Electric Locker Questions...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kuneff, Sep 29, 2010.
  1. Sep 29, 2010 at 6:35 AM
    Kuneff
    Kuneff [OP] Carpe Diem
    West Virginia
    Tacoma Woods Beater
    Tree Dents
    I am sure this has been posted before, however I am trying to get a quick answer so I can get the ball rolling ASAP...
    I am looking to see what it will take to put a e-locker in my 97 Standard cab tacoma. I know i have read a few things here before about the wiring... and I think someone on here even makes a wiring harness for this... Anyone know about that????
    1... I have no tag on my diff's and not sure they are the original ones to the VIN#. How do I find out for sure what the gear ratio is? I am guessing I will have to pull the 3rd member out and count, but what number teeth pinion/ring = what ratio???
    2... Who, where and how do I hook up a harness to maintain OEM switch and work like factory? If the Locker harness separate from the main truck harness??? How and where does it hook up?
    I am torn between going for an e-locker or a Lock-Right. I am thinking the easiest route would be the Lock Right. Any advise???
  2. Sep 29, 2010 at 6:48 AM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    Q1.0 = go to this site http://www.4x4wire.com/toyota/tech/electric_locker/
    Q1.5
    This can be checked by dividing the ring gear tooth count by the pinion tooth count (e.g., Ring gear tooth count – 35T, pinion gear tooth count – 10T. 35/10 or 3.50:1 ratio)
    Q2 go to that site http://www.4x4wire.com/toyota/tech/electric_locker/
  3. Sep 29, 2010 at 7:10 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How about researching an ARB locker?
