electric fan anyone?
Discussion in 'Performance and Tuning' started by woody6047, Feb 9, 2010.
  1. Feb 9, 2010 at 11:50 PM
    woody6047
    woody6047 [OP] McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Ive been looking but havent seen anything yet. Has anyone put an electric fan on a 2nd Gen? If so what kind did you end up going with.
  2. Feb 10, 2010 at 3:19 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
  3. Feb 16, 2010 at 6:31 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Flex-a-lite makes a kit for the Tacoma (flex-a-lite 678 I think). Expensive, about $400, though. I bought one late last summer and installed it. Works fine. Fan mount is Tacoma specific, but wiring is like a generic/universal kit. They recommended tapping wires in the engine bay, but I looked into the wiring diagram and tapped into the wires in the engine bay fuse box. At least there is some protection there.
    When I was researching there was also a few people who "rolled there own" and bought a fan and controller, then fabbed up the mounting and shroud. Some more searching on here should bring those posts up.
  4. Feb 16, 2010 at 3:22 PM
    rodstone
    rodstone Well-Known Member
    Travis
    California
    08 2.7l 2wd
    I was planning on getting this kit.http://www.toyotacatalog.net/M1WebG...UniqueID=D77E2B8D-E400-4221-AACA-AE550FFCEF30...when I can afford it. I've heard a lot of horror stories with the flex-a-lite fans. Best electric fan I know of to make your own kit is with a Lincoln MKVIII electric fan. Guys use those fans on EVERYTHING, I think they fit pretty good with the stock 05+ fan shroud too. I want to get the LCE fan kit because of the over flow tank and a/c relay, plus it makes things a lot easier for install, taking away all the guess work.
  5. Feb 17, 2010 at 5:50 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    This is the Flex-a-lite fan kit.
  6. Feb 17, 2010 at 7:11 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Yea i think im going to go with the flex-a-lite fan. I really havent heard anything bad about them. Should get it around march 1st so ill let yall know how it turns out.
  7. Feb 17, 2010 at 8:57 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Feel free to hit me up with any questions when the time comes. Like I said, I tapped into wires in the fuse block instead of Flexalite's instructions.
    My only feedback is that the electric fan seems to generate more "rumbling" in the cabin than I thought it would when its on. Also, the AC circuit that they recommend you tap into is the AC compressor circuit. That means that the fan cycles on/off with the AC compressor, which tends to cycle quite a bit. I have considered finding the AC turn on line to feed the fan controller's AC input, but have not done it as yet.
