electrical question
Discussion in '1st Gen. Tacomas (1995-2004)' started by WideLoad, Feb 14, 2009.
  1. Feb 14, 2009 at 7:09 PM
    WideLoad
    WideLoad [OP] Member
    Missouri
    97 Tacoma Ex-cab 4x4
    3 inch suspension lift, 2 inch body lift, K&N air filter, 33x12.5x15 tires on 15x10 steel wheels
    my first question to the experts here is about the electrical system. so about a month ago i took a 200 mile trip across state and on my return trip i noticed that my cruse control was not working. it did on the way out but not the way back. so i thought it was a fuse but they all check out. then the next week the air bag light came on, but the air bag never diploid. and finally i found out the other day that my horn does not work. but the blinkers and window wipers do work. so is there a master steering column fuse somewhere i missed or are all these problems not related. how can i test to see if the horn still works cause that could have just gone bad? some one please help me im confused.
  2. Feb 14, 2009 at 7:12 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Sounds like theres a problem in the circuit that goes to the steering wheel
  3. Feb 14, 2009 at 7:12 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    It is probably related to the rotating connection in the steering column. It resides between the wheel and non moving part of the column.
  4. Feb 14, 2009 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can test the horn by simply connecting it to the battery. If it honks, its good. Not sure what could be causeing the other problems, though. All the fuses check out ok?? The Fuse box under the hood, and teh one inside?
  5. Feb 14, 2009 at 7:16 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    if the air bag light is on and the horn doesnt work it sounds like a clockspring to me. its located under the steering wheel. the clockspring controls the air bag one on the steering wheel and if that goes out then usually the horn stops working.
  6. Feb 14, 2009 at 7:17 PM
    WideLoad
    Missouri
    thanks for the reply's. ill have to test the horn tomorrow. yes all fuses check out, both cab and engine boxes. is there a way for me to determine if the problem is in the steering column or should i just take it to the dealership and have them diagnose it?
  7. Feb 14, 2009 at 7:18 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    x2 on the clockspring! internal problem, happens alot on the dodge minivans
  8. Feb 14, 2009 at 7:24 PM
    JDMcQ
    So that's what that thing is called!
  9. Feb 14, 2009 at 7:26 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    you can do it yourself, just get a steering wheel remover and its pretty basic, just remember to disconnect the battery before you unhook the airbag
  10. Feb 15, 2009 at 9:33 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Toyotese for 'clockspring' = 'spiral cable'.
    ... And I agree that would be the most likely suspect for the symptoms you described.
