJ. 12 per pack. Hope this helps someone. :D Call B 4 U go if it's not just down the block.
  15. Dec 17, 2009 at 3:35 AM
    #235
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    I guess I'm a little slow following this thread. What are these prices and part number for? (Maybe I'm having trouble with my vision........is there a floating decimal point?)
  16. Dec 17, 2009 at 5:35 AM
    #236
    2007TacBorla4X4
    2007TacBorla4X4 Well-Known Member
    Bob
    Jax, FL
    TRD Sport 4X4 Short Bed
    Borla cat back, K&N cold air, Silver star bulbs, Nerf bars,NEW BFG, Weather teck windows, Flash light on the drivers seat, TRD off Road ft tow hook, Rear driving lights on bumper, Weather teck windows & ft bug guard, 4X4 switch glows, Windows tinted 20% sun shade
    When you all get done with this mod you should post were you got the parts & the amount you spent & do one thread. I know the Grunts do all the WORK & everyone else gets the rewards. It sucks but its true........
  17. Dec 17, 2009 at 10:49 AM
    #237
    george3
    New Jersey
    This is what was on the bill. Bottom line $3.50 for the female electric connectors to go on the mirror. They are small not like the 1/4" ones I'm used to. I don't have them in front of me but the part number is TA484L.
  18. Dec 17, 2009 at 10:52 AM
    #238
    george3
    New Jersey
    That is probably a good idea. There is 3 or 4 ways to do this from $35 to a few hundred. A lot of options. A little confusing to say the least. :confused:
  19. Dec 29, 2009 at 6:43 PM
    #239
    WATacoRider
    TRD Sport 4x4
    Deleted to prevent confusion.
  20. Dec 29, 2009 at 8:27 PM
    #240
    WATacoRider
    TRD Sport 4x4
    deleted to prevent confusion.
