Electric Fan power increase
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rons01TRD, Jul 7, 2014.
  1. Jul 8, 2014 at 10:13 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    An electric fan also offers the ability for those driving through say a creek or some other body of water to turn the fan off so it won't turn and splash water or break the fan.
  2. Jul 8, 2014 at 11:49 AM
    mustangstephen
    mustangstephen raise hell, drink beer
    Stephen
    by da creek
    02 Tacoma TRD
    Homebrew bumpers and sliders, 5100s & Eibachs up front and mutt leaf pack out back, 285s & Wheelers type B, sway bar deleted. Wife's ride: 01 4Runner 4wd sport. Stock with exception of TRD taco coils, and shift kit.
    I swapped to electric fans on my 67 mustang back in the day. Wasn't impressed with them. Ended up back on the stock clutch fan like tacos have. I was actually glad to find the clutch fan on the truck when I bought it. I have no desire to ever going back to electric fans.
  3. Jul 8, 2014 at 11:51 AM
    Rons01TRD
    Rons01TRD [OP] Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Truck has 144k never seen a dirt road:eek:
    1. Air filter changed every three months (Toyota brand)
    2. Oil replaced every 3000 miles (Mobil 1)
    3. Coolant flushed and filled every year
    4. Tranny fluid recently flushed and filled by Toyota
    5. Diff fluid every year
    6. Plugs, wires and fuel filter less than 6 months old (All Toyota brand)
    7. Throttle body is clean, upper and lower intakes are ported and polished to match the gaskets and painted to match the valve covers when I replaced the valve cover gaskets.
    8. Deck Plate mod preformed.
    The pic is a few months old and the brake fluid has been flushed and refilled.:)
  4. Jul 8, 2014 at 12:20 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Link? Cant find it under $300 :notsure:
  5. Jul 8, 2014 at 7:18 PM
    RdRunr
    RdRunr Well-Known Member
    Dan
    still in the Matrix
    2014 Base, white, reg cab, 2.7L, 5-spd
    DT header, Flowmaster 50 Series Delta Flow muffler
  6. Jul 8, 2014 at 7:32 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You are throwing away a lot of perfectly good air filters, coolant, mobil 1 and diff fluid with that schedule.
  7. Jul 8, 2014 at 8:38 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Toyota tends to use clutch fans with longitudinal engines, unless noise is a concern. Case in point: Supra with the 2JZ uses a clutch fan. IS300 with the 2JZ uses two electric fans.
  8. Jul 8, 2014 at 9:07 PM
    KenLyns
    Belly of the Beast
    ^Until the statistics catch up with him and he opens the wrong drain plug by mistake, rounds off a bolt, etc. :devil:
  9. Jul 9, 2014 at 3:32 AM
    Rons01TRD
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    Snap-On........no rounding of hardware.:D
  10. Jul 9, 2014 at 4:15 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Take the fan off drive it around the block and try it. I don't recommend it but you can stop a clutch fan that is cool with your hand. They require very little power to turn them until they lockup.
  11. Jul 9, 2014 at 4:25 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Here is some thing else to ponder. If your truck has A/C (seems likely) you will have to come up with a method of turning on the fans with the A/C it does not matter about engine temp but with out a fan turning cooling the condenser the head pressure on the A/C system will sky rocket.
  12. Jul 9, 2014 at 6:46 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Most decent controllers have an AC feed line that turns the fan on if the AC clutch is engaged. The flex-a-lite kit has that and you tap into the AC clutch down by the AC compressor or the engine fuse block.
  13. Jul 9, 2014 at 8:24 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    If you are looking for more pep why not headers, light pulley, maf recalibrator?
  14. Jul 9, 2014 at 8:29 AM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    Naw. Noone's dumb enough to do this.
    *snicker
  15. Jul 9, 2014 at 8:38 AM
    #35
    Indy
    Indy Master of all I survey.
    What hes doing wont affect longevity though. Hes spending money where it does no good. You can change you oil every mile and your engine wont live longer than if you do it every 5k. Its his money but there are better ways to spend it.
  16. Jul 9, 2014 at 9:19 AM
    #36
    KenLyns
    Belly of the Beast
    Snap-On won't prevent you from pouring transmission fluid into the radiator. :D
  17. Jul 9, 2014 at 11:49 AM
    #37
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Now you're just talking Krazie...
  18. Jul 9, 2014 at 2:13 PM
    #38
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Wrong drain lol:rolleyes: if someone is consistent with maintenance they shouldn't get stuck bolts to round heads;)
    I'd be interested in an electric fan for the ability to shut it off, always a great feeling tearing your fan blades and radiator up during a water crossing:eek:
  19. Jul 9, 2014 at 2:15 PM
    #39
    nagorb
    Alabama
    2001 dbl cab 4x4
    No, but not being stupid will. Not sure how someone who does maintenance at shorter intervals is more likely to put the wrong fluid in:confused:
  20. Jul 9, 2014 at 2:50 PM
    #40
    KenLyns
    Belly of the Beast
    ^Just going by experience in aerospace, where 50% of failures are caused by maintenance...
