Electrical system question - Bussmann
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skynet Surfer, Apr 26, 2017.
  1. Apr 26, 2017 at 8:52 AM
    Skynet Surfer
    Skynet Surfer [OP] Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    So I'm planning future mods while I'm installing my new stereo. I have been looking at Paranoid Fabrications relay holder. I'm not sure if I want to use a Bussmann set up or to get a plain one. My question is what mods would I need to put a Bussmann to good use?
  2. Apr 26, 2017 at 1:53 PM
    whipper
    whipper Well-Known Member
    2007 PreRunner
  3. Apr 26, 2017 at 1:56 PM
    Skynet Surfer
    Dis
    15 DC v6 SR
    Right. But how much electrical stuff would warrant buying this. I only plan on a few off-road lights, stereo and a few things. Nothing crazy. So just wonder if I have minor plans for my truck, if its worth doing?
  4. Apr 26, 2017 at 2:09 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    with the lights it will be useful, but if you are only running one set of lights, then its kinda overkill. If you plan on adding a few items that need a relay then its a great idea and is super clean.
  5. Apr 26, 2017 at 2:31 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Rule of thumb, 120 watts is 10 amps of current at 12 volts.
    Fuse everything you add.
    I like that fuse, relay setup. It's convenient and clean. And will make life a little easier when adding circuits. No more, "which fuse should I, tap with an add a fuse to power whatever it is being added."
    I didn't read the whole thread in that link @whipper replied with. However, looking at the pics it appeared to have fuses you could hook up directly to, and fuses feeding the relay contacts. If they're pre-wired, all the better, you add a switched wire to turn on the relay, and the new toy on the other.:thumbsup:
