Electronics Basics and Reference
Discussion in 'Technical Chat' started by larryde09, Jul 23, 2010.
  1. Dec 12, 2012 at 12:34 PM
    #81
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Blue Seas Aux Fuse Block is what most run on here
  2. Dec 12, 2012 at 12:36 PM
    #82
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    or an sPOD
  3. Dec 12, 2012 at 12:37 PM
    #83
    OZ-T
    Peter North
    British Columbia
  4. Dec 12, 2012 at 4:02 PM
    #84
    TacosNBurritos
    TacosNBurritos Active Member
    Nick
    Pacific Northwest
    2012 4x4 T|X TRD
    That sPOD looks great! It has relays already mounted, sweet! I will likely need two and install them in a nice box like the Factoy mounted one under the hood. Location is unknown. I'll also need to convert to dual batteries and upgrade the alternator to support the electrical load.
  5. Jan 16, 2013 at 5:56 AM
    #85
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    I have tried to find this, but no luck. How many relays can 1 switch activate safely? How do you do the calculations? I am wondering if I can have several sets of lights (led), all wired individually to there own relay and fuse, but activated by 1 switch.
  6. Jan 16, 2013 at 6:41 AM
    #86
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    questions are how many amps do the lights draw individually & all together?, how many amps can the relay handle?
  7. Jan 16, 2013 at 7:46 AM
    #87
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Yep. You have your questions backwards. There is a high likelihood you can wire all your LED lights into one relay. LEDs take up very few amps. Figure out how much your lights draw, and make sure your relay can handle it.
  8. Mar 23, 2013 at 8:54 AM
    #88
    AZDesertTRD
    AZDesertTRD Well-Known Member
    Pamela
    Arizona
    2012 PreRunner Sport
  9. May 14, 2013 at 7:18 PM
    #89
    budshupe
    budshupe Member
    bud
    lakeside ca
    03 Tacoma trd
    is sticky still around???? I have questions about potentiometers maybe you can help me with
  10. Feb 15, 2014 at 11:31 AM
    #90
    firetaco18
    firetaco18 Well-Known Member
  11. Apr 13, 2014 at 10:07 PM
    #91
    Li0nel1234
    Li0nel1234 Well-Known Member
    Lionel
    Denver
    14 TRD OR DCSB SSM
    Dear OP,
    Thanks for this thread. It has helped me understand a lot. I saved it to my faves. I vote this should be a sticky somewhere.
  12. Jul 21, 2014 at 11:43 AM
    #92
    daebin5
    daebin5 New Member
    Daebin
    Chico Ca.
    92 Toyota pickup
    I have my dash dismantled and cleaned up the mess of wires that were left dangling from my trucks last wiring job. I want to hook the cigarette lighter to use for powering up my phone. I know I need to run the wires to a fuse of 15w and I have know idea what color wire I need to use to connect to the proper wire the leads to the fuse box.
    I have a wire running with a 30w fuse from the battery to my stereo amp under the passenger seat and I need advise on whether or not I can use this wire to power my lighter? My thinking is to put a connecter out from the amp wire and link it to a 15 w fuse that then runs to the c. lighter. Then run a ground wire to somewhere under the dash and screw it in. Will this be a good Idea? ;)
  13. Jul 21, 2014 at 12:54 PM
    #93
    daebin5
    daebin5 New Member
    Daebin
    Chico Ca.
    92 Toyota pickup
    So i did some more research and discovered that the brown 12v accessory wire leading off the fuse panel is my wire, so I think i will simple connect this wire to the C. lighter and ground the c. lighter to a screw under behind the dash.
  14. Jul 21, 2014 at 2:44 PM
    #94
    daebin5
    daebin5 New Member
    Daebin
    Chico Ca.
    92 Toyota pickup
    I went ahead and tested the brown wire and it had no electrical pull on the light test, so I am going to assume it is a bad wire.
