electrical problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by A1CGuches, Dec 17, 2007.
  1. Dec 17, 2007 at 11:41 AM
    A1CGuches
    A1CGuches [OP] Oregon Alliance: Founder
    DMAFB, Arizona
    01 Taco
    Custom snorkel/intake, 6" lift, 35X12.5 mt's, flowmaster 40 seriers, performance clutch, custom skid plate, grille, everything is black on green, rotrex supercharger, 7th injector kit, urd short throw shifter, thorely header, kks speed limit defender...and more to come
    I have an 01 tacoma and i recently install aftermarket tail lights... all i did was simply plug them in and that was it...now when i turn on the lights the left turn signal indicator stays on and the turn signal barely works at all...also when ever i hit the brake it doesnt work but as soon as i let up on the brake it flashes .......i am think it is grounding out but i have no clue...anyone have any ideas?
  2. Dec 17, 2007 at 3:09 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    yeah sounds like a ground... take the lights back off just loose see if maybe you hit a wire when you put the screws back in
  3. Dec 17, 2007 at 3:51 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    It's a bad ground somewhere and/or some crossed wires. Check and re-check everything to make sure.
  4. Dec 17, 2007 at 3:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    also sounds like you may have a burnt out bulb......check that too!!
  5. Dec 18, 2007 at 9:30 AM
    A1CGuches
    DMAFB, Arizona
    01 Taco
    yup turns out it was a bad ground...after i took it apart and looked at it turns out the guy before me had a cannopy on it and the wiring for it was grounding out.
    thanks for the help
  6. Dec 18, 2007 at 5:04 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Drive on !:)
