Electric Supercharger?
Discussion in 'Performance and Tuning' started by caglezxj, Aug 8, 2007.
  1. Aug 8, 2007 at 3:44 PM
    caglezxj
    caglezxj [OP] Well-Known Member
    Has anyone used one of these. The URD kit is nice, but after 3500.00 in lift and wheel/tires, I don't see throwing another 5,000.00 out there. They clame to get 30 hp gains from them, and with the module/chip it is suppose to give you another 20. I don't see why it wouldn't work. I don't believe you would get 30 or 50 total but maybe 25 or even 20 hp gains. For 100.00 that is good. Then a new exhaust system you could maybe get 10 more. Let me know what you guys think. I would like to try this, just need some more info.
    Links to site
    http://www.electricchargers.com/
    http://www.stchiptuning.com/
  2. Aug 8, 2007 at 3:54 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    Why don't you just hook a leaf blower up to your intake? I wouldn't use that thing if they gave it to me for free, but that's my opinion. My guess is it will probably restrict the air flow more than anything. Let us know how it works out for you, if you get one.
  3. Aug 8, 2007 at 4:05 PM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    Do NOT get that crap man. There's a reason that an awesome kit like URD's costs $5,000 and that thing is $100. It wont help you at all.
  4. Aug 8, 2007 at 4:20 PM
    caglezxj
    I think it would help some. I might not add anything else, but I know pushing more air and adding a URD mass ir flow calibrator would change things alot. If you can explain to me how it would not work let me know. Each kit is designed to force more air in, and with the right calibrator for the MAF sensor it should give you some gain.
  5. Aug 8, 2007 at 4:21 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    Yea only 100.00 bucks if it sounds to good to be true it most likely is
  6. Aug 8, 2007 at 4:33 PM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    That thing will not be powerful enough to help more than hinder by taking up space in that intake.
    Don't you think EVERYONE would have one if it was "bolt-on 20hp"? Or dont you think car manufacturers would produce them OEM?
    Dont give your truck problems by using that thing man, it's not worth it. And as far as that chip goes, thats an even worse idea.
    Be logical, what is out there that gives you 20hp for $100? Nothing, and there's a reason for it.
  7. Aug 8, 2007 at 5:07 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Don't you kind of wonder why there are no good pictures of this device on the web page? By "featured" in those magazines on the bottom of the page it means that they paid for advertising in the back half somewhere. I no more believe that this thing does anything than I believe that the pills that are "featured" in the back of my car and driver or guns and ammo magazine will really enlarge my member to rival that of Ron Jermey. It's snake oil.
    You can find these things on e-bay too, I think I came across them by accident while looking for TRD parts (someone stuck TRD in the description for this thing, and curiosity compelled me to read it)
    Here's what it is in reality. It is a marine application blower. There is a little switch on the dash of a boat with an inboard motor marked blower. What it does is forceably vent flamable vapors out of the sealed engine compartment so that when you start up the boat after it's been sitting a while you don't blow yourself up.
    Go to a boat dealer, turn on the blower, stick you hand over the blower exhaust, you'll feel that it really moves next to no air at all. That is why you are supposed to leave the blower on for 5 minutes before starting the boat. All you are going to do with this is put a big obstruction in you intake.
  8. Aug 8, 2007 at 5:15 PM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    Precisely :)
  9. Aug 8, 2007 at 8:12 PM
    caglezxj
    well this was the type of questions I wanted to hear. Does the x-runner come with any factory performance parts? TRD makes superchargers for around 2800.00 the urd might be in the future.
  10. Aug 8, 2007 at 8:59 PM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    TRD has spent over 2 years "making" a S/C for the 05+ tacomas, and it's not released. When they release one, it will cost plenty more than 2800 too.
    The only performance difference between an x-runner and any other 05+ tacoma is the suspension
  11. Aug 9, 2007 at 4:23 AM
    Bfmco7
    Bfmco7 Well-Known Member
    Panama Red.. What do you think about this?
  12. Aug 9, 2007 at 4:49 AM
    4x4Taco
    4x4Taco Well-Known Member
    Ontario
    07 TRD Off-Road 4X4
    OK...here we go....
    To make 30hp on a V6 tacoma you need 2lbs of boost. For an electric supercharger to make 2lbs of boost on your engine would need close to 1000 amps of power at 12volts. Can you say impossible. The only electric setups I have ever seen that help in the least use caps to store up energy and then the SC can come on for a few seconds to help with acceleration. Save your money.
  13. Aug 9, 2007 at 5:46 AM
    Panama Red
    Panama Red Well-Known Member
    Bfmco7:
    The "electric supercharger" has been around for several years (it has discussed over on the Miatas forums many times). For those people who tried it (partly as a "gag"), they never achieved any benefit. As a result, it is looked upon as another version of "snake oil".
  14. Aug 9, 2007 at 5:56 AM
    Bfmco7
    thanks.. so it really is junk..
  15. Aug 9, 2007 at 4:56 PM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    OK im going to regret this, but I here it goes...
    When I was 16 (ten years ago) I road a Kawasaki Ninji 400. Me and a friend on mine "installed" a computer fan in the intake tube. We thought more air equals more power. Yes I was a stupid kid.
    The fan, running at full power, and those computer fans run pretty fast, restricted the air flow so much that the bike barelly ran at idle. Let alone while reving up.
    The actual speed of air being sucked into your manifold while your engine is running is way faster than any electric motor can ever force in. This is also why hood scoops dont actually "force" air into your engine. They only give your engine access to colder air.
    Dont worry I put "supercharged" stickers all over the bike, that made it faster.
  16. Aug 9, 2007 at 5:29 PM
    Panama Red
    reid:
    :thumbsup: & :amen:
  17. Aug 10, 2007 at 3:59 AM
    Bfmco7
    Heck I give you props for trying that at sixteen.. You were thinking, thats for sure. You never know if something works until you try it!
  18. Aug 10, 2007 at 1:28 PM
    reid
    Vancouver BC Canada
    2007 V6 Access Cab
    Ya, go figure, ten years later I am building custom show bikes.
  19. Aug 11, 2007 at 11:28 AM
    Bfmco7
    Who would have guessed!! Have any pictures?
  20. Aug 11, 2007 at 6:56 PM
    reid
    Vancouver BC Canada
    2007 V6 Access Cab
    Built this one for myself last year, won a lot of awards. Just a simple, clean bike, lots of open space, nothing crazy.