    I still need to know if I can do my original plan, which is to connect the C. lighter 12 volt cord with a 15v fuse and connect it to the amp power cord?
  15. Jul 28, 2014 at 5:19 AM
    #95
    larryde09
    larryde09 [OP] Well-Known Member
    Larry
    Boston, MA
    2019 TRD Sport, White Double Cab "Yeti"
    Current: DR750S-2CH Dash Cam, USB Fast Charger in stock blank, Hondo Garage phone mount Previous: 2006 Black 2.7L 5-spd SR5 4x4 Access Cab - K&N Cold Air Intake, Modified Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars, DIY Bed Lights, DIY Ground Lights, DIY Tailgate Electrical Box, Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I'm just checking in on the latest posts. Do you still have a question?
  16. Jul 28, 2014 at 5:42 AM
    #96
    larryde09
    Larry
    Boston, MA
    My first question is: wasn't the cigarette lighter already wired and fused from the factory, or are you doing some modifications? I'd recommend rewiring the original wire(s) to the original fuse location.
    I do not recommend connecting your cigarette lighter to the amp fuse for a number of reasons:
    1. The amp likely needs upwards of 20-30A to operate, or else the manufacturer wouldn't have recommended such a size of fuse and wire. Connecting another load to the same power line will rob power from the amp thus reducing its "headroom". In other words, say that the amp typically operates on 20A, and then you turn on your cigarette lighter that draws say 10A, this might blow your main 30A fuse. Do you want your stereo to shut down every time you use the lighter? Note: the scenario above is a slight exageration and fuses are typically rated higher than necessary, but it could happen if your amp is under load from high volume and multiple speakers. Although USB (i.e. phone charger) is relatively low current (~2A), who's to say you don't use the cigarette lighter sometime in the future to run a vacuume or tire pump, which draw a lot of current!
    2. Amplifiers enjoy clean power. Anytime you introduce other loads or noise on the power or ground lines of an amp, you risk reducing the quality of the sound. I would not compromise the amp or speaker wires (i.e. cut, splice, etc).
    3. Some amps are very sensitive to voltage transients. Adding a load may in fact damage your amp. This is particularly true if running something like a vacuume or pump. Without getting into too much detail, just know that electric motors can send jolts of electricity backwards down the power line. This could be damaging to your amp.
    Are you sure the wire is bad? This is not likely if it is a factory installed wire, unless you modified it in someway. Check if the fuse is good and installed properly. Also, most cigarette lighters only work when the key is "on" not in "accessory". Try testing it again with the truck in "on" or running if in doubt.
    If all you want to do is provide a USB charger for your phone, I recommend reinstalling the original factory cigarette lighter circuit and/or locating the standard 12V "Accessory" circuit in the truck. Tap off of that rather than messing with your amp.
  17. Jul 29, 2014 at 11:36 AM
    #97
    drop4205
    drop4205 Well-Known Member
    Windham, Maine
    14 TX Baja
    Pioneer 8201 nex Id cxs 6.5 component front Id cs 6.5 rear Jl audio hd 600/4 Jl audio 10” micro sub+ Ram mat Tinted windows Debaged Plasti dip front emble
    so how would you properly hook halo lights to my parking lights on a 2014 tacoma
  18. Jul 29, 2014 at 8:07 PM
    #98
    larryde09
    Larry
    Boston, MA
    Check out the original post, it outlines wiring up a circuit with a relay. I don't know the specifics of your application and/or any kit or prefabricated wiring harness you may have purchased, but the basics of using a relay are the same.
  19. Jul 29, 2014 at 8:13 PM
    #99
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Nice thread. Surprised I havnt seen this before. Agreed it should be a sticky though. Would save me alot of PMs haha :D jk guys I dont mind all the questions :)
  20. Jul 30, 2014 at 6:53 AM
    #100
    larryde09
    Larry
    Boston, MA
    It used to be a sticky, not sure if/when removed. Glad you've been fielding questions, I rarely check on the site since I got rid of my Tacoma.
