El Cheapo Heated Mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tsilliker, Oct 7, 2008.
  1. Jan 2, 2012 at 7:50 PM
    #381
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    Then would it be easier if I put the two mirrors in series bc I ran the two Wires from each mirror to the relay anyway. You think the mirrors will get hot enough?
  2. Jan 4, 2012 at 10:43 AM
    #382
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    I would leave them in parallel.
    I don't think you will tell any difference if they're in series vs. parallel. Yes there will be some reduction, but none that you will actually be able to feel. The amp draw we're dealing with is just not that much.
    Did you use the Toyota mirrors or the handlebar grip heaters?
    I would leave the Toyota ones the way they are. They were designed to be fed with 12 volts to begin with.
    If you used the handlebar ones, they should have included a 5 watt resistor. If not, let me know. I believe I should have one around (or someone else on here) that I'll freely ship out to you, or I can possibly get a PN for one from Radio shack that you can buy and install. I'm not at a user friendly computer to lookup right now. Just remember that it gets warm. It will have to be mounted in a safe manner, away from heat sensitive areas.
  3. Jan 5, 2012 at 8:26 PM
    #383
    BarefootBandit
    BarefootBandit Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    Anybody know where I could find similar pads but larger than what OP had used?
  4. Jan 6, 2012 at 6:08 AM
    #384
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i looked for a while and didn't come up with anything when i did mine. Although the pads are smaller than the entire mirror they heat up the entire mirror in about a minute and a half
  5. Jan 6, 2012 at 10:46 AM
    #385
    disc0monkey
    i got the ones like the OP on ebay.. guy is in poland but they get here fast.
    they might actually be a bit bigger than the OP's and they have adhesive already on them
    search mirror heat grid
  6. Jan 7, 2012 at 3:52 AM
    #386
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    Burco sells redi-heat grids that might work. I ordered the entire redi-cuts replacement mirrors for 2006 Sienna. They have stick-on grids on the back. I am sure they must be the same as the redi-heat grids.
  7. May 1, 2012 at 4:51 PM
    #387
    free
    free New Member
    montana and arizona
    07 dc sb 4x4 trd
    lots
  8. May 30, 2012 at 1:41 PM
    #388
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    for what are heated mirors used for?
  9. May 30, 2012 at 1:44 PM
    #389
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    to remove condensation and frost....
  10. Sep 23, 2012 at 9:16 AM
    #390
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    subbed
  11. Oct 17, 2012 at 5:49 PM
    #391
    Fightman80
    Fightman80 Well-Known Member
    Capreol Ontario Canada
    05 TRD DCLB Speedway Blue
    Tinted Tail lights, Nerb Bars, Tonneau Cover, Vent Visors, Hood Deflector, Foglight/highbeam mod, Custom homemade grill, Carbon Fibre Interior.
    This is ingenious!!!! I really want to do this.... just nervous that I'll melt the mirror housing in the oven.......
  12. Oct 17, 2012 at 8:36 PM
    #392
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    No need to use the oven, I just gently pried the mirror off.
    Shawn.
  13. Oct 17, 2012 at 8:39 PM
    #393
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    so you can ask dumb questions
  14. Oct 17, 2012 at 10:10 PM
    #394
    JLink
    Josh
    Ocean, NJ
    alright i finally broke down and ordered a set of handlebar heat pads today from Amazon.
    I've been trying to decide how I want them to be wired up.
    skimmed through some pages here and it looks like some people are against having them on for an extended period of time? I was thinking about wiring them so they are on anytime the defroster is on. If anyone feels that would not be a good idea please respond explaining why.
  15. Oct 18, 2012 at 12:23 AM
    #395
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    They might heat up too much, I'm guessing you don't need them too much when you're driving since the snow and rain will be hitting the front of the mirror housing so it will mostly be when you jump in your truck and the mirrors are iced over. Because of the heat issue I would not do it with the defroster because when it is cold outside, I'll run my heater with the defroster and the blower at the feet at least on low the entire time. You will need the defroster the entire time you are driving because the second you turn it off your windows will start fogging up (but I'm guessing you already know that).
    I may be wrong, but most cars with them stock should have timers on their mirror defrosters.
    Edit: Just saw that a 4runner has them tied to the defroster, but maybe the heating element on that is specifically made for the housing so it is safe :notsure:
  16. Oct 18, 2012 at 6:10 AM
    #396
    JLink
    Josh
    Ocean, NJ
    Might just wire them to a toggle switch in the coin pocket then. Unless anyone else chimes in
  17. Oct 18, 2012 at 6:24 AM
    #397
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Look into the highlander heated mirror switch. It has a timer built in, fits into the factory blanks with very little adjustment and matches the other dash switches. I believe it's timed for 15 minutes then automatically shuts off. I'm in the same boat and also came across this:
    http://www.wolstentech.com/products/timedelayrelay/basic-instructions.php
    I think that's a timer relay that will do the same thing, let power be on for a set amount of time, then shut the device off. You could then get any rocker switch that resets itself (momentary switch) to trigger the power to turn on and the relay will shut it off at whatever time interval you set. Look specifically at the TDR-M or TDR-MC relays.
  18. Oct 18, 2012 at 11:42 AM
    #398
    Drunknsloth
    Retribution
    South West
    Is there a way to turn these off before the time ends just in case?
  19. Oct 18, 2012 at 12:06 PM
    #399
    Pugga
    Massachusetts
    I was going to call the company when I got a minute because I've got a lot of questions about the setup.
    With the Highlander switch, just press the button again and they shut off.
  20. Oct 19, 2012 at 6:56 AM
    #400
    JLink
    Josh
    Ocean, NJ
    Screwed up typing on my phone but you can see what I wrote in the quote
