EMERGENCY HELP!!! Flooded interior...
Discussion in 'Technical Chat' started by kriskross, Mar 31, 2014.
  1. Apr 2, 2014 at 8:50 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    People can guess all they want over the internet. The issue is, where did the water go? Likely fried the ecm. Did you pull the mass air flow sensor to make sure its not covered in crap? Sounds to me like its not getting crank signal which I'd why the plugs aren't firing. I think you need to winch it out, dry everything, and get down to the basics.
  2. Apr 2, 2014 at 8:51 AM
    Toyota Tech31
    Debary, Florida
    Trying to fix it while it is still submerged sounds like trying to shovel shit uphill. Just gonna Jeep coming back down and messing everything up.
    Edit: never mind, just watched your video and saw its out of the water.
  3. Apr 2, 2014 at 9:02 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Yikes. Swammped mine a few times and I unplugged the battery and let a dehumidifier run for days before trying to move it and the whole time my interior was removed and all the wire harnesses were unplugged. They will not dry if pluged in.
  4. Apr 2, 2014 at 9:06 AM
    kriskross
    kriskross [OP] Shits & Giggles
    Monterey
    Former 2ndGen Owner, in the market for another
    See Build Thread
    Dude, sandbags is a great idea! The issue with crossing that stream is it's just too deep but sandbags would work great. Anyone know how to get ahold of a bunch??
  5. Apr 2, 2014 at 9:16 AM
    Alfuh
    Alfuh It's pronounced alpha
    Bismarck, North Dakota
    2006 Prerunner
    I have a few mods
    Home Depot should have sand bags for sale, I was just looking online and saw they had some, not sure if the HD near you has them in stock. but as for pre-filled ones....I have no idea, youll most likely have to fill em up yourself. Which there was that clay/dirt pit that we can use to fill the bags up
  6. Apr 2, 2014 at 9:53 AM
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Kriss Nooooo!!! This sounds eerily familiar :(
    The good news is that it sounds like your crank, rods, and pistons are intact.
    As others have suggested, your ECM might be shot, but I would also pull the Yaw sensor under the driver's seat and bench test it. Additionally, I would remove the kick panels from each side and unplug whatever got submerged. Hit the plugs with air (if you can), maybe some WD40 or high % Iso Alcohol, and then slap some dialectric grease on each plug before reconnecting.
    Are there any warning lights in the gauges that are out of the ordinary (VSC, ABS, Maint Soon, CEL)?
    That is likely the Airbag ECMs. Anything wrapped in Yellow tape is part of the Airbag system, and I would leave it alone for fear of accidentally deploying them.
  7. Apr 2, 2014 at 9:56 AM
    kriskross
    Monterey
    See Build Thread
    Every night I have left those plugs unplugged. I also used some WireDry on them yesterday. When it comes time to pull it out, I'll get some sandbags and a few Marines to fill 'em.
  8. Apr 2, 2014 at 9:57 AM
    XXXX
    sKiP
    05 Prius
    meh...disconnect the battery for 10 minutes and then those switches so they can dry. If you do not dry them properly you'll be SOL as soon as the corrosion whiskers start growing and shorting things out.
    Swamped mine a few times over the years and never had any electrical issues because I cared for it properly afterwords.
  9. Apr 2, 2014 at 10:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    This is the location of the ECM on the 2009 Tacoma 4X4 with 4.0
    Also in that same area is your 4X4 computer.
    As for your ignition coils, you should be showing 12 Volts on the B-R wire. The W-B wire is the ground. The LG-B wire is from the ECM, and is the "trigger" for the coil. It should show a ground when the coil is supposed to be firing. (ground trigger ignition system) The W-R wire is, if memory serves correctly, part of the internal diagnostics.
    Hope this helps some.
  10. Apr 2, 2014 at 10:16 AM
    kenneth.morris07
    kenneth.morris07 كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    They better only use a spoon to fill them!!!
  11. Apr 2, 2014 at 10:18 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    I never shut it off. Was in like 3 1/2 ft of water and mud. Pulled it out in 5 min. Then air bag lights.
  12. Apr 2, 2014 at 10:29 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Any luck?
  13. Apr 2, 2014 at 10:30 AM
    kriskross
    Monterey
    See Build Thread
    I'm gonna head back today and cross my fingers that it starts up.
  14. Apr 2, 2014 at 10:30 AM
    kriskross
    Monterey
    See Build Thread
    Left the can open and used some WireDry on the ECM plugs
  15. Apr 2, 2014 at 10:38 AM
    #35
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    sub'd for outcome
  16. Apr 2, 2014 at 11:17 AM
    #36
    The End
    The End #allenfab
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    HP60/14 bolt, Atlas 5.0.
    Pull someones ecu out and put it in your truck and see if it has ignition.
  17. Apr 2, 2014 at 3:36 PM
    #37
    kriskross
    Monterey
    See Build Thread
    Battery is dead. Going to have a tow company come out and pull me out with a tow skid tomorrow
  18. Apr 3, 2014 at 12:56 PM
    #38
    kriskross
    Monterey
    See Build Thread
    Got it pulled out of the woods. $250. Gonna Uhaul it back home. Dealership says $105 to program a new ECU. Found one new online for $550. This is becoming a very expensive lesson learned.
  19. Apr 3, 2014 at 3:26 PM
    #39
    Alfuh
    2006 Prerunner
    I have a few mods
    at least its out of that spot man, good to hear. nows the time to add a long stick to the list of things to bring with you on meets :D
    and no running off on your own without checking how deep spots are ;)
  20. Apr 3, 2014 at 6:45 PM
    #40
    SpruceTacoChris
    SpruceTacoChris Well-Known Member
    Las Vegas!
    13 DCSB TRD Offroad
    BAMF Sliders
    Next mod for Chris:
    :) Seriously though, glad its out of the spot and now it should be easier to track down what is wrong.
