El Cheapo Heated Mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tsilliker, Oct 7, 2008.
  1. Apr 5, 2017 at 9:24 AM
    #421
    mikaymusic
    mikaymusic Well-Known Member
    07 Tacoma 4x4 SR5 TRD
  2. Feb 19, 2018 at 7:15 AM
    #422
    ZaPHoN
    ZaPHoN Member
    Anyone have any thoughts on incorporating this
    "10A Mini Timer Time Delay Relay .2 Sec to 1000 Hours. 12V. Power on or Off Delay, Cycling and More"
    https://www.amazon.ca/Timer-Delay-R...coding=UTF8&psc=1&refRID=17C45V2KGFFG38FB6KMZ
    Description:
    Universal Timer delay module allows delaying power or disconnecting power after preset period of time. It could also be configured to cycle power ON and OFF. Time delay can be set from .2 second to 1000 hours. The circuit is utilizing embedded micro controller so the time delay is precisely repeated every time. Time delay is configured by two configuration wires. Circuit can support up to 10 amps. Current capacity can be extended by connecting external relay.
    Timer delay module can be configured to delay power, supply power for a period of time or cycle power with preset delay. There are 19 different timer modes so we sure it will fit your project needs.
    With external relay control any current or voltage. Great for automotive application, car amplifier control delay, industrial controls and hobby.
    Delay from .2 sec to 1000 hours
    6 - 20 Vdc
    10 amp
    Small and waterproof.
    Made in USA
    Lifetime Warranty
    We are confident timer will fit your project needs.
    We have number of YouTube videos to help with connection and configurations.
    Manual can be downloaded here: http://www.3rdbrakeflasher.com/documentation/Multifunctional_Timer.pdf
    https://www.youtube.com/watch?v=GxYvp71870s
    02MtnTaco likes this.
  3. Jul 4, 2019 at 7:52 AM
    #423
    Flatliner
    Flatliner Well-Known Member
    Robert
    2008 Tacoma Double Cab TRD Sport
    Fox and Icon Suspension upgrade
  4. Oct 15, 2021 at 8:17 PM
    #424
    Pearson
    Pearson Well-Known Member
    Elliott
    Lexington Texas
    Black 2012 2.7L Prerunner
    Excellent! Thanks for taking the time. Its threads like this that when contributed to by the community can become quite a resource. When I was reading through it the first thing that came to mind was a timed relay that could be manipulated for preference.
    Ideally when everything was said and done to have them come on and run for a set time each time the engine is started and then to have a switch that would make the same thing happen anytime while driving and felt the need.
    Really inciteful thank you!
  5. Oct 19, 2021 at 6:45 AM
    #425
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I tried one of those initially and never quite got it working right. But, that would be the ideal scenario.
