Electrical Gremlin On My Back! HELP!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by J4R, Jun 1, 2024.
  1. Jun 4, 2024 at 4:44 PM
    #101
    J4R
    J4R [OP] Well-Known Member
    2005 4R 4.0 4X4
    2009 Tacoma motor
    I just unplugged all connectors on drivers side kick panel or whatever it's called and plugged them all back in...they all went back together good seemingly for whatever it's worth
  2. Jun 4, 2024 at 4:57 PM
    #102
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Factory security/Immobilizer or whatever light doesn't blink when i remove key out of ignition like it used to if that has anything to do with anything
  3. Jun 4, 2024 at 5:25 PM
    #103
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did you ever check pin 12 of IC4 connector? (blue wire)
    We need to see if we are getting power in to the connector, and out of the connector.
    J4R[QUOTED][OP] likes this.
  4. Jun 4, 2024 at 5:42 PM
    #104
    TnShooter
    Deogee
    STOCK
    IC4 Connector Map Out
    1. Blue/Black - Mag Clutch Relay
    2. Black/Yellow - Power from ECM to STA Relay
    3.
    4. Black/Blue 10a Heater fuse
    5. Yellow/Black - Ground to Fuel Pump Relay
    6. Grey - To Alternator
    7.
    8.
    9. White - Power from Air Fuel Relay
    10. Red - 10A Dome fuse
    11. Black - Power from EFI Relay
    12. Blue - EFI fuse
    13. Grey - Power to ECM from 10a ETCS Fuse.
    14. Blue/Black - Wiper motor
    15.
    16. Blue/White - Wiper
    17. Blue/Red - Wiper
    18. Yellow/Green - 30A Defog Fuse
    19. White - Ground Headlight Relay
    20. Black/Yellow - 15A Turn/Haz Fuse
    21. Purple - Power from 110v Relay
    22. Head Hi Left
    23. Head Hi Right
    24. Light Green - 25A Heater
    25. Black - 30A Tow Brake
    26. Black/Yellow - Accelerator Pedal
    27. White/Blue - 20A Radio #2
    28. Blue/Yellow - 20A Radio #1
    29. Light Green / Black - Accelerator Pedal
    30. Grey - Power from Acc. Cut Relay
    31. Red/Black - Accelerator Pedal
    32. Orange - 7.5A OBD Fuse
    33. Grey/Black - Ground from ECM to C/Open Relay
    34. White/Red - Accelerator Pedal
    35. White/Green - ECM power to EFI Relay (Control)
    36. Black/Yellow - Power from Heater Relay
    37. Blue - Ground to Heater Relay
    38. Pink - 7.5A Acc Fuse
    39. Grey - A/C Temp Sensor
    40. Green/Yellow - 7.5A Heater Fuse
    41. Blue - Ground for 110v Relay
    42. Red/Black - Front Turn - Left
    43. Brown/Yellow - Ground Mag Clutch Relay
    Steves104x4 and J4R[OP] like this.
  5. Jun 4, 2024 at 6:44 PM
    #105
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Ran to grocery store will check soon as I get back home here directly
    Pin 12 blue wire on IC4 correct?
  6. Jun 4, 2024 at 8:17 PM
    #106
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes
    TnShooter likes this.
  7. Jun 5, 2024 at 5:28 PM
    #107
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Excuse the late response if you will everyone. Jus busy with work and frustrated with this truck issue.
    I can't make out what pins are what on that dang "funky oblong" whatever IC4 connector. I do however have power on 2 pins there but no clue what # they are due to the awkward shape/layout of it but I don't think either of them are #12 but I could be completely mistaken on that.
    I know this isn't much help to yall and apologize. Idk. Really missing my Fluke meter at this point. Sux not being able to test continuity
  8. Jun 5, 2024 at 5:48 PM
    #108
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Pinout for that connector is in Post #50
    I'd rather use a test light anyway.
  9. Jun 5, 2024 at 6:29 PM
    #109
    TnShooter
    Deogee
    STOCK
    Any idea what colors the wires are?
    Just to give me something to "think about".
    I always try to think ahead. That helps me put together a response "faster".
    Below is the pinout.
    J4R[QUOTED][OP] and Dm93 like this.
  10. Jun 6, 2024 at 9:29 AM
    #110
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    UPDATE!
    FWIW I do have power to EFI # 2 fuse now (key on)
    Will get back with you on wire colors or pin #'s at IC4 connector that have power.
    Continued gratitude for you guys.
    winkel, Steves104x4 and TnShooter like this.
  11. Jun 6, 2024 at 9:30 AM
    #111
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Still no CEL tho of course at any point
  12. Jun 6, 2024 at 9:54 AM
    #112
    TnShooter
    Deogee
    STOCK
    That’s a start in the right direction.
    Now see if you have power to E8 pins 1 , 2 and 3.
    We still need to address the grounds. But let’s get power first.
  13. Jun 6, 2024 at 10:00 AM
    #113
    TnShooter
    Deogee
    STOCK
    E8 pins 1, 2 and 3 all go through IC4.
    Pins 1 & 2 get power form the EFI No2 fuse. The only way the EFI No2 fuse can get power is if the ECM controls the EFI relay. And the control wire for the relay goes through the IC4.
    Something you did worked. :rofl:
    Keep doing what ever your doing. :thumbsup:
  14. Jun 6, 2024 at 10:24 AM
    #114
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    The EFI relay pin #2 (ground) was loose so I just twisted a wire around the corresponding terminal on the relay itself and ran it straight to ground is all I did...thereafter EFI #2 has power...if that makes sense.
    Headed to check those E8 pins 1,2,3 now.
  15. Jun 7, 2024 at 7:38 PM
    #115
    J4R
    2005 4R 4.0 4X4
    2009 Tacoma motor
    Ok lads n gents here is what I learned today...spoiler alert, it ain't good.
    E8-1, E8-2, IC4-11 are straight up GROUNDED! How the .... is this even possible?
    E8-8, E8-9 have power FWIW
    @TnShooter
  16. Jun 7, 2024 at 7:41 PM
    #116
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Grounded as in it's blowing the fuse or your checking with a meter?
    If your checking with a meter or test light yes they will show a path to ground because the EFI Relay powers up alot of stuff.
  17. Jun 7, 2024 at 9:30 PM
    #117
    TnShooter
    Deogee
    STOCK
    As @Dm93 said, they will show a path to ground.
    The easiest example would be “through a relay” on the control side.
    But let’s not get off course. That’s a a discussion for a different time.
  18. Jun 7, 2024 at 9:32 PM
    #118
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Did we ever figure out those 3 grounds that were missing? The PCM can't turn on the EFI relay or power up if it's missing grounds.
  19. Jun 7, 2024 at 9:34 PM
    #119
    TnShooter
    Deogee
    STOCK
    Not yet.
  20. Jun 7, 2024 at 9:35 PM
    #120
    TnShooter
    Deogee
    STOCK
    I posted the location. Looks like back side of passenger head.
    Or possibly under back of intake.?
