Emergency Brake Light won't go out?
Discussion in 'Technical Chat' started by FightFire48, Dec 13, 2008.
  1. Dec 13, 2008 at 12:03 PM
    FightFire48
    FightFire48 [OP] Taco Monster
    Will
    Spokane, WA
    04 Taco dbl cab
    3" Toytec lift AEM BruteForce CAI Gibson exhaust 2 - Rockford Fosgate 8's
    My e brake light on my 2004 taco quad cab stays lit when im driving. I thought that it was only doing this in the cold weather but im still having this issue. Does anyone know how resolve this matter?
  2. Dec 13, 2008 at 2:46 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Brake lever or your brake fluid may be low in the brake reservoir. With that said, if your brake fluid is low that means your brakes need to be serviced too.
    TomTwo likes this.
  3. Dec 13, 2008 at 4:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The brake fluid on the first gens needs to be near the "full" line or the light will go on.
  4. Dec 13, 2008 at 4:16 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Actually a little above the full line would be best, at least on my old rig. :rolleyes:
  5. Dec 13, 2008 at 4:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Could be. I wouldnt over fill it right off the bat, though. Work up until it goes off.
    TomTwo likes this.
  6. Dec 13, 2008 at 4:50 PM
    spp
    spp OC, Kalifornia
    OC California
    Check brake fluid and if that fixes it check the front pads. May be getting time for new ones but not always.
    TomTwo likes this.
  7. Dec 13, 2008 at 5:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  8. Dec 13, 2008 at 6:18 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Welcome to TW, Grab yourself a hard hat in the lobby. Just some suggestions I stole from other sites. It may help and it may not.
    There is a TSB on the emergency brake pedal... The bolt comes loose, and so does the arm assembly.. That may result in the button sensor showing a brake warning light on the instrument panel. When you make a turn, it moves over..
    Put it in park, get out of truck with the parking brake released.. Grab the pedal arm (above pedal) and see if it will move from left to right (driver <--> passenger) direction... Should be NO side movement at all.. IF so, tighten it, or go in to get it tightened and that might be tripping your light to...
    about: 2004 Toyota Tacoma
    [​IMG] Emergency Brake
    My emergency brake light comes on and stays on when its cold out, then when the truck warms up it turns off.
    This is extremely common on all Toyota trucks. The easiest way to take care of this is go buy a can of PB Blaster at your local auto parts store, lay on the ground under your truck and find the parking brake pivot. If you don't know where it is (should be drivers side about where the cab and bed meet next to the frame rail) have a friend pull the level and release it while you see what's moving. Lube the crap out of the pivot arm adjuster while you or someone else pulls it and releases it. This works 95% of the time. If not, you'll probably need to adjust the shoes in the back but like I said, should be fixed with that $3 can of PB. This is a 5 minute fix at most.
    http://www.tacomaworld.com/forum/technical-chat/9322-emergency-brake-light.html
    One more thing....From what I've read there is a float/bobber in the Master Cylinder that detects fluid level. Even if the fluid is at the correct service level,(visual) that float could still be sticking and not reading correctly. I assume you could pull the cover and GENTLY pull that float up to see if there is any movement upwards.
  9. Dec 20, 2008 at 7:32 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    your parking brake cable might be stretched... that's what was wrong with mine
  10. Dec 23, 2008 at 10:48 AM
    FightFire48
    Will
    Spokane, WA
    04 Taco dbl cab
    thanks for all the suggestions and im sure one of them will work its been agonizing for me on my taco.
  11. Sep 30, 2013 at 2:40 PM
    jkarov
    jkarov Member
    New Hampshire
    2001 4x4 SR5, V6 Tacoma Xcab bone stock
    I flushed the brake fluid in my non ABS 2001 Tacoma, but forgot, and left ignition on to listen to the radio. Pads and shoes are fine, just old fluid.
    When I drained the master cylinder, the light was triggered because the level went down too low. To turn off the light, unplug the sensor on the driver side lower part of the master with the key off.
    Turn the ignition on (don't have to start it) then back off.
    Next time you turn it on, the light will come on for self test, and then go out when it senses the fluid at proper level.
