Electronics & the heat......
Discussion in 'Audio & Video' started by Janster, Jun 9, 2008.
  1. Jun 9, 2008 at 3:14 PM
    Janster
    Janster [OP] Old & Forgetful
    Jandy
    Lancaster, PA
    Hey Gang....
    The last few days have been 95 degrees - amazing the heat came up on us quick. So obviously...it gets a bit HOT in the truck when its sitting outside.
    I have a scangauge mounted on steering column - and I know they recommend to keep it covered and out of the heat. I also have an 80gig ipod that pretty much stays inside my center console all the time. They both get HOT.
    You guys worry about this stuff? You scangauge owners...do you cover it up in these conditions? And I've never had problems with my nano in this heat (same scenario) - but the Classic is a slightly different animal.
    Thoughts? Suggestions? Or am I worrying too much?
  2. Jun 9, 2008 at 3:44 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    I leave my iPod in the center console all the time. I've never had any issues.
  3. Jun 9, 2008 at 3:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have had things in my truck when the outside temp was 120*+, and they still work. :)
  4. Jun 9, 2008 at 5:24 PM
    Janster
    Jandy
    Lancaster, PA
    Haven't had any problems yet... but are you saying to unplug it before I start the truck up (give the scangauge power)?
    or wait until I have problems, then proceed with powering it down?
  5. Jun 9, 2008 at 5:37 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Janster I've never seen the scangauge but what if you fabricated a tastefully cut brushed aluminum "sun shield" to shroud over the top of the unit-kinda with a 'visor' effect protruding over the readout like the SunTachs have? Then patent it, make a million and take us all out for hotcakes:D
  6. Jun 10, 2008 at 5:51 AM
    Janster
    Jandy
    Lancaster, PA
    :D
    I'd better get to work! ;)
    I was thinking more along the lines of covering it with an old white sock....:p
  7. Jun 10, 2008 at 6:37 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    welcome back phantom! Glad to see you here.
  8. Jun 10, 2008 at 6:59 AM
    Ridgerunner
    Frank
    Rocklin, Ca.
    :rofl:do the sok:rofl:
