Electric fans??
Discussion in 'Performance and Tuning' started by bigtaco07, Mar 29, 2011.
  1. Mar 29, 2011 at 9:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Only when the fan is not running. Once it starts, electric, or whatever, it takes power to make power. Gains are minimal.
  2. Mar 29, 2011 at 9:14 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    If you don't want to spend a lot on a fan set up, look into a Lincoln mark 8 2 speed fan or a 94 ish year t bird fan. The lincoln and t birds fan look the same but the lincoln put out more cfm(5000 ish). Google mark 8 fan conversion or thunder bird fan conversion. You can get them at a junk yard for 40 bucks
  3. Mar 29, 2011 at 9:29 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    True, but it really doesn't take much power to turn an electric fan. When you take into account the rotational mass of a clutch powered fan you begin to see legitimate parasitic loss of HP. Say your average electric fan is going to run an operating amperage of about 12 to 14 amps (about the norm.) Initial startup will be upwards of 25 but thats only for a very short period of time, less than 1 second usually. So say 14 amps x 12volts = 168 watts. 168 watts x 0.00134 = 0.221 HP. Now I couldn't tell you exactly how much our stock clutched fan is drawing without getting into some pretty complicated math, but i can assure you it is much more than .221 hp when engaged.
  4. Mar 29, 2011 at 9:46 PM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    2017 Tacoma Dbl cab long bed.
    Hood Strusts, remote Start, truck came with Leveling kit and wheels.
    I have a 16" fan with the standard relay kit for it. I am happy with it so far.. I just dont like the prob that I had to put through my radiator.
  5. Mar 30, 2011 at 6:24 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I have the FAL kit. I prefer e-fans overall so I spent the money. As for any noticable gains, I have seen none, either mpg or performance. What i do get is no startup fan roar, ensuring that the fan is on when the AC compressor is, and _maybe_ a bit less engine drag when engaged (mech fan drag vs. alternator drag).
    In the end, can't justify the kit on perf and mpg gains though. Also note that I upgraded the controller to the 2-stage FAL controller in order to start the fan on a lower power usage than the full on or off of the stock FAL controller.
    As for is it complete? Yes, it comes with everything you need to install it.
