emergency brake wont release
Discussion in 'Technical Chat' started by FreebirdTeamster, May 2, 2009.
  1. May 2, 2009 at 6:51 PM
    FreebirdTeamster
    FreebirdTeamster [OP] Member
    2000 tacoma sr5
    i tried my emergency brake last week for the first time just to see it if worked and it did, ever since then the light on the dash that says "brake" wouldnt go off so i figure it wont disengage completely
    so tonight while trying to figure out what the problem was i pulled the brake again and now its fully engaged and wont disengage at all
    please help i need my truck, i just need to get it disengaged so i dont have to tow it to a shop or anything
    2000 toyota tacoma SR5 4 wheel drive AT 2.7 liter about 120,000 miles
  2. May 2, 2009 at 6:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    I had the same issue with my 98. I found the lever was frozen, meaning it had rusted fast. The lever is held in with a pin that you can drive out. Remove the pin (under the rubber boot) and clean the lever and bracket up. Then grease it with white lithium grease. I am not saying this is your problem but it is worth a check.
  3. May 2, 2009 at 7:01 PM
    FreebirdTeamster
    2000 tacoma sr5
    where is that exactly
  4. May 2, 2009 at 7:02 PM
    98tacoma27
    Ben
    Not Beech Creek
    On the inside of your rear wheels. There should be one on each side.
  5. May 2, 2009 at 7:03 PM
    98tacoma27
    Ben
    Not Beech Creek
    I mean axle side of the wheel.
  6. May 2, 2009 at 7:04 PM
    FreebirdTeamster
    2000 tacoma sr5
    so do i need to take the wheel off or no
  7. May 2, 2009 at 7:08 PM
    98tacoma27
    Ben
    Not Beech Creek
    No. Just look at the backside of the wheel from under the truck. You can't miss it.
  8. May 2, 2009 at 7:24 PM
    FreebirdTeamster
    2000 tacoma sr5
    thanks man
    i actually just went out there and tugged on the cables and used some WD40 and finally got them to release
  9. May 2, 2009 at 7:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    Sweet. Glad you were able to fix it.