  12. Oct 8, 2013 at 10:16 AM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Wow. Good info. Thanks!
  13. Oct 17, 2014 at 7:28 PM
    Rubio92
    Rubio92 Well-Known Member
    Josh
    Bakersfield, CA
    '04 Prerunner IMPULSE RED
    Projector Retrofit in sig LED's galore inside and out Painted black stock alloys
    I love Google. First hit when I typed in "emergency brake 2004 tacoma engine oil" So my '04's E-brake light would NOT turn off. I topped off the brake resi last night and it went away, obviously came on when the E-brake was applied.
    Shamal likes this.
  14. Feb 15, 2015 at 12:45 PM
    2thumbs
    2thumbs New Member
    Topping off the brake fluid fixed it for me. Thanks!
    Shamal likes this.
  15. Jan 31, 2016 at 6:01 PM
    acidfly
    acidfly Well-Known Member
    Kevin
    Kitsap, Wa
    Toytec 3" lift, 4.88 gears, ARB locker, Elite front/rear bumper with sliders, Fully LineXed, Custom bedrack
    This is why I love this site, I've been staring at this light for a month. Went to take apart the switch, didn't fix it so searched for the reason. Bloody simple
  16. Mar 13, 2016 at 11:33 AM
    TacoTinker
    TacoTinker New Member
    I'm new to the forum as of today but the advice on this thread sealed it. I installed a new e-brake cable on my 99' Tacoquad. After finishing the install the Brake light was still on. That's when I found this thread. Several suggestions I saw helped. Saw that the fluid was at the minimum level and filled it. That didn't do it so the next thing was to try what jkarov suggested. Took two tries but then success! The light though kind flickered or came on randomly. I found that the brake handle wasn't going all the way down to the switch. Crawled under the truck and lubed the pivot arm that TicTacOma talks about with WD-40 and no more sticking. The light is off!
  17. Jul 16, 2017 at 5:41 PM
    toyotamd
    toyotamd Well-Known Member
    Arizona
    2002 Xtra Cab V6 auto TRD
    So my e brake light came on as well; possibly when fluid level was low after bleeding, but not sure.
    - I removed the switch behind the brake handle - it indeed functioned correctly and was engaged by the e brake handle. No change to the light.
    - I topped off the fluid to max. No change.
    - I tried the trick quoted above. No change.
    - Finally, I tapped on all sides of the master cylinder with a hammer. Not to hard, but not gentle either, bot the metal cylinder itself and plastic reservoir. The light went off. I interpret this to mean it was the float that was stuck on the bottom.
    SSG (03)TACOMA likes this.
  18. Oct 15, 2017 at 9:22 AM
    SSG (03)TACOMA
    SSG (03)TACOMA SSG TACOMA
    2023 DOUBLE CAB V6 TRD SPORT 4x4
    Good advise, worked for me
  19. Dec 1, 2019 at 1:24 PM
    WalkAboutCreek
    WalkAboutCreek New Member
    Joe
    2003 Silver Ext. Cab V-6 Tacoma SR5 4x4
    THE FIX IS: grease/oil/WD-40 the "cam assembly" under the truck (under driver's side) that connects the cable that runs up under the dash and to the main cable running to the rear brakes. This (what I call a) cam assembly is a pivoting junction that has a big spring on it. After using a lot of WD-40 (for now) and cycling the assembly, the cable running into the dash finally allowed for the pin connected to the rod on the emergency brake handle to finally seat fully on the switch which activates the light in the dash. After time this "cam assembly" gets coated and caked with dirt, oil and who-know-what-else. It gets sticky and doesn't want to react as designed unless cleaned and lubed.
    I fought this for years - not looking into the real problem but putting hardware on the pin that mates with the switch to build up its girth, electrical taping the switch down -- until the tape wore out, but finally tracked it down to this. Hopefully this IS the problem and the FIX. Hope others find this helpful!!
    Brewboy5 likes this.
  20. Jan 6, 2020 at 11:06 AM
    Brewboy5
    Brewboy5 Member
    Virginia Beach
    03 Tacoma Double cab
    This problem has been bothering me for the past several years as well and it finally caught up with me on my last state inspection where I failed due to the brake light being on. I tried everything (including a jerry rigged bungie cord to pull the e-brake handle back) and the only thing that worked was spraying that cam assembly with copious amounts of WD-40 and woking the mechanism. Thank you for that tip as it seems to have finally fixed my problem.
