El Cheapo Heated Mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tsilliker, Oct 7, 2008.
  1. Oct 19, 2012 at 7:10 AM
    #401
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Once I get around to calling that company, I'll post back but it looks like that TDR-MC will do what you want. Something triggers it to turn on, and it automatically turns off after a pre-determined amount of time. I've got a list of projects in front of this one... :eek:
    Also, I believe Contura makes a momentary switch as well. I didn't see one that was laser etched with the heated mirror symbol but maybe you could get a blank one to aesthetically match the others? I'm kind of in the same boat in the sense that I'm switching everything over to Contura switches instead of the OEM ones.
  2. Oct 22, 2012 at 2:04 PM
    #402
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    OTRATTW can have custom laser etches.
  3. Oct 23, 2012 at 1:24 PM
    #403
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I just read up on their website and that relay will definitely work.. Tdr-p
    $29 is a whole lot of money for a relay though, but I guess it's cheaper than the highlander switch and atleast I won't have to worry about leaving the heaters on.
  4. Jan 9, 2013 at 4:06 AM
    #404
    CraigTRD
    CraigTRD It's been a while
    Craig
    London, Ontario, Canada
    2023 Tacoma TRD Pro 6M
    Will have: 6" FabTech Lift, Custom rear leaf packs. Hockey Stick Canadian Flag Mod.
    Bah, no. I didn't even do the second part. (I ordered everything, but haven't installed anything).
  5. Jan 12, 2013 at 10:13 PM
    #405
    RDNK TAZ
    RDNK TAZ Well-Known Member
    Chad
    Marion, SC
    '11 Silver Streak Mica DCSB TRD 2x4
    I'm gonna do this but plan on wiring them into the factory defrost switch.
  6. Jan 12, 2013 at 10:35 PM
    #406
    RDNK TAZ
    Chad
    Marion, SC
    Yeah, the climate control switch. I went into the dealership one day asking about an OEM mirror defrost switch. The guy told me they didn't have one and besides they were wired in through the control switch. I haven't had much time to do any more research on it but it sounds liget. Maybe there is a timer also, not sure. I like the idea because it keeps it stock looking and it frees up a spot that I can use for something else.
  7. Mar 29, 2013 at 5:15 PM
    #407
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    Did this tonight...this has to be probably one of the easiest mods I have ever done....smh...I was actually kind of intimidated, but I'll be damned if I didn't do both mirrors minus the wiring and removal and install on the truck, in roughly 10-15 min total...:thumbsup:
  8. Oct 4, 2013 at 9:26 AM
    #408
    JLink
    Josh
    Ocean, NJ
    Doing this over the weekend.. Thanks for the write up!
  9. Oct 4, 2013 at 12:40 PM
    #409
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Be careful...I had to redo mine with the sienna mirrors with the heating element already on the glass. My passenger side broke after a 5 min run :mad:
  10. Oct 4, 2013 at 12:44 PM
    #410
    JLink
    Josh
    Ocean, NJ
    What do you mean? How did it break?
  11. Oct 4, 2013 at 12:45 PM
    #411
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Too much heat on the glass....and it cracked and broke as I sat in a parking spot.
  12. Oct 7, 2013 at 8:14 AM
    #412
    JLink
    Josh
    Ocean, NJ
    Do you know how long they were on for? Or which brand you used? Makes me think maybe I should just wire them up with the high/low/off switch that came with them...
    I got the mirrors out and ran wires through the doors, but didn't get any further than that lol
  13. Oct 7, 2013 at 8:34 AM
    #413
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    I used the switch that came with them...If you use them only use the low setting IMHO
  14. Oct 7, 2013 at 10:48 AM
    #414
    JLink
    Josh
    Ocean, NJ
    Ok different brand than mine. I guess I'll just wire them up with the resistor and if they don't heat up enough, ill remove it
  15. Oct 11, 2013 at 7:07 AM
    #415
    JLink
    Josh
    Ocean, NJ
    Well I finally got started on my mirrors. I was surprised how they came out of the backing pieces. I thought there was double sided foam, but the mirrors were only held in by the edge of the backing pieces. I warmed them in the oven to make them easier to pry off.
    I used the existing square holes in the backing pieces to route the wires.
    I used pl mirror mastic to glue the mirrors back into the backing pieces, but I don't think it's necessary after seeing how they were held in there originally.
    Routing the wires through the mirror housing was a bit annoying, but after I unbolted the housing from the arm I was able to get the wires through.
    I also tested the heating elements to see how hot they get... Thanks for the heads up slimwood... I think high might be too hot.. It's hard to hold them at that temperature. So ill wire them up with the resistor for the low setting and I think it should work just fine. They are still quite warm even on low.
  16. Oct 11, 2013 at 2:35 PM
    #416
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    No problem...it may be common sense, but who knows....my shit got hot as fuck!!
  17. Oct 12, 2013 at 5:47 PM
    #417
    JLink
    Josh
    Ocean, NJ
    Didnt end up using my time delay relay.. couldnt seem to get it to work the way I wanted, and i'm not sure if maybe I ordered the wrong one.. but if anyone wants a TDR-P from wolstentech.com let me know
  18. Oct 4, 2015 at 7:04 PM
    #418
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    deff will be doing this since its usually a problem in my area
  19. Apr 29, 2016 at 1:21 PM
    #419
    bretts
    bretts Well-Known Member
    Pasadena, TX
    98 Tacoma Regular Cab 2WD
    When you bought the sienna mirrors did all you need to do was wire up an on/off switch? Did the pwr mirror connector match up with the Tacoma pwr mirror switch? I think I might buy the siennas if something ever happens to my originals.
  20. Apr 29, 2016 at 8:29 PM
    #420
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    All I bought was the glass. Just wire them up POS and neg to a switch and you will be fine.
